SC'ing options for a DOHC - TCCoA Forums
post #1 of 48 (permalink) Old 04-05-2006, 02:55 PM Thread Starter
Toombs's Avatar
I'm just trying to get a game plan together here. I think ultimately I'd like to throw 6-7 psi of boost at my 96 Mark motor. What options are there? Best? Cheapest? Discuss.....
Mike
- DOHC 4.6
- 4.56 Trac-Loc
- DirtyDog Converter (3,800)
- SCT Micro Tuner from Blue Oval Chips
- 13.24 @ 103mph
ToombsRacing.com
Toombs is offline
post #2 of 48 (permalink) Old 04-05-2006, 03:17 PM
Boom.
Palmguy's Avatar
I'd say you've got two options:
1. Centrifugal, used or new...used Vortech would likely be the most readily available as well as cheapest option, but there are others out there. An S-Trim would probably suffice.
2. KB 96-98 Cobra kit...probably will have to buy new. Would give you more bottom end for sure, but if you've got 4.56 gears than I suppose who cares...lol
TCCoABAMFC - Founding Member
TCCoA Gun Club
Palmguy is offline
post #3 of 48 (permalink) Old 04-05-2006, 04:06 PM Thread Starter
Toombs's Avatar
What about fitting up a 99 era Cobra SC? Can this be made to work?
Mike
- DOHC 4.6
- 4.56 Trac-Loc
- 13.24 @ 103mph
ToombsRacing.com
Toombs is offline
post #4 of 48 (permalink) Old 04-05-2006, 04:11 PM
Boom.
Palmguy's Avatar
Well the 99-01 Cobras were N/A, the 03-04 has the M112 but the manifold it sits on bolts up to the tumble port heads. It wouldn't work unless you fabbed up your own intake manifold or swapped heads.
TCCoA Gun Club
Palmguy is offline
post #5 of 48 (permalink) Old 04-05-2006, 04:31 PM Thread Starter
Toombs's Avatar
I thought the later ones used the tumble port heads, but I didn't know if the manifold could be adapted or not. Oh, and I'm obviously not real up to speed about Cobras, because I thought for some reason they went SC'ed in 99, and were NA for 96-98. Thanks for the info!
Mike
- DOHC 4.6
- 4.56 Trac-Loc
- 13.24 @ 103mph
ToombsRacing.com
Toombs is offline
post #6 of 48 (permalink) Old 04-05-2006, 04:46 PM
I Break Stuff
94V8Thunderbird's Avatar
Send a message via AIM to 94V8Thunderbird Send a message via Yahoo to 94V8Thunderbird
the cobras were NA from 96-01
1988 Mustang GT 306, 4 bbl holley, edlebrock intake, nitrous cam, 4 inch cowl hood.
94 LX PI swapped Bird (sold) missing that car so bad
TCCoABAMF
94V8Thunderbird is offline
post #7 of 48 (permalink) Old 08-16-2006, 12:36 PM Thread Starter
Toombs's Avatar
Alright, digging up old stuff here.....
So is there any easy way to make a Vortech work with my Gen 1 Mark intake? I haven't found much, but this isn't my forte. I'm just trying to learn whats available. What do the Gen 1 Mark guys do? All the stuff I find here is about Gen 2's.
Mike
- DOHC 4.6
- 4.56 Trac-Loc
- 13.24 @ 103mph
ToombsRacing.com
Toombs is offline
post #8 of 48 (permalink) Old 08-16-2006, 12:45 PM
I was looking at that very option and what I was "thinking" was this:
Take the OEM hard tube air intake from the Gen I, resin it in fiberglass or carbon fiber (just using the mesh as a covering), and then just plumb the output of the Centrifugal into the opening that originally went to the MAF tube. The small 1.5” round outlet in the air tube (where it plumbs to the “resonator chamber”) could be used to plumb to a blow off valve so the tube would never see much boost. I think the tube is pretty strong, but a layer of glass around it would really strengthen it up.
But this was just what I came up with in my head when I was looking at that setup for my 94, so I have no idea if that would work. But I know a carbon fiber intake tube plumbed to a centrifugal supercharger on a Gen I would look awesome!!
I think most everyone with a Gen I that goes boosted, first converts over the Cobra intake and then just goes that route.
69 F100 LWB w/460 Engine
post #9 of 48 (permalink) Old 08-16-2006, 12:45 PM
Traveler's Avatar
I think ThomasA on the SCCoA site has a blown 97 Mark VIII. No, wait, I KNOW he has one. I've seen it, awesome car!
http://www.sccoa.com/forums/member.php?u=236
look him up, I'm sure he could help you out with info, though his is a 97 and I assume a Gen II. (I'm not real informed about Marks)
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #10 of 48 (permalink) Old 08-16-2006, 02:07 PM
jhosler's Avatar
Send a message via AIM to jhosler Send a message via MSN to jhosler Send a message via Yahoo to jhosler
Or you send a message to Burbank 98 lsc he has one that ones 11's with a vortec setup.
-Jason
2001 Lincoln Continental Limited
2006 Suzuki Boulevard M50
jhosler is offline
post #11 of 48 (permalink) Old 08-16-2006, 02:34 PM Thread Starter
Toombs's Avatar
Again though, those are both Gen 2 setups. I'm looking at Gen 1 for now. Seeing what the options are without changing intakes.
Mike
- DOHC 4.6
- 4.56 Trac-Loc
- 13.24 @ 103mph
ToombsRacing.com
Toombs is offline
post #12 of 48 (permalink) Old 08-16-2006, 04:22 PM
Lonnie's Avatar
What you want to do is use a 96 - 97 Cobra kit. You'll have to fab up your own inlet pipe, that's the easy part. The hard part is getting the SC inlet piping to fit between the SC and the radiator. You will have to cut and move the radiator lower mount and move it to lower the whole radiator in order to clear the inlet. There's actually more to it than this but just to give you an idea. It's all up to how good you are at your own fabrication. Or you take it to a shop and have them do it. I've done a couple of them.
www.blueovalchips.com
1992 5.0 Thunderbird Sport, 328 rwhp 347 rwtq
1995 Mark VIII, 287 rwhp 305 rwtq
I have seen the truth and it makes no sense
Lonnie is offline
post #13 of 48 (permalink) Old 08-16-2006, 04:53 PM Thread Starter
Toombs's Avatar
Thanks for your input Lonnie. I wonder....I've been thinking of getting rid of the AC....I wonder if removing the condenser would allow the radiator to be moved forward enough to provide the required clearance. Just thinking out loud here, because I haven't really looked at it on the car. It may not even be feasible, depending on the size of the condenser. Hmmm....
Mike
- DOHC 4.6
- 4.56 Trac-Loc
- 13.24 @ 103mph
ToombsRacing.com
Toombs is offline
post #14 of 48 (permalink) Old 08-16-2006, 04:55 PM Thread Starter
Toombs's Avatar
Looking at another angle, what needs to happen to make a 96-98 Cobra KB kit work? Aside from the obvious hood clearance issues.....
Mike
- DOHC 4.6
- 4.56 Trac-Loc
- 13.24 @ 103mph
ToombsRacing.com
Toombs is offline
post #15 of 48 (permalink) Old 08-16-2006, 05:40 PM
Mike
From what I've found, you'll need the following 96-98 Cobra parts to install a 96-98 Cobra KB onto a Gen I Mark 8 engine:
throttle body
throttle body cable
intake tube
fuel rail
IMRC's
The cool thing is that the KB kit is now based on a 2.1L big bore twin screw blower.
-Rod
post #16 of 48 (permalink) Old 08-16-2006, 07:15 PM
MaddMartigan's Avatar
If you do choose to get rid of the AC, you will have a ton of room to move the radiator forward. You will just have to figure out how to mount it but that shouldn't be a huge deal if you can fab things yourself (or somebody in that race car family of yours )
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is offline
post #17 of 48 (permalink) Old 08-17-2006, 06:34 PM
Mod Motor Cat's Avatar
throttle body
throttle body cable
intake tube
fuel rail
IMRC's
-Rod
Actually....the '96-'98 Cobra one only got the upgrade from the 1.5L to the 1.7L
http://www.kennebell.net/supercharge...angcobra46.htm
~Brian~
*1990 Mustang Coupe, 5.4L*
Black on Black & Stroked 'n' Polked!!!
Mod Motor Cat is offline
post #18 of 48 (permalink) Old 08-17-2006, 07:29 PM
Lonnie's Avatar
There's no after cooler either. I was thinking of trying this but then figured if I'm going to go that route I might as well switch heads and get a kit with the cooler.
Lonnie is offline
post #19 of 48 (permalink) Old 08-17-2006, 08:27 PM
It's actually just been upgraded again to the 2.1L. The website just hasn't been updated yet. Take a look at the price list on the KB website. It was just updated back on 8/2/06. The kit is TS1000-96C, and it is listed as a 2.1L. The blower went from a 1.7L to a 2.1L, and the price went from $3699 to $3799.
If you're planning on sticking with 6 psi, an aftercooler isn't absolutely necessary.
-Rod
post #20 of 48 (permalink) Old 08-18-2006, 09:16 AM
-Rod
My mistake then.
....and as for the lack of intercooler......water/methanol will work miracles in that dept.
~Brian~
post #21 of 48 (permalink) Old 08-20-2006, 07:22 PM
PDL2MDL
krazy4's Avatar
meth works wonders definately
http://www.youtube.com/watch?v=oMjdto07tuk
LX w/ true duals, cutouts
cone filter
Bird is gone replaced by an LS1.
krazy4 is offline
post #22 of 48 (permalink) Old 08-23-2006, 04:00 PM
On my 93 Mark, I tipped the ac condenser all the way forward, made some new
brackets, then slipped an 03 cobra radiator under the upper crossmember,
leaving the bottom in the stock position but the top tipped forward (w/new
brackets) and flipped the stock fan to offset it to the drivers side.
I had to cut out a chunk of fan shroud about the size of your hand for the
blower intake elbow (vortech), leaving good room for the engine to move
without anything rubbing.
I am using the stock gen1 air tube wrapped in kevlar, but getting a seal at
the throttle body required a machined aluminum oval collar w/ o-ring and a
3/8" groove on top that the plastic tube will be rtv'd into for seal.
The BOV connects to the blower discharge elbow, so seal up both resonator
holes, keep the air temp sensor bung and I'm keeping the breather bung
open just in case I want to try meth injection.
Blower is mounted, filter/maf/blower intake is ready, working on air tube/blower
dischage elbow now.
Mel C.
93 garnet/grey
Garage Queen
PS - And it all fits under the stock hood.
Melmark93 is offline
post #23 of 48 (permalink) Old 09-12-2006, 12:25 PM
mechman1984's Avatar
Are there any computer tuning issues to adding a superchager to a gen 1 dohc mark viii motor.
Will
Will
08 Ford Ranger
95 Thunderbird V8-Sold!
mechman1984 is offline
post #24 of 48 (permalink) Old 09-12-2006, 12:44 PM
93, 94 & 95 Mark ecm's are OBD1 and cannot be re-flashed, so a chip must
be used to compensate for the larger MAF and injectors needed.
I bought a SCT ProRacer kit which allows you to program your own chip, but
I'll get a baseline dyno tune from a SCT dealer before I try tweaking anything
myself.
Mel C.
93 garnet/grey
Garage Queen
post #25 of 48 (permalink) Old 09-12-2006, 01:55 PM Thread Starter
Toombs's Avatar
You have any pics of your setup?
Mike
- DOHC 4.6
- 4.56 Trac-Loc
- 13.24 @ 103mph
ToombsRacing.com
Toombs is offline
post #26 of 48 (permalink) Old 09-12-2006, 02:40 PM
I bought a new camera to document the project and took a bunch of pictures,
but they're still in the camera. I haven't even loaded the photo software on
the laptop. I may be forced to do something soon, however, my wife keeps
snapping family picts and soon the chip will be full.
I've never posted photo to a forum, so that's another hurdle to jump also.
If there's anything specific I could discribe, just ask.
Mel C.
93 garnet/grey
Garage Queen
post #27 of 48 (permalink) Old 09-27-2006, 10:02 PM
BIG PETE's Avatar
http://www.speedfreak.cc/mk.8/engine/index.html
If you're seeking some inspiration ;-)
Pete
-97 XR-7
-5.0 Big Bore ...
Density Altitude = 4132'
1/8 mile: 8.75 @ 82
BIG PETE is offline
post #28 of 48 (permalink) Old 09-28-2006, 08:17 AM Thread Starter
Toombs's Avatar
I've been considering swapping to the Cobra intake when I SC mine, just to make the SC install cleaner. But that adds another $500 (roughly) to the project. Now, I can justify that to myself if I'm convinced that the Cobra manifold will make signifigantly more power than the Mark's. Otherwise, I'm adding $500 to the project because I'm too lazy to make an intake tube for my existing manifold!
Mike
- DOHC 4.6
- 4.56 Trac-Loc
- 13.24 @ 103mph
ToombsRacing.com
Toombs is offline
post #29 of 48 (permalink) Old 10-17-2006, 06:44 PM
CEO, WT Club
GODSPEED's Avatar
So just curious, what kinda hp/tq numbers is the DOHC gonna see with the KB kit on it? Any guesses?
-Joel
Previous MN12s:
GODSPEED is offline
post #30 of 48 (permalink) Old 10-17-2006, 06:55 PM
-Joel
I'm expecting around 370-380 rwhp or so, with a slightly lower rwtq number.
-Rod
