What size MAF are you running with your Super? - TCCoA Forums
post #1 of 19 (permalink) Old 01-12-2006, 06:17 PM Thread Starter
i have a 75mm Pro-flow with 6-psi Allen on the 4.6
post #2 of 19 (permalink) Old 01-12-2006, 06:24 PM
Whining Intakes Rock
Al_Florida's Avatar
90mm LMAF with the SVO
# 0 rows returned
# drop table users;_
Al_Florida is offline
post #3 of 19 (permalink) Old 01-12-2006, 07:17 PM
CobraRThunder's Avatar
90mm LMAF with the Vortech. 75mm BBK TB. Full tilt, almost maxed out.
PI cams in the trunk
4R70W From DirtyDog
CobraRThunder is offline
post #4 of 19 (permalink) Old 01-12-2006, 07:32 PM
SCT 2400 - Good to 650+ HP
Eric Z. is offline
post #5 of 19 (permalink) Old 01-12-2006, 08:32 PM
Ox
Ox's Avatar
95 4.6 [email protected] 1.748 60' (drag tune with drag radials and racing gas) Street Tune: 288HP and 326TQ Body Retired-Engine and other goodies transferred below)
96 4.6 [email protected], 349HP and 380TQ on pump gas and drag radials.
Funded by me built by the man RobertP
Ox is offline
post #6 of 19 (permalink) Old 01-12-2006, 08:35 PM
Overkill Fetish Freak
90mm L-MAF.
Dr. FrankenCougie is offline
post #7 of 19 (permalink) Old 01-12-2006, 08:35 PM
Birdless
Grasshopper's Avatar
Send a message via AIM to Grasshopper Send a message via Yahoo to Grasshopper
80mm LMAF
A man may smile and bid you hail
Yet wish you to the devil;
But when a good dog wags his tail,
You know he's on the level.
--author unknown
Grasshopper is offline
post #8 of 19 (permalink) Old 01-13-2006, 09:45 AM
02 Explorer Pioneer
timb's Avatar
80mm Mustang MAF with SVO
Birdless
timb is offline
post #9 of 19 (permalink) Old 01-13-2006, 10:26 AM
Was gonna go with a Pro-M, but changed our minds to use a 90mm Cobra MAF with extender instead on an intercooled T-Trim application ...
which means I have a spare, brand new, in the box Pro-M I'll probably be selling.
-mike
96 GoldBird
N/A:
96 GoldBird is offline
post #10 of 19 (permalink) Old 01-13-2006, 12:43 PM
80mm Lightning Maf
Roadhawg is offline
post #11 of 19 (permalink) Old 01-13-2006, 01:36 PM
scottkornhaus's Avatar
90mm MAF
-Kornhaus
scottkornhaus is offline
post #12 of 19 (permalink) Old 01-13-2006, 01:52 PM
MAMN12 Posse Member
JeffTBird93's Avatar
~Jeff
*signed off
JeffTBird93 is offline
post #13 of 19 (permalink) Old 01-14-2006, 05:54 PM
ZackG's Avatar
97 Tbird 4.6
Vortech at XY psi
4.10's, KB boost a spark.
Yummy.
ZackG is offline
post #14 of 19 (permalink) Old 01-14-2006, 06:01 PM
Pro-M 75mm Blowthru using the 24# 95 GT Calibration, Works great and still has room to grow (hit 4.5v on the dyno)
1996 Thunderbird LX 3.8L
-255rwhp 273rwtq-
-Vortech V1 S-trim [email protected], aftercooled-
-Built 4R70W W/3200rpm PI
1997 Lincoln Mark VIII LSC
-stock, stock, big dent, and more stock-
rancherlee is offline
post #15 of 19 (permalink) Old 01-17-2006, 10:44 PM
Mod Motor Cat's Avatar
90mm LMAF/75mm BBK T/B with an overspun AED Rev I
~Brian~
*1990 Mustang Coupe, 5.4L*
Black on Black & Stroked 'n' Polked!!!
Mod Motor Cat is offline
post #16 of 19 (permalink) Old 01-18-2006, 08:40 AM
On Probation
blown96bird's Avatar
90 MM L maf
I am running a 90 mm Lighting mass air meter. 75 mm BBK throttle body. 8 psi aed with 2.5 pulley. I am also running 36#hr injectors. I peged the 80 MM L maf.
blown96bird is offline
post #17 of 19 (permalink) Old 01-18-2006, 02:53 PM
wilson502's Avatar
you mean 75mm BBK Thorttle body steven?
2007 White Ford Focus SE ZX3 Hatchback (The new driver)
1997 Alpine Green 4.6L Bird (SOLD!)
Mods:
Removed Air silencer, Clear Corners, Silverstar headlights and corner lights, Moroso Bluemax Spiral Core wires, Custom 3" Magnaflow exhaust with 2.5" Y-Pipe, 300-450 HP J-mod Kit by dirtyd0g , Hayden 30k GVWR Trans Cooler, Sport Front Suspension, 03-04 Cobra Rear Shocks, PBR Front Brake Swap, Xcal 2 by Lonnie @ Blueovalchips.com, 22C plugs, 180F T-stat, 02GT MAF/Airbox with K&N Drop in, Griffin Radiator, Cobra Water Pump
wilson502 is offline
post #18 of 19 (permalink) Old 01-18-2006, 05:47 PM
On Probation
error corected
post #19 of 19 (permalink) Old 01-18-2006, 06:22 PM
AED Specialist
A-Train's Avatar
I've been using an 80mm L-MAF for years now.
Pegs at 54 lb./min
I'm at 44 lb/min
It would take more than an Eaton M90S to reach 54 lb./min
A-Train
2008 Acura TSX (5AT)
2012 Honda Ridgeline RTL (w/Navi)
Ex toy: 1995 T-Bird LX - ALLEN supercharged, 2000 Mustang GT 4.6L PI engine, lot's of goodies...
12.74 @ 109.45 mph (BEST E.T. BEST MPH)
325 RWHP/380 RWTQ (SAE) on a dynojet
Tuned by Jerry W. from SCT
A-Train is offline
