ok so today went to the junk yard and found a whole sc inside was gutteed but the engine and s/c was still intact and in one piece. i nabbed the s/c with the top plenum and the piping that says supercharged. my question is has anyone actually got the super charging off the 3.8 to fit a 96/97 4.6L. i have ideas but wanted to see other ideas and go on from there. i only plan to run 6-8psi for now until i can beef the engine and rest of the drive train up.
i dont think so, that V6 supercahrger has 6 ports and your V8 has 8 ports. Im NO expert but im pretty sure it wont work, i dont know how you would account for the other two cyclinders. maybe im wrong.
i've come up with an idea to mount it up. it wont fit under the hood but i'm sure it will work. basically i'm making a mount that has it sit above the intake manifold and a special box under it that will hook up to the intake manifold and another box stemming from the back outlet with a lip inside to hold the oil in. the bracket will hold it 2 1/2 to 3" above the intake manifold so i can fit the custom made connector.
out of curiosity who makes the kit. i rather not how to fabricate all this if i can get just the hardware.
Dude don't waste your money, do it right the first time...and buy my Allen kit
VVVVVV
Don't get me wrong, more power to ya if you can fab everything up yourself and make a complete intake manifold to support the M90. Some one was making some kind of manifold for his V6 to support a M112 lighting blower a while back, but I don't think he finished the project, but you might want to hit him up for some help. He’s the Iowa Chapter D.
i would get an allen if i could afford it. i got this blower in mint condition for less then 100 bucks. and i can fabricate all the mounting stuff for 50 or less. i know i could do it but if there is an easier way then waht im doing then hell i'll do it the easy way.
how much psi do they run at. i want to do a safe psi. if i'm not mistaken they produce 12psi. but i rather have about 6-8 psi. but i'v figured out how to mount it atleast.
i'm not.....yet. once i get a weekend off ill tear apart the intake and t/b and all that and make the mount for it. the hardest thing i'm seeing right now is getting a tube down to the intake manifold inlet.
i'm going to put a blow off valve in between that. and mate the intake with a custom made back plate with a 3.5" tube haning out the back so i can clamp on a hard tube for the intake. the mount will hold the s/c about 2 1/2 inches off the manifold. then i will have a rectangular "tube" going under the mount that will bolt up to inlet of the intake manifold. a hard tube will come from the top of the s/c down to the box. i think i got everything covered.
Toss that M90 breh. slap one of these babies on and call it a day
<a href="http://s178.photobucket.com/albums/w272/blongsworth/?action=view¤t=blower.jpg" target="_blank"><img src="http://i178.photobucket.com/albums/w272/blongsworth/blower.jpg" border="0" alt="Photobucket"></a>
yeah theres a pully thats just there to guide its the one by the left hand coild pack and just under it to the right i was thinking of going back to that s/c and taking off the carry pully and putting it there.
one problem you have with the m90 will be fabricating a manifolds setup to work, figure the belt routing out. build a inlet for the blower with throttle, blower outlet top? You have the plastic manifold so you have the issue of fabricating a complete manifold to bolt the m90 upside down on or under? Or you can build a mount for the m90 to sit on blow thru the top and thru a FMIC and then into the intake....however the m90 will be sticking out thru the hood....All i can say is i see it getting more costly and more time and sweat than just saving and buying a blower kit for the 4.6L and going. On craigs list ive seen KB setups go for 3000$
i think you can just flip the m90 over and build a custom "upper elbow" replacement that will bolt the m90s outlet to the intake manifold however im sure it will still stick thru the hood?
Status
Not open for further replies.
You have insufficient privileges to reply here.
Related Threads
TCCoA Forums
1.5M posts
26.9K members
Since 2002
