Cracked Front Cover - TCCoA Forums
post #1 of 2 (permalink) Old 01-24-2004, 06:19 PM Thread Starter
JohnE's Avatar
Exclamation Cracked Front Cover
Well, I've been plagued with an oil leak which started a a small seep and has turned into several drops on the ground where I park. I pulled the front cover and changed the gaskets, even used RTV all the way around. That didn't get it. Then I pulled the crank sensor and lubed it with RTV (general area of leak). Two major efforts and didn't find it.
Today I was under the car fixing an exhaust leak. FRPP shorty header on passenger side is warped and was leaking out both ends! Okay that's another subject. Well I spent a bit of time and cleaned things up. Then I noticed the source.
My front timing cover has a hairline crack under the tensioner!
All this time I thought maybe I'd done something wrong while working on my car. Well I guess I did miss this crack when I had it off a while back. But at least it wasn't from an improper install.
This little tensioner s*cks anyway. Now's a good time to upgrade to a better tensioner design.
John
2000 Chestnut Grand Marquis w/HPP
0 to 60 in 5sec, 1/4 mile 13.3 @ 101
* Rennigade Forged Engine and ported npi heads
* AED 9psi Supercharger, 70mm FRRP TB, 90mm LMAF, Marauder Airbox
* 3.55 Trac-Lok w/extra clutch + F-150 spring, J-Mod Tranny
* Reinhart Exhaust, KB Dead Pedal
JohnE is offline
post #2 of 2 (permalink) Old 01-26-2004, 04:50 PM
AED Specialist
A-Train's Avatar
Talking
John,
I have a 2000 4.6L GT front cover here. Brand spanking new.
PM me, I'll give you a good deal if you want it.
A-Train
2008 Acura TSX (5AT)
2012 Honda Ridgeline RTL (w/Navi)
Ex toy: 1995 T-Bird LX - ALLEN supercharged, 2000 Mustang GT 4.6L PI engine, lot's of goodies...
12.74 @ 109.45 mph (BEST E.T. BEST MPH)
325 RWHP/380 RWTQ (SAE) on a dynojet
Tuned by Jerry W. from SCT
A-Train is offline
