Spark Plugs for Supercharger - TCCoA Forums
post #1 of 33 (permalink) Old 06-21-2004, 05:53 PM Thread Starter
I just learned the hard way today that the Denso Irridium Spark Plugs are crap. Save your money and buy the Ford Lightning Spark Plugs for your supercharged T-Bird or Cougar. Scott from AED called me and said that the car was misfiring like crazy at 3/4 to WOT with the Denso Irridium Plugs. They cahged to the CHEAPER Ford Lightning Plugs and the car runs great....Just an piece of advice for all you T-Bird and Cougar people...Don't get suckered into the "Irridium Plugs"
AED 9 PSI Supercharger, .30 over Forged Block with Manley H-Beam Rods & Pistons, Innovative West 10% Overdrive Crank Pulley, Thump RRR Tensioner Pulley, Cobra Crankshaft, BPE Racing Stage 2 Ported & Polished Heads, Crower Direct Replacement Cams, 70MM Throttle Body, MAC Cold Air Intake, 80 MM L-MAF, 38Lbs Injectors, JBA Ceramic Coated Headers, Metal Matrix Drive Shaft, Kevlar Clutch & Kolene Reaction Plate Transmission, True 2.5" Dual Magnaflow Exhaust (Cats & Mufflers), Griffin 1 1/4" Radiator, B&M Racing Trans Cooler, Hughes 2750 Stall Torque Converter, 3.73:1 Gears with Traction Lock Differential, Trans-Go Kit, Superchips Custom Tune for Supercharger, 17" SVT Wheels, Kenny Brown Suspension Enhancers & Eibrach Lowering Kit.
Wolverine27 is offline
post #2 of 33 (permalink) Old 06-21-2004, 06:43 PM
JustinH's Avatar
We have known that for years now.
I run a AWSF-12C plug and it works fine.
Motorcraft copper.
JustinH is offline
post #3 of 33 (permalink) Old 06-21-2004, 09:02 PM
On Probation
blown96bird's Avatar
I run agsf12fm1 plugs gaped at .035
blown96bird is offline
post #4 of 33 (permalink) Old 06-22-2004, 04:41 AM
AED Specialist
A-Train's Avatar
Lightbulb
Wolverine27,
Ford Lightning plugs (AGSF-12 FM1) are iridium/platinum alloy. They have an ultra fine tip and are full thread plugs. They are also two heat ranges colder than stock.
A-Train
2008 Acura TSX (5AT)
2012 Honda Ridgeline RTL (w/Navi)
Ex toy: 1995 T-Bird LX - ALLEN supercharged, 2000 Mustang GT 4.6L PI engine, lot's of goodies...
12.74 @ 109.45 mph (BEST E.T. BEST MPH)
325 RWHP/380 RWTQ (SAE) on a dynojet
Tuned by Jerry W. from SCT
A-Train is offline
post #5 of 33 (permalink) Old 06-22-2004, 08:03 PM
96AEDtbird's Avatar
I really like my Lighting plugs that were purchased from Dan Newman. Car idles much better now.
Previous owner of: '96 Tbird Sport with AED SC.
Best 1/4 mile 13.7sec @ 101mph
Previous owner of:'04 Red Mercury Marauder 100% stock.
Best 1/4 mile 14.6sec @96mph on Dec. 20th at Hallsville, TX
96AEDtbird is offline
post #6 of 33 (permalink) Old 06-22-2004, 08:40 PM
Birdless
Grasshopper's Avatar
Send a message via AIM to Grasshopper Send a message via Yahoo to Grasshopper
I'm running the Lightning one too.
A man may smile and bid you hail
Yet wish you to the devil;
But when a good dog wags his tail,
You know he's on the level.
--author unknown
Grasshopper is offline
post #7 of 33 (permalink) Old 06-22-2004, 11:51 PM Thread Starter
I Just picked up my T-Bird and I love the Supercharger...Getting it Dyno'd next week. AED suspects that I will pull between 330 and 350 at the rear wheels...We will just have to see next week...Thanks for all your advice A-Train...
post #8 of 33 (permalink) Old 06-23-2004, 02:03 AM
On Probation
I can tell you right now your need to upgrade some parts before the tune or pereferably bring them with you and change on site before tune. You are going to need atleast 36# hr injectors and pereferably 42# hr injectors. I would also recomend getting a 90 mm lightning mass air meter. Do you have a 255 lph fuel pump? If not I would get one from mn12performance. Get the one designed for the supercharged system. If you upgrade these parts It should be possiable for you to see 370 rwhp.\
I am only making 330 rwhp and I had to upgrade to 36# hr injectors and a 90 mm lighting mass air meter per "the mans" recomendation. With the power I am making my 30s would be at 105%. Anything beyond 85 % is bad.
post #9 of 33 (permalink) Old 06-23-2004, 09:42 PM
AED Specialist
A-Train's Avatar
Wolverine27,
We went through this and Blown96bird is right. You need more injector, trust us. At least consider 36 lb./hr. units and you can even use the stock 190 lph pump with them.
You'll be disappointed when the car can't spin beyond a ceratin rpm because it's out of fuel on the dyno. Nevermind what could happen to the pistons.
30's are pretty much good for 325 RWHP on an AED kit with no fmu. After that you need more injector and I think with your mods, you could make 340-350 RWHP. Depends on the gas too, your area is know for low octane fuels.
It's up to you. Injectors are easy to swap in.
A-Train
A-Train is offline
post #10 of 33 (permalink) Old 06-26-2004, 11:24 AM Thread Starter
Both Scott and Jim at AED tuned the engine and it is running fine with the 30 lbs injectors. They told me that there is no need to increase anymore. In fact, Scott told me that he does not know why you are suggesting 36's Anthony. He also said that if I want to stay smog legal in CA, stick with the 30's. He said that the 30's are more than enough to handle the 6 PSI boost that I was given....YES...6 PSI and a true 6 PSI at WOT...The tune was custom done by Jim....Remember that I also have every bolt on and ported heads that are smog legal and done by an approved head shop and can handle the extra compression and spark.
post #11 of 33 (permalink) Old 06-26-2004, 11:32 AM Thread Starter
By the way A-Train, the car is set for another Dyno run on July 5th...
First Dyno run was when the main water pump was leaking at the o-ring. The results were only a mere 352 RWHP and 402 lbs of torque. The mechanic was not able to do the second and third pul because of the water pump problem...It was the stock one that came with the car and had 80,000 miles on it....It has been replaced and is now got even more power than when I picked it up at AED...
I burn the tires from 1st until half way threw 2nd....I know, I need better trires then my yokahama AVID H4's, but I know I am at about 355-360 RWHP now and considering Jim said that he had to add 6 degree's of timing to the system, when he tuned the engine, it is one of the fastest 6 PSI birds he has seen...
post #12 of 33 (permalink) Old 06-26-2004, 01:29 PM
AED Specialist
A-Train's Avatar
Wolverine27,
If they tuned it at AED, then I will call Scott and ask him what your MAF lb./min of air was at WOT. Then I will ask what your A/F ratio is and then I'll tell you exactly how dangerously out of fuel injector you really are.
My car pulls in 45 lb/min of airflow at WOT. My A/F ratio is set between 11.8-12.0:1 at WOT. My fuel pressure is 40 psi at idle/part throttle. The EEC-V then knows it must deliver 3.78 lb./min of fuel or 227 lb./hr. of fuel. It must deliver 28.36 lb./hr. of fuel at each fuel injector. I had a 30 lb./hr. fuel injector that meant I was at 95% duty cycle at WOT. I made 325 RWHP/380 RWTQ (SAE), which is not nearly as much power or AIRFLOW as you are seeing with your combo. I switched to 36 lb./hr. injectors to lower the duty cycle and make the combo safer. Duty cycle lowered to 78% at WOT.
Now let's say that it gets cold one day, really cold. The ambient temp drops to 30 degrees F. Colder air is denser and therefore more air will be metered by the MAF and fuel will have to be sent to match it. So AED has you running 30's right now and your fuel pressure is 45 psi at WOT. Your airflow increases to 49 lb./min and your A/F ratio is commanding 11.5:1. That means you need at least 32 lb./hr of fuel at each of your 30 lb./hr. fuel injectors. Guess what? You are now the proud owner of a supercharged 4.6L V-7.
The same applies if it gets to hot. Air is less dense when it's hot so you'll make less power. However, your ACT's will climb higher with the extra ambient air. AED/SCT sets the ACT level around 160 degrees F. At this point, the program adds more fuel and removes some spark timing. Or it should...you want this set-up if you have the ACT sensor in your plenum (which I'm sure they did for you). So you'll be pushing the car in 100 degree heat and bump into the fuel/spark modifiers for the ACT sensor. The EEC will command say 10% more fuel and guess what...you won't have it available.
Clearly you don't understand that boost is backpressure and not a true measurement of airflow. The fact that you are making 6-psi of boost means you have a restriction somewhere, either in the exhaust or inlet. I don't buy the fact that you made 6-psi of boost with the stock 3" pulley and ported/polished heads. That's neither here or there, you are still flowing more cfm than you have fuel injector for.
Now you do as you will with this info. I have no reason to lead you wrong, nor do I care what you do. It's your car, your money, your time. If Scott tells you you're ok...well then it must be ok. But no matter how many ways I add it up...you need more injector.
A-Train
PS I think you missed this...
"Denso Irridium Spark Plugs are crap" & "Don't get suckered into the "Irridium Plugs"
You are saying that iridium is junk or "crap" as you called it. You are telling people to stay away from them as you've had a bad experience with Denso plugs. Fine...but
AGSF-12 FM1 Lightning plugs are made from an IRIDIUM/PLATINUM alloy. Why an alloy, iridium is to brittle to be used alone. The alloy makes it stronger and Denso uses it as well. So you are saying don't use iridium in one sentance and then you said...
"Save your money and buy the Ford Lightning Spark Plugs for your supercharged T-Bird or Cougar".
A-Train is offline
post #13 of 33 (permalink) Old 06-26-2004, 02:54 PM
AEDM8's Avatar
How are you making 6 psi with ported heads? Is that even possible with the stock pulley? You have an exhaust restriction like crazy or your ported heads are not very well ported...????
I personally prefer the copper lightning plugs.
Autolite 103's for me.
AEDM8 is offline
post #14 of 33 (permalink) Old 06-26-2004, 06:45 PM
On Probation
wolverine you are sitting on a ticking time bomb if you don't upgrade to a larger set of injectors. I had it strongly empsised by "JERRY that I should upgrade to a larger injectors. I think a set of 36# hr injectors would work perefectly for your application. A set of injectors is a lot cheaper than a new motor. Some of us know that by experience. You are running out of fuel at the 310 rwhp mark. The 36 will have better cold start cartaritisics than the 42s. If you have forged pistons you can get away with it slightly longer than hyperpathetic pistons but detonation will destroy any piston. You might be having silent deotnation because of the lean condition.
post #15 of 33 (permalink) Old 06-29-2004, 12:56 AM Thread Starter
I have no clue where you guys are coming up with your information, but you are wrong. #0 Lbs injectors can handle up to 450 HP, and since I am at 352 at the Rear Wheels, I am more than adequate with the #30's since I am under 450 at the engine...
As for you individuals that are wondering how I obtained 352 with a 6 PSI Kit, I have Crower Cams, A supped up valve train and a Stage 2 Head Porting and Polishing. I had 239 RWHP prior to the Supercharger kit, with the stock Air Intake Manifold.
Also, as Scott at AED said when one of you contacted him, IT IS A 6 PSI KIT. Thus #30 Injectors are fine....
Scott and I are curious why some of you are preaching larger injectors when he knoew the supercharger, since he designed the system and knows what it can handle. Especially, since he has degree's in engineering and design....Makes no sense that you guys are trying to state facts that go against simple logic....
post #16 of 33 (permalink) Old 06-29-2004, 01:09 AM
On Probation
read up
fuel pump and injector article
injector aritcle must read
Jerry wrote these and knows a more about tuning than scott dose. I am not disrespecting scott but jerry was one of fords top powertrain engineer for years and knows more about tuning that I can even fathom.
injector calculator
another injector sizing equazion
generaly if you are making 352 at the rear wheels to get crank hp you take your figure and go and times 1.21 times you wheel hp to get your crank hp.
Lets say that puts you at 425 crank hp. you devide that into 8 for the number cilinders. That equals 53.125 times by the brake specific fuel consumption usualy arount .6 #per hr = 31.875 pounds per hour. to get the desired injector you need to devide you the percentage of duty cycle 31.875/.85 = 37.5# hr injector at 85% duty cycle.
Remember this if you manifold pressure is 6 psi and you fuel pressure goes up 6psi to 45 psi you are canceling out the increased fuel pressure meingin your injectors are flowing at the standard 39.5 psi like they were rated at by ford for a na application.
post #17 of 33 (permalink) Old 06-29-2004, 01:42 PM
AEDM8's Avatar
I want to see the dyno sheet.
The people who have posted are VERY knowledgable and are only trying to help you keep your engine alive longer. They are not wrong, you are. Why do you feel the need to fight the info they are providing? Read the above articles.
You are on the edge....past the limits of the 30's at least. Your clearly smart enough to figure out a good combo for power....why risk going lean on it? Im sure you can figure out what happens then.....you wont have those numbers to brag about anymore.
What is 200 dollars more compared to what you have already spent?
AEDM8 is offline
post #18 of 33 (permalink) Old 06-29-2004, 03:32 PM
Renegade
chadg's Avatar
Boom...
See my signature? I NEEDED 42# INJECTORS TO SAFELY RUN THERE.
Lets see how many knowledgeable people need to scream at you that you're WRONG until you finally buckle.
-Chad
Down for the count
chadg is offline
post #19 of 33 (permalink) Old 06-29-2004, 07:38 PM
AED Specialist
A-Train's Avatar
Cool
Wolverine27,
OK, good luck with it!
Post a graph some time, we'd love to see it.
A-Train
A-Train is offline
post #20 of 33 (permalink) Old 06-30-2004, 11:54 AM Thread Starter
This is right out of Jerry's article...
If you have 8 injectors and each injector is rated at 30#/hr, then you have a total fuel flow of 8 time 30 or 240 #/hr of fuel. If your car is blown with a BSFC of .6, then you can take this 240#/hr of fuel and divided by the BSFC of .6, then these injectors would support 400 HP at the crankshaft. There are cars out there making more than this, I have worked on some, but in those cases fuel pressure was raised up higher. In some true race only cars, you can run them a little leaner and get a little lower BSFC as well. In the above example if you raised fuel pressure to 55 psi with these 30# injectors, you would be able to support 35.4 times 8 divided by .6 to get a HP of about 472.
post #21 of 33 (permalink) Old 06-30-2004, 12:06 PM Thread Starter
No matter how I do the math, it shows that I am okay
425HP/8 Injectors= 53.125
53.125x.65 BFSC=34.53125
34.53125x.8 Duty Cycle = 27.625 Injectors, which is below a 30....
Thus, Jim at Allen Engine's seems to be correct...By the way, he checked the car yesterday and everything seems to be okay...
post #22 of 33 (permalink) Old 06-30-2004, 12:26 PM
mamberg's Avatar
ok, I will admit that I don't know squat about fuel injector theory, but I do know that your equation is wrong.
should be
34.53125 DIVIDED BY .8 = 43.164....... which is way bigger than 30.
Think of it in reverse, if you have a 43# injector at a 80% duty cycle, then you get 34.5# available.
mamberg is offline
post #23 of 33 (permalink) Old 06-30-2004, 01:50 PM
On Probation
you made a mistake in you last calculation. the 34.531 is the pounds of fuel each cilinder needs at .65 bsfc to get the ideal injector you divide by .80 and not times. Also if you raise the pressure in your system it auctaly cuts flow on the fuel pump the higher the pressure the more the loss and the and manifold pressure also cuts into this.
post #24 of 33 (permalink) Old 07-01-2004, 08:28 AM
Renegade
chadg's Avatar
Crap, why did I spend money on 42# injectors when I could have just ran my 19#s at 100PSI? Damn i'm dumb...
-Chad
Down for the count
chadg is offline
post #25 of 33 (permalink) Old 07-01-2004, 12:02 PM Thread Starter
I see the math was wrong based on a calculation mistake...Still want to know why Jim and Scott are telling me that 30 lbs injectors are all I need then, whne in actuality larger injectors are needed based on the calculation formula's...
When I spoke with Jim, he said that 30 Lbs injectors are good up to 450 HP at the engine...The calculation shows different...
Please let me know if this is an accurate data calculation since I don't know squat about injectors and am just listening to the mechanics...
post #26 of 33 (permalink) Old 07-01-2004, 12:22 PM
On Probation
I think the reason for this is because the kit with the 30#hr injectors is carb certifed and if you changed to the 36# hr injectors the kit would not be carb certifed. It is expensive to get something carb certifed. I would talk to supercustomtuning.com They can asists you in geting a tuner or a tune when 'the man' comes to california. I would get a larger set of 36# hr injectors or 42s. The 36 should work fine since you are only making about 22 hp more than I am and I run 36# hr injectors. STAY AWAY FROM LUCAS INJECTORS I had a set of lucas 38# hr injectors and I had idle problems and they are a little larger around the o ring area and are diffuicult to fit into the allen kit. I think that the problem with lucas is that they have a 1/4 inch shorter tip than the ford bosh injectors. I think that the spray cone patern on the lucas injectors was hitting the boss because of the shorter tip causing the fuel to drop out and puddle.
post #27 of 33 (permalink) Old 07-01-2004, 12:36 PM Thread Starter
Blown Bird,
I just got off the phone with both Allen Engine Development and SCT...Both told me that the 30 lbs injectors are fine, since the formula is wrong in the article...
The BFSC should be .5 (Conservatively) for a Supercharged engine and .35 for a NA engine...
Also, an 80 % duty cycle would mean that I have a 20 percent reserve or an extra 100 HP...They said to use .85 or even .9...
Thus,
425/8 = 53.125
53.125*.5 = 26.5625
26.5625/.85 = 31.25
26.5625/.9 = 29.5138
Thus, both said to stick with the 30 lbs injectors...Do you agree?
I want to stay SMOG LEGAL, since I am in CA
post #28 of 33 (permalink) Old 07-01-2004, 01:55 PM
On Probation
I would do a google search and find programs for calculating hp that the fuel injectors and hp supported by them. I would still say go for the 36's. If you want to stay smog legal in ca I would run the 30s. If you can afford it I would get a extra computer and have sct flash it like your current computer but have them flash it for 36's and get a set of 36s. and only put the 30 and there assiciated computer when it comes time for smog check.
post #29 of 33 (permalink) Old 07-01-2004, 02:05 PM
mamberg's Avatar
Here are a few links for the info:
One
two
three
four
all of them seem to say the BFSC for forced induction engines is at least .6
I think the disconnect here may be that to meet CA standards, the tune has to be less than would be optimal for max HP, which I am sure is what everyone else is after.
mamberg is offline
post #30 of 33 (permalink) Old 07-01-2004, 06:21 PM
AED Specialist
A-Train's Avatar
Wolverine27,
You need to tell me what MAF voltage or LB/MIN or airflow you see at WOT. Then you need to know what A/F ratio you are set at.
The EEC-V then takes the MAF lb./min or airflow and divides it by the commanded A/F ratio. This is how the EEC calculates fuel delivery. So once again, if you are truly at 350 RWHP/400 RWTQ (which you have yet to post a real dyno chart, but rather bench race ) then you are at approx 49 lb./min or airflow.
BOOST DOES NOT EQUAL POWER NOR DOES BOOST MEASURE AIRFLOW! Boost is made when you flow air through a restriction. The more boost pressure you have, the more restriction you have. Want proof? Open up the exhaust (remove you cats and such) and boost drops. Open up the inlet to the bower and boost goes up.
Let's say you are at 11.8:1 A/F ratio. I will go richer later, but for now let's use this as an example since most AED cars like 11.5:1-12.0:1.
49 divided by 11.8:1 = 4.15 lb./min of fuel required to maintain that A/F ratio at WOT.
Multiply by 60 to get lb./hr. and you have 249 lb./hr. of fuel required to hold that A/F ratio. Divide by 8, since you have 8 cylinders and 8 injectors and we get 31.12 lb./hr. of fuel required at each of your 30 lb./hr. fuel injectors.
EITHER YOU ARE NO WHERE CLOSE TO 350 RHWP OR YOU ARE OUT OF FUEL. Which is it?
I have contacted AED and I know your set-up and until you post a real dyno chart, you are bench racing.
Here you go, here is my dyno chart.
A-Train
A-Train is offline
