Catch can or oil separator? - TCCoA Forums
post #1 of 9 (permalink) Old 01-22-2019, 05:20 AM Thread Starter
TwoHaggard's Avatar
Catch can or oil separator? Vented or sealed? And how do you have it setup?
What you guys prefer with a boosted set up.
4.6 intercooled vortech explorer swapped tbird.
Thanks!
File Type: jpeg B3D14107-2B77-472B-8CA9-6C7A94A4926F.jpeg (840.4 KB, 8 views)
Project still in progress
Explorer engine, vortech v2,intercooled,bullit intake,derale power steering cooler, b&m trans cooler, oil filter relocation, cobra aluminum radiator, Walbro 255 Pump, Intrax 2in lowering springs, KYB front/back,,mark8 Driveshaft, 1.25Rear sway bar, 3:73 aluminum diff, TrackLok, Rear Diff Cover Brace, Sc Wheels 235/60s, Jmodd, Air Bags in Springs,Rear strut Bar,17in Mirror Blk CobraRs, Sc L Brackets, rear torsional load brace, kmember-frame brace, weightloss program, pbr dual pistons drilled/slotted, stainless lines , recaro seats, sct x4 DonL tuned
TwoHaggard is offline
post #2 of 9 (permalink) Old 01-22-2019, 09:41 AM
S4gunn's Avatar
I use one with my 5.0 engine. You can use a liquid separator for an air compressor or make your own with an old metal water bottle, some steel wool, and two hose barbs.
Are least with the older Windsor engine design, I capture a not insignificant (in terms of cleanliness) 2-3 tablespoons or so oil after a race weekend. Granted this is 14-16 hrs at 3-5.5k rpms. if you find one you like appearance wise, it won't hurt to put one on.
http://goo.gl/csaet4
S4gunn is offline
post #3 of 9 (permalink) Old 01-22-2019, 08:18 PM
I use a separator in a CCV arrangement on my PD blown setup. With your centri, the popular route is to use a vented catch can in a OCV arrangement, as you have no place to draw ahead of the blower.
post #4 of 9 (permalink) Old 01-22-2019, 09:10 PM
MaddMartigan's Avatar
I'm interested in this. Would you care to share more details about your setup since yours is more like mine than everyone else's.
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is offline
post #5 of 9 (permalink) Old 01-23-2019, 10:59 AM Thread Starter
TwoHaggard's Avatar
Anyone see any reason this would be a bad idea. Running each valve cover with -8AN line to a “Y” then run -10AN to a vented catch can?
post #6 of 9 (permalink) Old 01-23-2019, 03:17 PM
T6Rocket's Avatar
It provides no active ventilation of the crankcase with vacuum, just allows the excess pressure to vent somewhere. Some cars can idle rough without a PCV with vacuum, and an engine with some wear on it will smoke out said catch can and smell like burning oil. And sometimes blow the dipstick out.
I always like to use sealed catch cans on each side to catch as much oil as possible. I have two cans made by this company. They have different sizes to match any rubber hose dia. Saikou Michi Co. Home
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
post #7 of 9 (permalink) Old 01-23-2019, 03:36 PM Thread Starter
TwoHaggard's Avatar
Is -8 going to be efficient or should I make it all -10 reason I ask is my trick flow valve covers have -8 and to go to -10 I would have to run another fitting and it won’t be as clean and one more fitting for leaks and such.
post #8 of 9 (permalink) Old 01-23-2019, 04:13 PM
That will work fine for your setup.
Al
With a PD blower or NA setup, a CCV system is the way to go. That really isn't applicable/possible with the OP's centri arrangement though.
post #9 of 9 (permalink) Old 01-23-2019, 07:31 PM
BTW, I bought a cheap can on Amazon, and reworked it, rather than pay $100+.
I Disassembled, cleaned, washed the metal debris out, reworked the fittings and RTVed all the new fittings in so no leaks.
I think I have $30 in it, and it's nice looking, and anodized aluminum.
There's a choice of colors, and it has a sight gauge on the side, so you can see how full it is, and a thumbwheel type, o-ring sealed drain plug at the bottom.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
It's a cheap piece of crap as is, so it needs lovin; just not $60 worth.
