What plug's you guy's running with your No2 - TCCoA Forums
post #1 of 12 (permalink) Old 04-24-2007, 12:27 PM Thread Starter
Hey Im just curious what plug's people with N2o are running? I got stock plugs right now in my car and not real sure if I should keep them in or what.
Also do you guy's change your plug's when your on the street not running No2?
97qwikcat is offline
post #2 of 12 (permalink) Old 04-25-2007, 02:28 PM
i have tried running stock plugs,1-2heat range colder plugs and would always get a miss and backfire,i went and tried a set of zex power racer plugs and have never had to pull the plugs since,i did pull them to check to see what they looked like after running down the track on the bottle ,butt they have never given me any problems.i also leave them in and dont switch up between the street and the track
mike
1990 ford f150 5.0
1989 cougar xr-7 5spd 5.0 --249hp/[email protected]
1989 mustang gt [email protected]
1984 tbird 5.0 auto
1999 chevy tracker...wtf!!!!!
joker77_2005 is offline
post #3 of 12 (permalink) Old 04-25-2007, 03:05 PM
NGK TR6's.
I believe they are 1 step colder.
and its N2O....2 parts nitrogen, 1 part oxygen..
post #4 of 12 (permalink) Old 04-26-2007, 06:23 AM Thread Starter
mike
roughly how much did the zex plug's run ya?
NGK TR6's.
Im assuming that is what you ran with this kit? everything worked out fine for ya im assuming. Would the engine work that I have done make any diference on the plug's?
post #5 of 12 (permalink) Old 04-26-2007, 09:27 AM
I actually ran the TR55's(stock heat range), at first, then before I took it off, I bought the correct plugs(TR6's), but never even used them with the spray....I sold them shortly after.
But, with that being said, thats the plug(NGK TR6), that a ton of people told me to use.
And yes, your mods should be just fine!
post #6 of 12 (permalink) Old 04-26-2007, 09:46 AM Thread Starter
you know where you got them a guess on price?
post #7 of 12 (permalink) Old 04-26-2007, 09:51 AM
I picked them up at O-reilly Auto...I think they are around $2 bucks a piece...
post #8 of 12 (permalink) Old 04-26-2007, 10:06 AM
http://www.texas-speed.com/shop/item...d=232&catid=11
check the link
post #9 of 12 (permalink) Old 04-26-2007, 10:09 AM
this one also..
http://www.oreillyauto.com/EW3/Displ...SearchFor=4177
post #10 of 12 (permalink) Old 04-26-2007, 10:18 AM
The more I read on different links, it says the TR6's are 1 step colder than stock, and should be gapped at .035.
post #11 of 12 (permalink) Old 04-26-2007, 10:22 AM
The Great Obucina's Avatar
if you get a nitrous tune from say, BOC, lonnie can set your timing curves up to run A12C plugs on both nitrous and N/A.
"Booyah". Stu Scott.
The Great Obucina is offline
post #12 of 12 (permalink) Old 04-26-2007, 10:33 AM Thread Starter
my thing is I got the guy that tuned it in the first place going to tune it this weekend to get it right. I wanna have all my stuff in place so I don't have to take it back to him. If he doesn't get it right I already contacted lonnie to see what it was gonna run for him to fix it.
