who has supercharged a 5.0 tbird - TCCoA Forums
post #1 of 24 (permalink) Old 10-27-2006, 12:27 AM Thread Starter
i have a 92 bird with the 5.0 who here has done there with a supercharger?
what kits are out there /and ideas
25svo is offline
post #2 of 24 (permalink) Old 10-27-2006, 04:21 PM
Thunder Canary's Avatar
Send a message via AIM to Thunder Canary
kenne bell makes a kit for 3 grand
A nut is a nut and a bolt is a bolt. Wrench 'em off!
I used to dream about this car now I drive it- ditto
SVO Heads
SVO Intake
SHM cams
JE pistons
Eagle rods
Cobra crank
Thunder Canary is offline
post #3 of 24 (permalink) Old 10-27-2006, 08:21 PM Thread Starter
i went that route already
25svo is offline
post #4 of 24 (permalink) Old 10-28-2006, 11:54 AM
mechman1984's Avatar
Did you not like the kit or si it not the right coimbo for you.
Will
Will
08 Ford Ranger
95 Thunderbird V8-Sold!
mechman1984 is offline
post #5 of 24 (permalink) Old 10-28-2006, 01:47 PM
Vortec? If not..turbo it.
"Pain is inevitable. Suffering is optional. "
LincolnLSC5pnt0 is offline
post #6 of 24 (permalink) Old 10-29-2006, 08:06 PM Thread Starter
vortec dosent make a kit they say
and who does turbo's?
25svo is offline
post #7 of 24 (permalink) Old 10-29-2006, 09:57 PM
VicRattlehead's Avatar
and what happend?? btw i believe they are the only ones that make a 'kit' for the tbirds. if you want to do anything for these cars its never a kit you always have to fab it in.
CMP Drag Racing
VicRattlehead is offline
post #8 of 24 (permalink) Old 10-29-2006, 10:34 PM
Does anyone have anything to say on the quality of kit or the results in general.
Will
Will
08 Ford Ranger
post #9 of 24 (permalink) Old 10-30-2006, 02:00 AM Thread Starter
i dunno but my buddy swapped in a mustang motor as i did for the forged,
he used his brackets and went with a novi 2000 complete plug in play but hes off in the war and his car is somewhere overseas
so i cant refer to that for the space issuses
25svo is offline
post #10 of 24 (permalink) Old 10-30-2006, 10:56 AM
I have a 5.0 vortech supercharger. You can view it on lonnie's blueovalchips.com website. Lots of fab work but now everything is perfect. Lonnie had a writeup on it in the tech articles. It really is an expensive adventure. Because of the extra power a lot of other things need to be upgraded and other things fail. I am selling my tbird now that has a brand new engine that supports the supercharger and a T-56 tranny that was just put in as well. It is running better than it ever did before. 377hp and 370 tq to the wheels. Should have it officially on sale shortly in the papers and internet.
John is offline
post #11 of 24 (permalink) Old 11-01-2006, 12:41 AM Thread Starter
hardly any info on there, actually none at all
25svo is offline
post #12 of 24 (permalink) Old 11-01-2006, 04:48 AM
MaddMartigan's Avatar
What are you looking for specifically? You've given a lot of short, simple replies to everyone that has replied but you still haven't given much information. What are you trying to accomplish? What is your budget?
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is offline
post #13 of 24 (permalink) Old 11-01-2006, 05:33 PM
dwinthrup's Avatar
and whats up with the kenne bell kit i was thinking of going that route but the no longer have the kit
dwinthrup is offline
post #14 of 24 (permalink) Old 11-01-2006, 06:57 PM
Of course after i find out about it they discontinue the kit. What was in the kit any way i can't imagine it was anything different then a mustang kit considering it was eec4.
Will
Will
08 Ford Ranger
post #15 of 24 (permalink) Old 11-01-2006, 08:44 PM
The bottom line is that there is no kit for the 5.0 MN12. The "easiest" thing to do these days is to get a 94-95 Mustang alternator bracket and then adapt the Vortech kit for a 94-95 Mustang. You are going to have to fab some parts and you may have to change the hood. That's life with these cars. It's very doable but it will take some work on your end.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #16 of 24 (permalink) Old 11-01-2006, 08:50 PM
Well there was a kenne bell kit out there so it clearly must have been a "bolt" on design so that leads me to believe that the 5.0l birds are relativiely easy to supercharge minus brackets and things of that nature. Personally i would go kenne bell anyway becuase there are no brackets to fab its just bolt on and go plus i think the kenne bell is the better design anyway.
Will
Will
08 Ford Ranger
post #17 of 24 (permalink) Old 11-02-2006, 04:53 AM
Will
Apparently they don't make that kit anymore. In any event it's all a matter of perspective. The KB kit was a roots blower. If you want the down low power then that's the kit for you. Since it replaces your entire intake manifold I'm not so sure how easy it really is but it is certainly different.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #18 of 24 (permalink) Old 11-02-2006, 04:13 PM
dwinthrup's Avatar
just the top half and you got to choose gt 40 or stock lower. like i said i was looking into it procrastination sucks
post #19 of 24 (permalink) Old 11-06-2006, 04:44 PM
KB Mustang vs. Thunderbird 5.0 Kit
What would the major differences be between these two kits (hood clearance aside)? If I wanted to maintain the A/C, what other considerations would you need to make if you wanted to install this supercharger?
FordofSin is offline
post #20 of 24 (permalink) Old 11-06-2006, 06:01 PM
My 93 LX was, I believe, the second supercharged 5.0 Thunderbird at the time. I used an adaptation of the Mustang Powerdyne kit. I converted the car to use an 89-93 Mustang GT EEC and used an Autologic chip. The car ran pretty good. If I had it to do over, however, I would use the Kenne-Bell blower for better part throttle torque. It should not be that difficult to adapt the 89-93 Mustang kit to your car.
Mitch
MitchB is offline
post #21 of 24 (permalink) Old 11-09-2006, 01:16 PM
92blackbird's Avatar
Send a message via AIM to 92blackbird
That's what I did.
Birdless now
92blackbird is offline
post #22 of 24 (permalink) Old 11-09-2006, 04:16 PM
CMP Drag Racing
post #23 of 24 (permalink) Old 11-09-2006, 04:28 PM
bad93bird's Avatar
QUADSQUAD MEMBER
bad93bird is offline
post #24 of 24 (permalink) Old 11-11-2006, 09:08 AM Thread Starter
about time we seems some install pics
25svo is offline
