Negative Boost - TCCoA Forums
post #1 of 7 (permalink) Old 03-06-2006, 05:56 PM Thread Starter
Kolenich's Avatar
Negative Boost
Can someone explain to me why boost gauges operate in negative boost. If the + side is psi above atmospheric pressure then is negative below atmospheric pressure. So is it true that naturally aspirated engines operate at atmospheric pressure or 0 on a boost gauge.
Thank you
Kalr
Kolenich is offline
post #2 of 7 (permalink) Old 03-06-2006, 05:58 PM
The Great Obucina's Avatar
dont you mean vacuum?
"Booyah". Stu Scott.
The Great Obucina is offline
post #3 of 7 (permalink) Old 03-06-2006, 06:57 PM
mamberg's Avatar
A naturally aspirated engine operates at 'negative boost', or vacuum. If it didn't, it wouldn't 'suck' any air into the engine.
A supercharger, or turbo forces more air into the engine than it would draw by itself, thus creating 'boost'.
The statements in this post are my opinions only.
If you have a problem with them, please PM me
and keep the boards clear of flame wars.
_____________________________________________
mamberg is offline
post #4 of 7 (permalink) Old 03-06-2006, 08:20 PM
Darrin's Avatar
If an NA engine is not showing a vacuum when its running then you either have a REALLY big problem or you have the gauge hooked up to the wrong end of the engine.
Darrin is offline
post #5 of 7 (permalink) Old 03-22-2006, 08:24 PM
greencurse's Avatar
actually you should be reading 18-22 in Hg (inches of mercury) at 2000 rpm on manifold vacum (below the throotle plates) using a vacum gauge hooked up to a good source (i like the brake booster)
-greencurse
1997 Thunderbird LX, 4.6L, Performance White.
3.27 TL, 300hp J-Mod, Mid-Mount Magnaflow w/2.25" True Duals to 3" Magnaflow 15* Slash Cut Tips, PI Intake,
FR500 Steering Wheel, FRPP Wires, 180* T-Stat, 22C Plugs, Cobra Vert Rears, RSTB, SC "L" Braces. 175k and still flying!
greencurse is offline
post #6 of 7 (permalink) Old 03-22-2006, 08:45 PM
Mark M. TCCoA VP's Avatar
Normal outside pressure at sea level with a temp of 70F you should be at 29.92 HG (inches of mercury) which is the standard. The metric equivalent is 1013 millibars. One Bar is equal to one atmosphere which is 14.7lbs per sq in. Damn the crap you remember LOL
An engine is an air pump so you should think of it in that way.
"Mark M. TCCoA VP. Emeritus"
To the Batmobile ! ! !
ADDCO MN12 big bar R&D guru
Mark M. TCCoA VP is offline
post #7 of 7 (permalink) Old 03-23-2006, 03:12 PM
MaleWhore
smokymance's Avatar
-greencurse
right on...mine is right at 18 to 18.5 at 2k RMP....
smokymance is offline
