What can the stock 4.6 take? - TCCoA Forums
post #1 of 6 (permalink) Old 11-25-2003, 11:28 PM Thread Starter
330Bullitt's Avatar
Send a message via AIM to 330Bullitt
What can our stock 4.6L blocks take, stock heads aswell. Also, what gains can be expected when running the stock block at boost it can handle, maybe 50 hp? I ask because I want some more power and plan to get a KB unit down the road anyways... and since I plan to build up a seperate block with forged internals and ported heads and cams I figure I can just transplant the blower over when I have the money for the new bottom-end.
So are they safe at say 6psi stock, I plan to run 12-14 when built right...
~Kris
95' Nissan 240sx
94' Mazda RX-7
330Bullitt is offline
post #2 of 6 (permalink) Old 11-26-2003, 12:41 AM
CobraRThunder's Avatar
Duno...they say i am pushing my luck at 89K with my 6-8psi Vortech kit. But i just started the install today....so stay tunned kids, disaster may strike!!!
4R70W From DirtyDog
CobraRThunder is offline
post #3 of 6 (permalink) Old 11-26-2003, 08:22 AM
02 Explorer Pioneer
timb's Avatar
If you look at most of the folks who have run the AED 6 seems just fine with the right tune. Everyone who has pushed it to 9 has lost pistons.
Birdless
timb is offline
post #4 of 6 (permalink) Old 11-26-2003, 12:50 PM
There seem to be lotsa guys running 6psi with high mileage, stock bottom ends... But I don't think that's a guarantee, "anything" can happen when you add boost...
96 GoldBird
N/A:
96 GoldBird is offline
post #5 of 6 (permalink) Old 11-26-2003, 04:45 PM Thread Starter
330Bullitt's Avatar
Well KB says the nonIC is good to 6 on pump gas and the IC kit is good to 9 on pump gas... something to look forward to.
~Kris
95' Nissan 240sx
94' Mazda RX-7
post #6 of 6 (permalink) Old 11-26-2003, 05:24 PM
AED Specialist
A-Train's Avatar
Kris,
I've seen a few naturally aspirated 4.6L 2V engines with broken ring lands on the hyperpathetic pistons. I'd say 6-psi of boost with an intercooler, a good fuel system and a GOOD dyno tune could go many, many miles on a stock 4.6L. Then again, drop fuel pressure at WOT and go lean...it may last a few seconds.
The weak link is the pistons and the connecting rods. If you plan on any boost and you want longevity, I would consider forged pistons and forged rods. You may want to even use a forged Cobra crankshaft to be safe.
I ran 6-psi with the AED kit for two years on the stock '95 ROMEO 4.6L. I then switched to a smaller pulley and even with a good EEC program, I lost a ring land on the piston (passenger side) in about six months.
I now have a '00 4.6L GT engine in the T-Bird (it has the same garbage internals as the '95) and for two years now I've been at 10 psi of boost. I expect it to grenade one day, but for now, she runs great.
So be WARNED...its not "if" it will break...but when.
A-Train
2008 Acura TSX (5AT)
2012 Honda Ridgeline RTL (w/Navi)
Ex toy: 1995 T-Bird LX - ALLEN supercharged, 2000 Mustang GT 4.6L PI engine, lot's of goodies...
12.74 @ 109.45 mph (BEST E.T. BEST MPH)
325 RWHP/380 RWTQ (SAE) on a dynojet
Tuned by Jerry W. from SCT
A-Train is offline
