Help it if it fit - TCCoA Forums
post #1 of 5 (permalink) Old 09-17-2008, 05:31 PM Thread Starter
Jensa's Avatar
Send a message via MSN to Jensa
Help it if it fit
Hello everyone
I have found a Eaton Supercharger Model 112 from a SVT Cobra.
Can this work on my T-Bird 94 with 4,6L engine?
What can i need more if this can work?
T-Bird Racing
Underdrive pullies, 9mm Ford Motorsport wires, Open air, 3,73 rear
Jensa is offline
post #2 of 5 (permalink) Old 09-17-2008, 06:51 PM
The_Ghost's Avatar
No, it will not work with your stock heads.
You need the Cobra's DOHC heads, intake, and upper plenum to use the M112.
Sorry, mate.
96 Laser Red 4.6L - Custom
Custom Nascar-Inspired Bodykit - 55* Rear Spoiler - J-modded Trans - 80mm MAF - One-Off Diablosport Chipmaster Revolution Chip/Tune W/Toggle - ScanGaugeII Diagnostics & Data Readout - PBR Brakes - Drilled/Slotted Rotors - SC Wheels & Springs - Falken Tires - KYB GR-1 Shocks/Struts - FSTB - RSTB - RTLB - LECB - 60/40 Split Rear - SC Seats - SC Vac/Boost Gauge
The_Ghost is offline
post #3 of 5 (permalink) Old 09-18-2008, 05:28 AM Thread Starter
Jensa's Avatar
Okey.
Thank you for the infomation do i know
T-Bird Racing
Jensa is offline
post #4 of 5 (permalink) Old 09-18-2008, 06:52 AM
It could possibly work, but it would involve a major amount of aluminum fabrication/welding. Plus the 94 heads are the worst 4.6L heads out there being very restrictive.
Since you have the 94 with the aluminum intake, you basically cut a hole in the top of the manifold and then weld a plate onto it to match the supercharger outlet. There's a LOT of fabrication work, but mainly just aluminum milling, grinding and welding.
I'm even pretty sure someone on here already did something like that years ago. I just can't remember who; Frankencougie maybe?
But just my opinion but on a stock early 4.6L, I don’t think the gains would be worth the fabrication nightmare.
69 F100 LWB w/460 Engine
post #5 of 5 (permalink) Old 09-18-2008, 08:40 AM
fast Ed's Avatar
There is an intake now to install the 03-04 Cobra blowers on 99-04 Mustang GT, so with a P.I. head swap, or intake adapters, its possible ... just a lot of work still.
http://shop.torktech.com/99-04gtsupe...ablower-1.aspx
cheers
Ed N.
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
