Gapping Plugs for Supercharged Engine - TCCoA Forums
post #1 of 25 (permalink) Old 06-23-2005, 10:13 PM Thread Starter
Don't call me a Newbie
RoushTBirdNo1of6's Avatar
I was searching around to determine where to gap the Motorcraft 12c's for my recently aquired Vortech Blown 4.6L '96 TBird. It looks like it breaks down into two camps:
  1. Big Gap - 0.052"-0.060" (stock being 0.052"-0.056")
  2. Small Gap - 0.032"-0.040"
I found Supercharged cars in both camps. Well, THAT helped.
Some seem to think that the biggest gap that the ignition system will support, is the way to go. Others seem to be concerned with the spark being "blown out" in the larger gap range.
I even found someone running a 0.025" gap, and he swears by it.
For the record, this is what Vortech has in the FAQ on their site:
11. What spark plugs should I use with a Vortech supercharger system?
Always utilize the stock specified heat range for street legal applications. For continuous heavy-duty racing, off road use only, use one heat range colder than stock and reduce the gap to 0.032 to .040". (NOTE: the gap requirement varies per the application and intended use). It is suggested that you follow the manufacturers suggested recommendation for spark plugs. Do not use platinum plugs, as they are considered long life spark plugs and are not performance spark plugs. For higher performance engines, consult the spark plug manufacturers for their specific suggestions.
So they suggest the stock plug and gap, unless racing...then only one step colder and the smaller gap range. Of course, the mantra around here is TWO steps colder (How cold of a plug to use, is a different issue that I am MORE than satisfied with...hence the 12c's going in my car ). At least Vortech agrees on Copper over Platinum, as most people here seem to.
Now, I'm not trying to start a knife fight. I know that some peoples mechanical beliefs are more sacred than their religious beliefs. However, I'd like to hear what gap people are running on Supercharged cars and why; preferably backed up by some sort of reference, documentation or something beyond a gut feeling or "I was told to". The old Try-Test-Change-Repeat process, for finding what works, is valid...IMHO.
Ok folks, have at it....but try to play nice.
Wayne Hazard Wife is back from Kuwait - Welcome Back, Chief! My Multiply Site
1995 4.6L Thunderbird LX - Daily Driver...1 3/4 Miles to Work and Back
1996 4.6L Thunderbird LX, Vortech V-2 SQ Blown - Heart transplant in the works.
   (If SC+V6 = SuperCoupe, wouldn't SC+V8 = SuperDuperCoupe?)
1997 Mark Martin Signature Thunderbird (AKA: "1 of 6")* - 25k mi Garage Queen
   *A Significant Thunderbird in the Thunderbird RegistryAww, man...I can't believe Mark drives a freekin' Chevy now.
RoushTBirdNo1of6 is offline
post #2 of 25 (permalink) Old 06-23-2005, 10:28 PM
ZackG's Avatar
mine are personally gapped at .030 and i run 12c's
97 Tbird 4.6
Vortech at XY psi
4.10's, KB boost a spark.
Yummy.
ZackG is offline
post #3 of 25 (permalink) Old 06-23-2005, 10:37 PM
awdRocks's Avatar
im going one step colder than stock and will gap at .035
im also gonna do the gap test runs until i get my best trap speeds... then leave it at that faster gap. but im starting at .035 SCT recommended .035
2002 EXPLORER: 400+whp 2v/M90 434tq / 401rwhp @ 9psi.. suv, 20's, IRS, slush box
COMING SOON: Modular Performance 324ci, Trick Flow Heads w/custom grind cams, Tork Tech TVS SC
awdRocks is offline
post #4 of 25 (permalink) Old 06-24-2005, 07:06 AM
On Probation
blown96bird's Avatar
spark plug gap
I currently run the awsfa 12 c plugs gaped at .35 of inch. When I gaped them at .41 I had spark blowout. I was advised by The Man to use 2 steps colder than stock and gap them from .35-.37.
On you gauge cluster if you want a sc cluster this is what I done on mine. I purchaced a 95 sc cluster and swaped out the cluster but I had to take my v8 tack out of the old cluster and install it into the old one because the v6 one is diffrent. I did take the face off the supercoupe one and put it on the v8 one so it would say premiumin unlead only.
blown96bird is offline
post #5 of 25 (permalink) Old 06-24-2005, 09:13 AM
Blown306's Avatar
The Man gave me the blessing on .040", one step colder...but I have a MSD 6A ignition and Blaster coil. With the factory ignition, .035" was recommended by Kenne Bell as well as the Man. I can't see how a big gap would work, unless running pretty low boost levels (< 6#) and staying out of the throttle...but who in the world would want to do that!
- Blown306 "Putting the THUNDER back in the BIRD"
Past President, Webmaster - Chicagoland Thunderbirds
'93 LX Kenne Bell 306
'01 Mustang GT Convertible
'02 Excursion Limited Ultimate Diesel
'03 Harley V-Rod - Two Tone Anniversary
Blown306 is offline
post #6 of 25 (permalink) Old 06-24-2005, 09:35 AM
awdRocks's Avatar
to think i first ran with boost a 12 uradium/platinum plug at .044... recommended from AED themselves... VERY FRUSTRATING!!!
glad I found this site!!!
awdRocks is offline
post #7 of 25 (permalink) Old 06-24-2005, 10:39 AM
02 Explorer Pioneer
timb's Avatar
I run .32
Birdless
timb is offline
post #8 of 25 (permalink) Old 06-24-2005, 10:28 PM
AED Specialist
A-Train's Avatar
AGSF-12FM1 gapped at 0.037". Works great for me.
A-Train
2008 Acura TSX (5AT)
2012 Honda Ridgeline RTL (w/Navi)
Ex toy: 1995 T-Bird LX - ALLEN supercharged, 2000 Mustang GT 4.6L PI engine, lot's of goodies...
12.74 @ 109.45 mph (BEST E.T. BEST MPH)
325 RWHP/380 RWTQ (SAE) on a dynojet
Tuned by Jerry W. from SCT
A-Train is offline
post #9 of 25 (permalink) Old 06-24-2005, 10:58 PM Thread Starter
Thanks, one and all, for the replies! Seems that the majority are in the 0.035" (give or take a couple of thousanths) camp. I suppose, being the conservative type of guy that I am, I'll do 0.035" for the moment. Once I have some other kinks ironed out of the car, I'll do some testing with some other gaps.
So if you'll excuse me...I'm going do a little prep work for tomorrow...
post #10 of 25 (permalink) Old 06-24-2005, 11:20 PM
CobraRThunder's Avatar
you back in town? Give me a ring...mine is still down and I am antsy in my pantsy to see the car.
4R70W From DirtyDog
CobraRThunder is offline
post #11 of 25 (permalink) Old 06-24-2005, 11:32 PM Thread Starter
Yep, I'll give you a ring tomorrow. Or if you drive by and see the hood up on a red TBird...there's a good chance that it'll be me.
post #12 of 25 (permalink) Old 06-25-2005, 11:44 AM
Rude's Avatar
Send a message via AIM to Rude Send a message via Skype™ to Rude
A-Train
Ditto
Rudeman
Rude is offline
post #13 of 25 (permalink) Old 06-25-2005, 11:56 AM
awdRocks's Avatar
Originally Posted by Rude
Ditto
Rudeman
I guess I was just gapped to big with the 12FM1...
awdRocks is offline
post #14 of 25 (permalink) Old 06-26-2005, 03:17 PM
AEDM8's Avatar
Didnt like the FM1's. Waste of money IMO.
AEDM8 is offline
post #15 of 25 (permalink) Old 07-05-2005, 01:12 PM
awdRocks's Avatar
I just replaced my plugs from FM1s to copper one step colder than stock and gapped .at 35.... HOLLY COW!!!
day and night.... these copper plugs stuck me to the seat.... huge difference.
awdRocks is offline
post #16 of 25 (permalink) Old 07-05-2005, 07:48 PM
AEDM8's Avatar
Good deal. What gap did you go with?
AEDM8 is offline
post #17 of 25 (permalink) Old 07-05-2005, 08:04 PM
awdRocks's Avatar
gapped at 35....
feels like a muscle suv now
its a trip. with the FM1's at say ... coming out of a stop light.... at about 2k... i would wak it ... and she felt hesitent and climbed ok.... and I tested two sets of plugs... so my plugs were good.
Now... i waked it the same way.... BAM... instant trust... slammed me to the seat with NO hesitation. Tried it through different rpm's and same... VERY quick responce... I can finally feel what all the hype is about an AED being a bottom end king.
I cant wait to get her tuned and switch to 9psi!!!
I suppose I could have been gapped really wrong with the FM1's. Jim said .44
What ever the case.... im happy with these plugs.
awdRocks is offline
post #18 of 25 (permalink) Old 07-05-2005, 08:54 PM
AED Specialist
A-Train's Avatar
Yeap, gapping a plug at or over 0.044" with 6-9 psi of boost will blow the spark out. So you are now enjoying the power you were missing. Happened to me as well.
Ran 14.5 @ 94 mph with 0.054" gap
Ran 14.1 @ 99 mph with 0.040" gap
Ran 13.9 @ 100 mph with 0.035" gap
I settled for 0.037" since 0.035" felt like it was dropping cylinders at idle.
IMHO, I ran many different types of spark plugs with my 10 year old T-Bird. 5 years under boost too. I used AWSF-32C, AWSF-32PP/EE, AWSFA-12C, AGSF-12EE, AGSF-12-FM1, AGSF-22 FM1...etc.
I like AGSF-12 FM1's gapped at 0.037". Coppers work well, but I wanted a plug that was slightly more durable.
A-Train
A-Train is offline
post #19 of 25 (permalink) Old 07-05-2005, 10:26 PM
AEDM8's Avatar
Durable and 4X the price.
Im not sure how much longer Ill have the AED under the hood but if it ends up being more than a year I want to pick up a KB BAS and see what I gain by going with a little bit larger gap.
Im currently at .037 but feel that there is power left if I can get the spark to jump that gap. Just need to make up my mind on how I want to get to my power goals.
AEDM8 is offline
post #20 of 25 (permalink) Old 07-05-2005, 10:28 PM
ZackG's Avatar
after i get mine running right again, i think im going to open the gap up alittle more. .035 or .037
97 Tbird 4.6
Vortech at XY psi
Yummy.
ZackG is offline
post #21 of 25 (permalink) Old 07-06-2005, 09:28 AM
prsrizdgt's Avatar
A-Train
This is the Lightning (iridium) plug correct? That is what I am running anyway with no ill-effects gapped at .035.
I am curious about the post refering to low rpm power. He was saying switching to copper made a huge differance. Isn't it more likely that the gap was the problem and not so much the plug type?
AED Supercharged Mustang GT
prsrizdgt is offline
post #22 of 25 (permalink) Old 07-06-2005, 09:56 AM
awdRocks's Avatar
Yes that is the lighting plug.
And yes most likely or VERY likely my power problem with the FM1's was running the wrong gap size.
I dont know how true this is please someone correct me if im wrong, but I have heard that with platinum/iridium (maybe just platinum)plugs under heavy boost the plug can almost stay lit like a "glow plug" and cause premature (EDIT) ignition or detonation. With copper that problem is eliminated.
awdRocks is offline
post #23 of 25 (permalink) Old 07-07-2005, 05:59 PM
On Probation
plug gaps
I regaped my plugs making the plug gap more consistant. I had them gaped any where from .32 to .37. I tried to open the gap up to .38 and .37 and experienced spark blow out in the upper rpms around 5300-5800. I regaped them to a .35 keeping a eye on tight tolerences. The car idles smoother and has slightly more vacuum and no spark blow out in the upper rpm area.
post #24 of 25 (permalink) Old 07-08-2005, 05:48 AM
prsrizdgt's Avatar
What are you guys experiencing that indicates "spark blow-out"???
Is it as obvious as a clearly felt miss or cutting out under boost, or is it more subtle like it is just sluggish or loosing a little power under boost?
post #25 of 25 (permalink) Old 07-08-2005, 07:14 AM
awdRocks's Avatar
well i was gapped 44 and i had no power... sluggish... and felt like it missed.... like missing a cyclinder. i thought it was because because my tune is so rich...
even with the new plugs im still rich at 8mpg but finally has power.
awdRocks is offline
