AED Fuel Pressure Regulator. - TCCoA Forums
post #1 of 2 (permalink) Old 05-22-2009, 10:59 AM Thread Starter
AEDM8's Avatar
Is there any way to get rid of the fuel pressure regulator can that comes with the kit. Can you bypass it and use a regular FPR if the car has been tuned? Im trying to clean up under the hood and would like to get rid of that eye-sore if possible.
Thanks for your thoughts.
AEDM8 is offline
post #2 of 2 (permalink) Old 05-22-2009, 09:08 PM
On Probation
blown96bird's Avatar
yes you can get rid of it you do need to build a bracket to support the degasing tank. I did it on my bird when I had it tuned. Just run a vacuum line to the manifold so it will see boost
blown96bird is offline
