M112 question - TCCoA Forums
post #1 of 8 (permalink) Old 10-29-2012, 09:50 PM Thread Starter
M112 question
I keep finding low milage eaton m112 chargers on craiglist for relatively cheap 500 -800 bucks. Of course thats just for the blower and in some cases the plenum, throttle body, and injectors so I would need more parts. My question is why is everyone dumping these chargers when comparable kits from tork tech are upward of 5000 dollars? Do the eatons blow up or do they just suck?
AlanE is offline
post #2 of 8 (permalink) Old 10-29-2012, 10:00 PM
Most people selling eatons are Cobra or Lightning owners upgrading to Whipples or KBs. Tork tech gets you a custom accessory drive and manifold.
post #3 of 8 (permalink) Old 10-29-2012, 10:51 PM
Yes, and those that you are finding on craigslist won't fit your 2v 4.6 heads. The 4v cobra C-heads are the most common source for the Eaton M112, however like mentioned before it's not that they are bad, there just easily maxed out like the M90. Whipple/KennyBell/Vortech all make superchargers that will put out more then the stock Eaton M112 which is why people upgrade. The tork tech kit lets you use the m112 supercharger on the 4.6.
post #4 of 8 (permalink) Old 11-11-2012, 10:08 AM Thread Starter
I've already upgraded my heads and intake to PI which is what tork tech requires so I might go that route and stick with a two valve build. As far as a four valve build goes I've found a mark viii long block for $500. All I'm really after is the block because I've got another set of windsor pi heads with 30k on them. what are the performance benefits of using the corbra heads over the mark heads in relation to forced induction? My goal is building a Teksid block with 600 to 650hp at the wheels, needless to say probably a few years down the road before all is said and done.
AlanE is offline
post #5 of 8 (permalink) Old 11-11-2012, 10:32 AM
Well to make 600 plus u better have lots of money, cause u will have 1500-2000 grand in a proper fuel system
Robert
I sell everthing needed for a full fuel system done correctly, there is cheaper ways like a kb boost a pump but that alone want cut it
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 [email protected]
10.11 @ 139.19 best mph
RobertP is offline
post #6 of 8 (permalink) Old 11-13-2012, 06:09 PM
Moderator & Teksid Whore
guitar maestro's Avatar
bon appetite
guitar maestro is offline
post #7 of 8 (permalink) Old 11-28-2012, 04:37 PM
If anyone is interested in the Tork Tech products on this forum I welcome your calls as Super Coupe Performance is a dealer for these awesome items.
Let me know you are from TCCoA and I can offer you a discount on any of their kits.
SCP
513-697-6501
Bill Evanoff is offline
post #8 of 8 (permalink) Old 12-14-2012, 08:48 PM Thread Starter
Originally Posted by guitar maestro View Post
bon appetite
thx
AlanE is offline
