T Bird SC Charger on 03 V6 Stang - TCCoA Forums
post #1 of 4 (permalink) Old 08-30-2004, 06:19 PM Thread Starter
Ok, a friend of mine has a 92 Tbird SC hes getting rid of (Junkyard), but the charger still works fine. Is it possible and practical to take this out and put it on my 03 V6 mustang? How would I do it and what would I need? All help is appreciated
DrumSTW3 is offline
post #2 of 4 (permalink) Old 08-30-2004, 06:27 PM
On Probation
blown96bird's Avatar
It can be done but it is not easy. first off get the entire motor and all electrics off the car. The sc motor is special and diffrent to its NA brothern. The sc motor has a forged crank and extra heavy duity block, harmonic ballancer, heads.
It won't be praticle to insall on you split port 3.8 motor. I would recomend that you get the entire motor though. The heads could be sold off to sc members along with the lower intake manifold. Like I said above the block and crank are special and much stronger than your 3.8 block and crank.
I would recomend that you go with a centrifcal that is offered for your car and possiably build up a forged 3.8 sc block for when your stock block lets go.
blown96bird is offline
post #3 of 4 (permalink) Old 08-30-2004, 07:20 PM
save your money up and pick up the procharger or vortech kit and run one of those on your stock engine.
1996 Thunderbird LX 3.8L
-255rwhp 273rwtq-
-Vortech V1 S-trim [email protected], aftercooled-
-Built 4R70W W/3200rpm PI
1997 Lincoln Mark VIII LSC
-stock, stock, big dent, and more stock-
rancherlee is offline
post #4 of 4 (permalink) Old 09-02-2004, 03:40 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
in order to put the sc on your split-port motor, you would need to use the sc heads as well (Unless you spent big bucks on a custom lower intake manifold. And by the time you got rid of your split-port heads, which have bigger valves and breath WAY better than single-ports, you'd only be 25hp higher. I'd look into a centrifugal supercharger as well.
-Thomas
Thomas is offline
