bolt on supercharger - TCCoA Forums
post #1 of 52 (permalink) Old 02-03-2005, 06:56 PM Thread Starter
i was wanting to know what superchargers are out there that will bolt straight on to my 96 bird and were can i find these at?
2007 mazda 5- grocery getter
95 mustang gt convertible- newest project
thunderchicken17 is offline
post #2 of 52 (permalink) Old 02-03-2005, 07:45 PM
On Probation
blown96bird's Avatar
First off there is no bolt on supercharger for the bird other than allen engine development unfotunatly they are no longer in business. What I would recomned and get if I had the money would be a kenny bell whipple charger for a 96-98 GT. DO NOT TELL THEM IT IS FOR A 96 THUNDERBIRD NO MATER WHAT. If you do they won't sell you the kit. I imagine it will work but some custom egr plumbing will have to be done but that is not so bad. The 96-98 mustang gt uses the same belt routing, alt, ps pump, ac compressor, pullies, EGR valve, fuel rails, throttlebody and various other parts. I am not sure but I think that the throttle linkage bracket is the same if it is you can use the bird throttle and cruise cables.
It might require relocating the batterie to the trunk and it will definatly require a 3 inch raised cowl hood. If you get the hood make sure you get hood pins. If you get the supercharger make sure you start saving for a forged motor with ported heads because the stock motor is not going to last too long when you are making 500 crank hp.
blown96bird is offline
post #3 of 52 (permalink) Old 02-04-2005, 05:58 AM Thread Starter
hopfully someone pics up the allen line
post #4 of 52 (permalink) Old 02-04-2005, 07:52 AM
02 Explorer Pioneer
timb's Avatar
I beg to differ
Still in production and available from Dan Newman
Birdless
timb is offline
post #5 of 52 (permalink) Old 02-04-2005, 07:58 AM Thread Starter
were can i get some info about the supercharger, how much boost do they produce and how much do they run?
post #6 of 52 (permalink) Old 02-04-2005, 08:02 AM
02 Explorer Pioneer
timb's Avatar
It's an SVO from Ford Racing. They come with a 6lb pulley. You can do a complete install with tune from Lonnie for around 2500. Since you have a 96 Tbird you shouldn't need to trim your hood. On the 94 you have to remove the center brace. I've had mine on for 30,000 miles now
Birdless
timb is offline
post #7 of 52 (permalink) Old 02-04-2005, 08:07 AM Thread Starter
were can i get all the parts i need to install the supercharger and is there a way to up the boost
post #8 of 52 (permalink) Old 02-04-2005, 08:14 AM
02 Explorer Pioneer
timb's Avatar
It all comes with the supercharger and install kit. The only thing I would recomend adding is a 80mm MAF if you don't already have one and tap one of the runners for a lighning ACT sensor so Lonnie can pull timing as blower temp increases. The install kit comes with 30lb injectors 190 lph fuel pump and all the brackets and bolts required. If you have a fax machine I can fax you the install instructions with packing list. It even comes with an EEC tuned by Ford but I sold mine since the SCT tuning is way better. I forgot to mention the entire instal including dropping the tank for the new pump took 8 hours. You can up the boost but wouldn't recomend more than 6 on a stock block you can go tto 9 but then blower outlet temps really ramp up and without an intercooler the only option is water injection to bring it down
Birdless
timb is offline
post #9 of 52 (permalink) Old 02-04-2005, 08:19 AM Thread Starter
cool, so who do i contact or call to get this supercharger.
post #10 of 52 (permalink) Old 02-04-2005, 08:22 AM
02 Explorer Pioneer
timb's Avatar
Any Ford parts department but Dan Newman gives us a great discount on Ford Parts and will be the cheapest you will find
Birdless
timb is offline
post #11 of 52 (permalink) Old 02-04-2005, 08:26 AM
02 Explorer Pioneer
timb's Avatar
Let us know what you find out I'm curious if pricing has changed any in the last year
Birdless
timb is offline
post #12 of 52 (permalink) Old 02-04-2005, 09:58 AM
Peter M's Avatar
Ok, now the $50 question. Is it C.A.R.B. certified for use on a T-Bird in CA?
Peter M.
SOLD 1996 4.6l Thunderbird-(fast) PI intake, custom exhaust, Bullet-Resistant Tranny™, blah, blah, blah
2007 VW GTI-(faster) United Grey, 18" wheels, APR stage 1 chip, and... uh... that's it for now.
________________________
..this space for rent..
Peter M is offline
post #13 of 52 (permalink) Old 02-04-2005, 10:04 AM
02 Explorer Pioneer
timb's Avatar
Good question check the FRPP catalog....if I had to bet I would say no....I would also bet my 02 explorer motor isn't either. I'm so glad I left the fruit and nut state back in 84.
Birdless
timb is offline
post #14 of 52 (permalink) Old 02-04-2005, 11:01 AM
Peter M's Avatar
AAAAAARRRRRRRGGGGGGGHHHHH!!!!!!!!!!
...sorry about the mess...
Peter M.
Peter M is offline
post #15 of 52 (permalink) Old 02-04-2005, 11:04 AM
02 Explorer Pioneer
timb's Avatar
Since it has Ford stamped on it do you think they would know it wasn't the origional intake anymore than they know you have a PI? Just asking because all that crp happened after I left and I don't know how close they inspect
Birdless
timb is offline
post #16 of 52 (permalink) Old 02-04-2005, 11:12 AM
girdnerg's Avatar
Originally Posted by timb
...FRPP catalog....
How do I go about getting one for myself folks?
Rob
girdnerg is offline
post #17 of 52 (permalink) Old 02-04-2005, 11:13 AM
02 Explorer Pioneer
timb's Avatar
Call Dan he will send you one.
Birdless
timb is offline
post #18 of 52 (permalink) Old 02-04-2005, 11:27 AM
AEDM8's Avatar
Have you dyno'd with that setup?
Were you the guy who was going to do water injection? How did that ever turn out?
AEDM8 is offline
post #19 of 52 (permalink) Old 02-04-2005, 01:01 PM
02 Explorer Pioneer
timb's Avatar
Haven't dyno'd I just drive it. The tune J sent me in the mail was great from the start so I never bothered with a dyno. John (Cam94) was the guy who was going to use the snow injection. I plugged my 1/4 mile figures in a HP calculator for a WAG and came up with 255 at the wheels but who knows.
Birdless
timb is offline
post #20 of 52 (permalink) Old 02-04-2005, 09:58 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
was your 1/4 mile around mid-high 13's?
Thomas is offline
post #21 of 52 (permalink) Old 02-06-2005, 04:38 PM
02 Explorer Pioneer
timb's Avatar
Thomas,
With good traction yes it would be. Here is a run down from the last time I ran at the track...you can see I have a lot to gain in the 60' department. Since this timeslip I have changed rearend gears to 3.27 and have a mustange converter rather than the Tbird one
94 trans with Jmod and stock converter
open 3.08 rear
SVO blower
ART Exhaust
Temps were around 75*
60'......2.179
330'.....6.137
1/8......9.347
MPH....77.49
1000'...12.048
1/4......14.339
MPH......97.96
Birdless
timb is offline
post #22 of 52 (permalink) Old 02-07-2005, 07:58 PM
Ox
Ox's Avatar
The install kit went up in price and the blower "may" be going up as well from the last time I talked to Dan (last week but I talk to him once a week or more). I got both before it was too late. 04 Exploder motor is being ordered tomorrow (man they charge alot for 04's) along with a 70MM TB and I should "hopefully" have everything in by March along with slicks (drag radials won't cut it) and a PI triple disc later on along with a beefier tranny. MK8 TC will suffice for now along with my 3rd transmission.
Broke a valve spring last Friday and luckily got it fixed Sat by a kick a$$ mechanic. Engine really needs to come out.
Tim-How long time wise have you had your blower?
95 4.6 [email protected] 1.748 60' (drag tune with drag radials and racing gas) Street Tune: 288HP and 326TQ Body Retired-Engine and other goodies transferred below)
96 4.6 [email protected], 349HP and 380TQ on pump gas and drag radials.
Funded by me built by the man RobertP
Ox is offline
post #23 of 52 (permalink) Old 02-07-2005, 08:07 PM
well ill give my 2 cents here is my times
first itme ive ran it temps were 70 degrees and like 48 prcent humidity 12s are definetly there
1.84 60ft
1/4 mile 13.09 @ 103.36
dont have the slip in front of me so i dont know the 1/8 time
this is on my completely stock 95 motor it has comp cams in it those
im still waiting on my 70 mm throttle body so there is no question 12s are there and i do plan on the the snow injection with straight water
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 [email protected]
10.11 @ 139.19 best mph
All made possible with Braincoating's ported manifolds
RobertP is offline
post #24 of 52 (permalink) Old 02-08-2005, 08:32 AM
02 Explorer Pioneer
timb's Avatar
A little over a year 35,000 miles
Birdless
timb is offline
post #25 of 52 (permalink) Old 02-24-2005, 09:23 PM
Send a message via AIM to burittobob
will the blower work on a NPI engine? or is it for the pi engines only
removed 3rd cat and resonator installed flowmaster true duals,removed air silencer, 16"Taurus SHO wheels with 235/55/16 falkens, Intrax drop springs, KyB shocks
burittobob is offline
post #26 of 52 (permalink) Old 02-24-2005, 09:32 PM
ford racing sells it in both versions pi and npi
10.75 @128.38
RobertP is offline
post #27 of 52 (permalink) Old 02-25-2005, 06:46 AM
Recidivistic Procrastinator
I have a ported SVO for sale with 9 lb pulley. Ad is the the parts for sale forum under "ported SVO". Mine is for NPI heads. Good deal for anyone interested!
94 LX 4.6
Hibernating...
Engine built by Jim O'[email protected] Racing
I live with "fear" everyday, sometimes she lets me race...
Cam94 is offline
post #28 of 52 (permalink) Old 03-09-2005, 04:05 PM
supercharging
you can get a whole kit from supercoupeperformance.com under 4.6 thunderbird cougar
mekanik84 is offline
post #29 of 52 (permalink) Old 03-09-2005, 06:25 PM
lobo's Avatar
Send a message via Yahoo to lobo
The kit on Supercoupe performance is the Allen kit...which isn't available anymore.
2013 Mustang GT...2013 Escape
lobo is offline
post #30 of 52 (permalink) Old 03-10-2005, 01:04 PM
Destructor90's Avatar
Send a message via AIM to Destructor90 Send a message via MSN to Destructor90 Send a message via Yahoo to Destructor90
did you try seeing if you could fit a vortech v8 super chager on it???
Your Local Discount Tire Hook Up
1989 Ford Thunderbird Super Coupe
Drive Fast, Fly Low, Be Safe
Prick Racing
Destructor90 is offline
