Getting ready to do major suspension overhaul - TCCoA Forums
post #1 of 4 (permalink) Old 01-17-2009, 07:41 PM Thread Starter
Black_Cat's Avatar
Ok so the time is coming up here in the next month or so when I do my complete suspension overhaul, here is my parts list, if you see anything else I'm going to need, please add it underneath in a post along with the price, thanks!
- Vogtland 1.6" Drop Lowering Springs all around
- KONI infinately adjustable shocks all around
- New spring cups all around
I am wondering if I need shorter sway bar links now due to the drop? Yes/No??
Thanks!
2011 BMW X5 35i Premium Package
2009 BMW 535i ///M Sport Package
2008 BMW 535i Premium Sport Package
Black_Cat is offline
post #2 of 4 (permalink) Old 01-17-2009, 09:54 PM
Here's the thread for the rear poly spring cups that I told you about. You can see Big Mike still has his stock end links in place.
http://forums.tccoa.com/showthread.php?p=1048560
http://www.laurelmountainmustang.com/6-1709.jpg
The shorter sway bar end links for the rear are, IMO, optional. I used the end links that came with my ADDCO bar. They worked fine and aren't much shorter than the stock end links. I like the way it sits now it has an ever so slight front to rear rake - (where the rear sits slightly higher than the front). Which works well to help the rear fender wells clear the 275 tires.
post #3 of 4 (permalink) Old 01-18-2009, 11:50 AM Thread Starter
Black_Cat's Avatar
Thanks Trunk, good information there!
post #4 of 4 (permalink) Old 01-18-2009, 01:51 PM
Take my advice and order some of the suspension fasteners ahead of time. I would get one set of lower control arm-to-strut mounting hardware, at least one lower control arm front & rear cam adjusting bolt and nut. Only the front nuts are available. Make sure you have a new front upper control arm-to-spindle pinch bolt and nut. Upper arms do not always come with these. You'll need one set per side.
Mitch
MitchB is offline
