Fav. Methanol Injection kits? - TCCoA Forums
post #1 of 20 (permalink) Old 10-25-2007, 05:14 PM Thread Starter
Silenced's Avatar
What is your favorite methanol injection kit? I'd like to see some opinions on a few -- I'm thinking I want to stay away from MAF based kits if at all possible.
-Ryan
Powered by:
Megasquirt EMS, Vortech Superchargers, Renegade Racing, Gator1980Transmission, Innovative Motorsports, Devil's Own, Magnaflow, Eibach, KYB, Kooks
Silenced is offline
post #2 of 20 (permalink) Old 10-26-2007, 07:39 PM
indiana's Avatar
I've been thinking about getting one too. But it's hard to find the room in the engine compartment. I've been looking at this company, doesn't look to bad.
www.alcoholinjectionsystems.com
95' T-Bird w/ Allen 9psi S/C,JBA headers,30# injectors, 80MM Lightning MAF, 180 Thermostat,190 LPH pump,K&N filter,3.73 gears, Auburn Differential 28 spline for 8.8, SVT 17x7 Cast Alum. Rims w/Michelin Pilot Sport A/S p235/50ZR17, Art True Dual S/S w/High Flow Cats 2.5' Exhaust w/Superturbos, MMC Driveshaft, Cobra Brake upgrade 13"KVR Cross Drilled w/ 2 Piston PBR Calipers, Rear disc convertion w/ 12" KVR Cross Drilled Rotors, Zex Wet Nitrous Kit w/ Polished Bottle, Optima Battery In Trunk, Vortech Intercooler Tank, Tranny Cooler
http://www.supermotors.net/users/Indiana
06' SRT8 Dodge Charger w/Techco Supercharger 5.5psi, Custom Dual Exhaust Dump's, Auto Meter Boost & Fuel Gauges, cross drilled & slotted rotors, Oil cooler
indiana is offline
post #3 of 20 (permalink) Old 10-26-2007, 07:44 PM
95xbird's Avatar
Now water injection is controled by boost off of a swicth right?How is it controlled from a N/A motor??
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #4 of 20 (permalink) Old 10-26-2007, 08:21 PM
This typically isn't used too often on NA applications.
I've been looking at the AIS systems as well.
-Rod
post #5 of 20 (permalink) Old 10-26-2007, 08:46 PM
95xbird's Avatar
-Rod
So I've heard.But the car is going to be supercharged in the next year,maybe two.But I also like the fact it acts as an octane booster.I know this year we will be investing in one for the SVO car.
Its slow, Really.
LS1 KILLER
95xbird is offline
post #6 of 20 (permalink) Old 10-26-2007, 09:38 PM
The MAF based systems could be used in a NA application.
-Rod
post #7 of 20 (permalink) Old 10-26-2007, 10:09 PM
Chapter Director Coordinator
jamesD's Avatar
most of us w/ the SVO use the AIS kit
I bust ARP bolts by hand...
If Guns kill people, then...
...pencils miss spel werds
~Gun Owners of America
jamesD is offline
post #8 of 20 (permalink) Old 10-27-2007, 01:05 AM
just as a fly shoot me a PM on these kits, anyway Steven tried the kit on his allen car and didnt get good gains, but on my svo blower i got great gains
Robert
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 [email protected]
10.11 @ 139.19 best mph
RobertP is offline
post #9 of 20 (permalink) Old 10-29-2007, 12:19 PM
Send a message via AIM to Slowpoke
biggest problem is using too much. You need to realize that you are adding fuel. Unless you are tuning for that extra fuel you wil lloose power. In that regard a lil may work well..Alot wont
Going for broke!!!!
Slowpoke is offline
post #10 of 20 (permalink) Old 10-29-2007, 01:29 PM
i run a 14 gph and didnt retune my air fuel is a little richer with it but its added safety feature, and my car runs just ask the Z06 guys at the track he layed down 409 to the tires and he couldant believe i was smoking him him with and old explorer motor water meth is great on a non intercooled car
10.75 @128.38
RobertP is offline
post #11 of 20 (permalink) Old 10-30-2007, 06:15 AM
392Bird's Avatar
I will be adding a Snow kit to mine over the Winter, so may need some advice. I had planed on having mine on E85 by now to give me the needed octane and extra cooling. The only 1/4 mile strip we have near here is 80 miles away in Bowling Green Ky, and no E85 there, or between me and BG. I will have to continue pulling timing for now.
-----1993 Bird 5.0------
275/50/17 M&H DR on the rear
Click for Full Project
392Bird is offline
post #12 of 20 (permalink) Old 10-31-2007, 12:19 PM
awdRocks's Avatar
Make sure you get the "safe injection" from them.
2002 EXPLORER: 400+whp 2v/M90 434tq / 401rwhp @ 9psi.. suv, 20's, IRS, slush box
COMING SOON: Modular Performance 324ci, Trick Flow Heads w/custom grind cams, Tork Tech TVS SC
awdRocks is offline
post #13 of 20 (permalink) Old 10-31-2007, 02:18 PM
392Bird's Avatar
I will be using there Stage 2 kit, and may have to use there carb plate also. Would rather inject next to the SC discharge, but supposedly the alcohol can puddle in my carb enclosure. Always some thing...
What does the Safe Injection do?
392Bird is offline
post #14 of 20 (permalink) Old 11-01-2007, 01:21 PM
awdRocks's Avatar
Using their silonoid between your carb enclosure and the reservoir might help it not puddle? Basically a one way valve that opens and lets the meth by only when the system is activated. Maybe im not understanding you and this might not have anything to do with it.
A module that is plumbed and wired between the nozzle and reservoir. If you are going to tune for meth (advance timing), I wouldn't even consider the tune without a safe injection.
It basically measures the amount of pressure of meth going through the safe injection unit, when the pressure falls below a pre-determined mark already programmed into the unit, like if you run out of meth on a WOT run, the safe injection will send a 12v signal to a silonoid plumbed into your bypass valve and instantly bleed lots of boost. Therefore automatically retarding your timing and saving your motor. The boost will remain bleeding until you put more juice into the reservoir.
This is good for when you do a P/A.
As you are N/A, I would personally just spray the meth/water for added insurance and cooling power and not tune for it. That's up to you. The extra fluid in your combustion chamber will also help raise your compression a little. And if your motor already has about a 10:1 CR, that is when you can really benefit on performance on a N/A.
I personally love the stuff. I will add it to any car I ever own... even if its just for protection and clenseness (sp).
Hope this helped.
awdRocks is offline
post #15 of 20 (permalink) Old 11-01-2007, 05:11 PM
392Bird's Avatar
Sounds like a good set up. I use to be NA, but now boosted big time. 15 psi for now, and going up in the Spring. Here is what I did back in June.
http://members.tccoa.com/392bird/sup...gerinstall.htm
392Bird is offline
post #16 of 20 (permalink) Old 11-01-2007, 07:39 PM
Well, I was planning on using Safejection. Unfortunately, I don't have a bypass valve with my blower setup. I'll have to figure something else out.
-Rod
post #17 of 20 (permalink) Old 11-02-2007, 12:50 PM
awdRocks's Avatar
-Rod
Can you add one? Try giving Greg a call from Snow. I think they have something.
awdRocks is offline
post #18 of 20 (permalink) Old 11-02-2007, 08:03 PM
Not without fabbing up a one-off inlet plenum and blower manifold. It could happen, but I doubt that I'll have that much time to devote to the car this winter.
-Rod
post #19 of 20 (permalink) Old 11-14-2007, 10:14 PM
Burbank 95sc's Avatar
Mike is running Mr.Freeze by Anderson Ford Motorsports and it works great ,so far.His intake tem dropped from 140* to 76*,his spraying right before the blower.
Derek
96 GT - 4V,T-56,2.2 - video
01 F-150 - work beater
95 SC - 4.6 DOHC,4R70W -sold
94 LX - 4.6 SOHC - scraped
Burbank 95sc is offline
post #20 of 20 (permalink) Old 11-18-2007, 09:29 PM
Boost Happy
Jurgen's Avatar
Send a message via AIM to Jurgen
www.alcoholinjectionsystems.com i run one of their kits last time i checked on a 80* day my numbers were in the 180-190* without under boost and with the AIS kit would drop in the 110* or so its been a while that was on a 20/80 mix its a safe insurance .
1994 Ford Thunderbird
2002 Corvette Z06
Yeah I got a few mods.And Some More
http://www.cardomain.com/ride/239875
Jurgen is offline
