Internals - TCCoA Forums
post #1 of 5 (permalink) Old 12-18-2006, 05:55 PM Thread Starter
shaken, not stirred
stangboy7's Avatar
Internals
Now i searched and found that a stock 4.6 birdie engine will handle about 6psi and will eventually die. But what about a mark 8 motor? is the pistons forged in it? how long will it handle the pressure? same thing with a 99-01 cobra engine. I want to get to about 350-400 range.
thanks
C.Hill
'97 Laser Red T-bird w/ Option 66S - 125,000 miles, stock except for 3.73s Best ET 15.6 @ 88.3
'94 Electric Red T-bird LX V-8- 212,000 miles- SOLD
2005 Ebony Black Excursion Limited 6.0 Diesel STUDDED
"Thinking is the hardest work there is, which is the probable reason so few engage in it."
- Henry Ford
"Opportunity is missed by most people because it is dressed in overalls and looks like work."
- Thomas A. Edison
http://www.tailofthedragon.com <---- A test of driving ability and nerves.
stangboy7 is offline
post #2 of 5 (permalink) Old 12-18-2006, 09:56 PM
Carlover007's Avatar
Adding boost to any application will not help durability.
However I heard that block can handle up to 450/500 hp before the connecting rods go.
Here's a good page that you might want to look at:
http://www.svtperformance.com/forums...d.php?t=180943
Edit: I'm running 8 psi on my 4.6 SOHC
Carlover007 is offline
post #3 of 5 (permalink) Old 12-18-2006, 10:06 PM
twin turbo 281's Avatar
the mark 8 bottom end has the same hyperutectic pistons i belive with a 3cc dish? If you strap 2V heads to the mark 8 bottom end you will raise compression which isnt the way you wana go for boosted. 6psi is an ok level on a stock block. As long as it is tuned and fueled properly the stock block can be very durable. If you bolt NPI heads to a PI block you will lower the compression which will alow you to run more boost. 10 psi is about max for a stock block and thats pushing it!
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #4 of 5 (permalink) Old 12-18-2006, 10:52 PM
Mod Motor Cat's Avatar
6psi with a decent tune will last as long as your car will. The stock internals are certainly not ideal for boost, but not that weak. Detonation is the enemy, so as long as you stay a little on the safe side with the timing, you're good to go.
Sure, I've heard of/seen a handful of stock engines going out here and there with higher boost levels, but I'll guarantee you in all cases, it was due to the way it was tuned or previous condition of the engine that pushed it out the door.
Hell.....I know of several 4.6L Mustang guys running around with 9-11psi and 400+hp on the stock short block for years now without even the slightest hiccup. Again, keep the heat under control (conservative fuel and timing curve), maintain your engine and always run good quality fuel and you'll do alright.
~Brian~
*1990 Mustang Coupe, 5.4L*
Black on Black & Stroked 'n' Polked!!!
Mod Motor Cat is offline
post #5 of 5 (permalink) Old 01-14-2007, 01:32 AM
Boost Happy
Jurgen's Avatar
Send a message via AIM to Jurgen
Its mostly in the tune i am running about 8-9 psi it could blow up anytime but its been ok so far CobraRThunder (chris) is running like 11-12psi but i am not sure and hes been running that for a couple of years if you do plan on building a engine run whatever on a stock engine if it blowes up then big deal you are not gone reuse any of thouse parts on a new build.
Jurgen
1994 Ford Thunderbird
2002 Corvette Z06
Yeah I got a few mods.And Some More
http://www.cardomain.com/ride/239875
Jurgen is offline
