Pictures of my new setrab heat exchanger setup - TCCoA Forums
post #1 of 14 (permalink) Old 01-31-2008, 07:05 PM Thread Starter
On Probation
blown96bird's Avatar
I decided to replace my aed heat exchanger. I found a seatrab oil cooler on ebay 22x6x2 oil cooler with an12 fittings IE 3/4 hose size. I had to custom make a aluminum bracket setup to hold the cooler and fans. I am using two 7 inch fans that I have hooked to a toggle switch and relay. Enjoy the pict
blown96bird is offline
post #2 of 14 (permalink) Old 02-05-2008, 11:40 AM
MaleWhore
smokymance's Avatar
you got any complete front end pics of the car? looks like its got plenty of air going to it
smokymance is offline
post #3 of 14 (permalink) Old 02-05-2008, 06:17 PM Thread Starter
On Probation
pictures of the front end
enjoy the pictures
post #4 of 14 (permalink) Old 02-05-2008, 06:25 PM
954.6tbird's Avatar
looking good!
Ed
94 Thunderbird 4.6 PI
954.6tbird is offline
post #5 of 14 (permalink) Old 02-05-2008, 07:35 PM
MaleWhore
smokymance's Avatar
lovely....i need to start cutting!
post #6 of 14 (permalink) Old 03-26-2008, 09:00 AM Thread Starter
On Probation
it has been brought back to life.
post #7 of 14 (permalink) Old 03-26-2008, 03:54 PM
5oh Transformer
ZeroRain's Avatar
Send a message via AIM to ZeroRain
Man you cut open a 96 cover???? You should have got ahold of a 94-95 with the vents already there.
Zero
1996 Ford Thunderbird LX EFI Swapped 311 5spd "TT 5oh project"
1998 Ford Taurus SE 24v Duratec auto "DD"
1966 Ford Galaxy 500 352 Cruise-O-Matic "Restoration Car"
We don't just dream about fast toys, we build them!
ZeroRain is offline
post #8 of 14 (permalink) Old 03-26-2008, 07:37 PM Thread Starter
On Probation
my car is a 96. I am going to try to graph part of a 95 cover into the holes.
Can I see pictures of your 5.0 in a 96 tbird?
post #9 of 14 (permalink) Old 03-26-2008, 08:49 PM
5oh Transformer
ZeroRain's Avatar
Yeah I will snap some pics in the a.m. I have older pics with the carb setup in my photobucket.
Zero
ZeroRain is offline
post #10 of 14 (permalink) Old 03-27-2008, 03:49 PM
5oh Transformer
ZeroRain's Avatar
It has been snowing all day. Didnt get enough time to go out and snap any shots of the bird. I will try again tomorrow.
Zero
ZeroRain is offline
post #11 of 14 (permalink) Old 03-27-2008, 04:02 PM Thread Starter
On Probation
I wish it was cold here. today in tulsa it is 85 degrees.
post #12 of 14 (permalink) Old 03-28-2008, 04:04 PM
5oh Transformer
ZeroRain's Avatar
Well I went out and snapped a few shots of the bird. As you can see the front end i replaced it with twas a 94-95. It was redily available and i only spent 200 on hood, b cover, and header panel with lights. She still needs a set of valve covers before i can actually start her up. The motor is an 87 truck 302 bored 60 over and converted to an mn12 roller valve train.
Zero
ZeroRain is offline
post #13 of 14 (permalink) Old 03-28-2008, 11:42 PM
wow you got a lot of room under your hood with that motor!
always sideways 97 is offline
post #14 of 14 (permalink) Old 03-29-2008, 01:49 AM
5oh Transformer
ZeroRain's Avatar
Yea there is a ton under there since im not using the stock brackets and since all a/c and egr items are removed. The next plan is to make a decent amount of power by slapping an m90 down there. Sorta like a BBK instacharger. I might even go with a bigger roots.
Zero
ZeroRain is offline
