All blown up! - TCCoA Forums
post #1 of 12 (permalink) Old 12-13-2007, 09:13 PM Thread Starter
All blown up!
My cobra motor is shot. That vortech v-1 at 12 lbs just killed it. Or was it me?
RIchard
Pozitrax97 is offline
post #2 of 12 (permalink) Old 12-13-2007, 09:52 PM
Chapter Director Coordinator
jamesD's Avatar
i'm gonna say YES...to both
running over 6psi of boost on a stock motor does run the risk of "blowing it"
what blew up on it?
I bust ARP bolts by hand...
If Guns kill people, then...
...pencils miss spel werds
~Gun Owners of America
jamesD is offline
post #3 of 12 (permalink) Old 12-14-2007, 12:12 PM
awdRocks's Avatar
mmmmm.... What year Cobra motor?
They are forged right? I don't think the boost did it.... the tune did.
2002 EXPLORER: 400+whp 2v/M90 434tq / 401rwhp @ 9psi.. suv, 20's, IRS, slush box
COMING SOON: Modular Performance 324ci, Trick Flow Heads w/custom grind cams, Tork Tech TVS SC
awdRocks is offline
post #4 of 12 (permalink) Old 12-14-2007, 04:04 PM
954.6tbird's Avatar
yeah 6psi aint going to kill a cobra engine...
it had to been a bad tune or lack of fuel and went way lean
Ed
94 Thunderbird 4.6 PI
954.6tbird is offline
post #5 of 12 (permalink) Old 12-14-2007, 05:16 PM
Edited - I guess all years DOHC cobras used forged cranks. I don't know the compression ratios for each year.
Steve
S_Mazza is offline
post #6 of 12 (permalink) Old 12-14-2007, 08:55 PM Thread Starter
It's dead due to over reving in 2nd gear during a race. It had a professional dyno tune and was running 104 race fuel. She had 42 lb injectors, 90mm Lmaf and a 255 lph in tank fuel pump. By the way the crank is forged but not the pistons or rods. I just got greedy. I should have left it with 6 lbs, it had 367 at the wheels back then.
RIchard
post #7 of 12 (permalink) Old 12-14-2007, 09:06 PM
jamesD's Avatar
Originally Posted by S_Mazza View Post
I think the supercharged Cobra motors used forged cranks, but that the N/A Cobras (about the same engine as the Mark VIII) did not. Correct me if I am wrong. So, the question about the year may be directly relevant to why the engine is now dead.
03 cobras are iron block, forged bottom end
96-98 cobras are teksid aluminum, forged crank
99-00 cobras are romeo aluminum, forged crank
jamesD is offline
post #8 of 12 (permalink) Old 02-22-2008, 10:57 AM
joshbea6's Avatar
Ok thread resurrection....
What is the big difference between the Romeo block and the Teksid block (other than one being iron and the other aluminum)? Is one better than the other? Is there THAT MUCH weight savings on the Teksid?
Josh
joshbea6 is offline
post #9 of 12 (permalink) Old 02-22-2008, 12:17 PM
They are completely different castings. The teksid block is actually stronger than an iron block in addition to weighing less.
On the note of the crank, are the Mark8 cranks forged too? Or just the cobras?
post #10 of 12 (permalink) Old 02-22-2008, 12:20 PM
joshbea6's Avatar
I think that the Cobra's are the only ones that are forged.
Were all of the aluminum blocks teksid's? Reason I ask is that I've got a 1994 Mark VIII motor that I'm going to be building, and as I read through stuff, it said on the mark VIII specs that it had an aluminum engine.
Josh
joshbea6 is offline
post #11 of 12 (permalink) Old 02-22-2008, 01:17 PM
Yeah, the mark8 motors were also teksids. All the aluminum 4.6s up till 98 were teksid. In 99 ford started casting the blocks themselves, and the ford blocks are slightly lighter and not as strong.
post #12 of 12 (permalink) Old 02-22-2008, 10:33 PM
jamesD's Avatar
teksids are also 4 bolt mains, romeos are 2 bolt, windsors are 2 bolt w/ studs
jamesD is offline
