here is how its done - TCCoA Forums
post #1 of 8 (permalink) Old 02-01-2004, 04:09 PM Thread Starter
boost gauge
'97 block, cobra crank, manley rods, probe pistons, ported and polished PI heads, Manley Valves, SHM 2770 cams, 75mm throttle body, 42lb. Injectors, 90mm Lightning maf,, Vortech V-1 S-Trim, 2.62 pulley, 8 rib, vortech mini-race bypass, FRPP 3.73 rearend, j-modded trans, ssautochrome headers, full 2.5" true dual exhaust, high flow cats, 17" fox fives, 275's, Custom Autometer Gauges, sprint springs
nutboy44211 is offline
post #3 of 8 (permalink) Old 02-01-2004, 04:39 PM
CobraRThunder's Avatar
what kinda $hit you trying to pull here. There a dead link .....
4R70W From DirtyDog
CobraRThunder is offline
post #4 of 8 (permalink) Old 02-01-2004, 05:14 PM Thread Starter
my website host sucks d#$% try it again in a bit, it only allows so many uploads per hour
post #5 of 8 (permalink) Old 02-01-2004, 11:19 PM
hahahahha bad link
Andrew-L is offline
post #6 of 8 (permalink) Old 02-01-2004, 11:43 PM
93SC's Avatar
What are you running 20psi in?
UpperMidwest Thundercats
Dyno's are for pussies, I simply put chuck norris in front of my car, and proceed to floor it, he tells me how much HP and torque I have.
93SC is offline
post #7 of 8 (permalink) Old 02-02-2004, 02:50 AM
93SC's Avatar
Sorry, just assumed that wasn't a bird.
93SC is offline
post #8 of 8 (permalink) Old 02-03-2004, 02:49 PM
Red Sox Nation Rabid Fan
TCCoAAC Founding Member
JordanSypek's Avatar
you have no oil pressure....
TCCOAAC (R.I.P. JOEL)
96 4.6 XR7 (T45 Swap, etc.)
95 4.9 F150 4X4 M5R2)
JordanSypek is offline
