If you live in Tulsa ok beware Quicktrip gasoline - TCCoA Forums
post #1 of 4 (permalink) Old 09-27-2007, 01:30 PM Thread Starter
On Probation
blown96bird's Avatar
Here is a word of warning All the tulsa QuickTrip gasoline stations now have 10% ethanol in there gasolines. There is no law that says they have to disclose this. That is why they are cheaper than other stations because alcohol cost less than gas. The ethanol has only 2/3 the energy of gasoline and you will get 4% less mpg with gasoline that contains it. Also it will mess up your air fuel ratio and could cause your air fuel ratio to go lean which is a real danger if you use forced induction and you might have to compensate by adding 5% more fuel. It can also be harmful to seals in older carbueatored vehicles. Please call the QuickTrip corporate office in national office inTulsa and complain if you don't want this garbage in your gas. 918 615 7700.
blown96bird is offline
post #2 of 4 (permalink) Old 09-27-2007, 02:05 PM
Traveler's Avatar
I can't speak as the the QuikTrip in Tulsa thing, but can anyone else comment on the Alcohol/Gasoline issue?
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #3 of 4 (permalink) Old 09-29-2007, 10:27 PM
Blade Runner's Avatar
It's actually mandatory for them to do that crap here in Houston. When I had my old truck, I found ONE gas station sliding under that did not have it. It was the only gas that would allow my truck to run right.
Blade Runner is offline
post #4 of 4 (permalink) Old 09-30-2007, 11:24 AM
dwinthrup's Avatar
I thought that all gas had 10% ethanol by law.
dwinthrup is offline
