Lightning ACT...? - TCCoA Forums
post #1 of 11 (permalink) Old 03-31-2004, 05:36 PM Thread Starter
Question Lightning ACT...?
I searched and it seems almost mandatory for blower cars. Are you centrifugal guys running the Lightning ACT too?
Since I have an air-to-air IC, I would want to plumb it in after the IC, correct?
Does this replace the IAT that is in the stock airbox, or is this something completely different? If its going to help things run safer, I need it. So please educate me.
'97 T-bird LX - 4.6L
The weekend car I never drive
'06 Mustang GT
The Daily
Jack K is offline
post #2 of 11 (permalink) Old 03-31-2004, 06:12 PM
Birdless
Grasshopper's Avatar
Send a message via AIM to Grasshopper Send a message via Yahoo to Grasshopper
I'm not centrifugal, but as I understand it, the Lightning pickup that the ACT is stock on, is supercharged and is located after the IC. You'll have to have your EEC tuned for it in order to take advantage of it.
A man may smile and bid you hail
Yet wish you to the devil;
But when a good dog wags his tail,
You know he's on the level.
--author unknown
Grasshopper is offline
post #3 of 11 (permalink) Old 03-31-2004, 06:17 PM
AED Specialist
A-Train's Avatar
Jack,
This is funny, but the Lightning ACT carries a '96 T-Bird part number. So your '97 sensor is fine to use.
The L-ACT is p.n. F6SZ-12A697-A (#474712). So is the '96 T-Bird IAT.
Put the ACT in after the I/C so the EEC-V knows the actual temperature of the air entering the intake/engine. That way your SCT program will compensate for air charge temperature.
A-Train
2008 Acura TSX (5AT)
2012 Honda Ridgeline RTL (w/Navi)
Ex toy: 1995 T-Bird LX - ALLEN supercharged, 2000 Mustang GT 4.6L PI engine, lot's of goodies...
12.74 @ 109.45 mph (BEST E.T. BEST MPH)
325 RWHP/380 RWTQ (SAE) on a dynojet
Tuned by Jerry W. from SCT
A-Train is offline
post #4 of 11 (permalink) Old 03-31-2004, 06:27 PM Thread Starter
OK, My question is how do I install it so it won't just "blow out" for lack of a better term?
Jack K is offline
post #5 of 11 (permalink) Old 03-31-2004, 06:52 PM
AED Specialist
A-Train's Avatar
Jack,
I can't help you with that. Here is what I did for the AED kit.
Perhaps one of the Vortech guys can get you squared away.
A-Train
A-Train is offline
post #6 of 11 (permalink) Old 03-31-2004, 06:56 PM
JustinH's Avatar
I have the same act, it is tapped very much like Atrains setup.
I will shoot a pic for you if it stops raining out.
JH
JustinH is offline
post #7 of 11 (permalink) Old 03-31-2004, 07:00 PM Thread Starter
Thanks guys. I'm sorry if I'm asking simple questions, but I'm up at school and my Bird is at my parents house, so I am just trying to go off memory on a lot of these things. I'm trying to have a solid plan so when I get home I can get this car setup and start running an SCT program, at least untill I can get it on a dyno with JW.
Jack K is offline
post #8 of 11 (permalink) Old 03-31-2004, 07:07 PM
AED Specialist
A-Train's Avatar
Talking
Jack,
Well there you go. Just make sure it sits in the air stream far enough so you don't get psuedo readings.
A-Train
A-Train is offline
post #9 of 11 (permalink) Old 04-01-2004, 08:02 AM
Get a pipe tap from the plumbing dept in the hardware stire. I tapped mine in on the plastic tube connecting to the tbody. Then screw it in
bc
mazda6 Sport- 06
100hp worth of Stickers coming soon
Blake-vortech is offline
post #10 of 11 (permalink) Old 04-01-2004, 09:14 AM
Birdless
That's what I did, 'cept I didn't actually do it. I paid a machine shop $15 to do it right (I'd mess it up for sure). Then just screwed it in. It has a sealer on the threads.
--author unknown
post #11 of 11 (permalink) Old 04-02-2004, 07:06 PM
I've got mine located between the Water-to-Air Aftercooler and the Throttle body which is a pretty good place for it. Ideally it should be installed directly in the intake plenium or one of the runners.
1996 Thunderbird LX 3.8L
-255rwhp 273rwtq-
-Vortech V1 S-trim [email protected], aftercooled-
-Built 4R70W W/3200rpm PI
1997 Lincoln Mark VIII LSC
-stock, stock, big dent, and more stock-
rancherlee is offline
