Exhaust requirements for 9psi? - TCCoA Forums
post #1 of 5 (permalink) Old 11-10-2004, 07:56 AM Thread Starter
Mod Motor Cat's Avatar
Asked this over in the exhaust section, but it doesn't seem to have caught on with the rest of the board yet.
Read here.
http://forums.tccoa.com/showthread.p...781#post464781
~Brian~
*1990 Mustang Coupe, 5.4L*
Black on Black & Stroked 'n' Polked!!!
Mod Motor Cat is offline
post #2 of 5 (permalink) Old 11-12-2004, 07:15 PM
indiana's Avatar
http:/www.tccoa.com/articles/exhaust/pipes.html
I'm running 2.5' true duals with my set-up and have 280rwhp- 350rwtq.
95' T-Bird w/ Allen 9psi S/C,JBA headers,30# injectors, 80MM Lightning MAF, 180 Thermostat,190 LPH pump,K&N filter,3.73 gears, Auburn Differential 28 spline for 8.8, SVT 17x7 Cast Alum. Rims w/Michelin Pilot Sport A/S p235/50ZR17, Art True Dual S/S w/High Flow Cats 2.5' Exhaust w/Superturbos, MMC Driveshaft, Cobra Brake upgrade 13"KVR Cross Drilled w/ 2 Piston PBR Calipers, Rear disc convertion w/ 12" KVR Cross Drilled Rotors, Zex Wet Nitrous Kit w/ Polished Bottle, Optima Battery In Trunk, Vortech Intercooler Tank, Tranny Cooler
http://www.supermotors.net/users/Indiana
06' SRT8 Dodge Charger w/Techco Supercharger 5.5psi, Custom Dual Exhaust Dump's, Auto Meter Boost & Fuel Gauges, cross drilled & slotted rotors, Oil cooler
indiana is offline
post #3 of 5 (permalink) Old 11-12-2004, 07:16 PM
indiana's Avatar
http://www.tccoa.com/articles/exhaust/pipes.html
indiana is offline
post #4 of 5 (permalink) Old 11-12-2004, 09:53 PM Thread Starter
Yeah, i've seen that graph before, but I don't put much stock into it. It's pretty general. I'm not even sure if that's a flywheel horsepower rating, or rear wheel?
Besides, I'd think that the exhaust requirments for a blown engine, would be a little higher than that of a N/A set up. I'm hoping to make horsepower within the 350rwhp range and torque up around 400rwhp. Maybe I might have to go with the ART exhaust afterall?
~Brian~
post #5 of 5 (permalink) Old 12-07-2004, 02:10 AM
I was running 352 RWHP with a 2.5" true dual exhaust system and 2 two stage cats along with an H-Pipe. If you go to a true 2.5" dual exhaust system, make sure that it is mandrel bent and has an H-Pipe to equalize the pressure and allow for more power and better exhaust...
Can handle well over 400 BHP
-Steve
AED 9 PSI Supercharger, .30 over Forged Block with Manley H-Beam Rods & Pistons, Innovative West 10% Overdrive Crank Pulley, Thump RRR Tensioner Pulley, Cobra Crankshaft, BPE Racing Stage 2 Ported & Polished Heads, Crower Direct Replacement Cams, 70MM Throttle Body, MAC Cold Air Intake, 80 MM L-MAF, 38Lbs Injectors, JBA Ceramic Coated Headers, Metal Matrix Drive Shaft, Kevlar Clutch & Kolene Reaction Plate Transmission, True 2.5" Dual Magnaflow Exhaust (Cats & Mufflers), Griffin 1 1/4" Radiator, B&M Racing Trans Cooler, Hughes 2750 Stall Torque Converter, 3.73:1 Gears with Traction Lock Differential, Trans-Go Kit, Superchips Custom Tune for Supercharger, 17" SVT Wheels, Kenny Brown Suspension Enhancers & Eibrach Lowering Kit.
Wolverine27 is offline
