Tool sizes - TCCoA Forums
post #1 of 2 (permalink) Old 01-26-2009, 09:12 PM Thread Starter
MN1293-232's Avatar
Tool sizes
Hey all, Iam going to replace my front lower control arm and was wondering what size tools i need to buy.
Front strut rod nuts 30mm wrench I know that
I need the ball joint nut size, the lower shock bolt sizes, and the camber bolt sizes. Since Iam not a mechanic anymore I sold all my tools so i have to ask this stupid question to go buy some. FYI dont do this youll be wishing you still had them Thanks
MN1293-232 is offline
post #2 of 2 (permalink) Old 01-27-2009, 11:48 AM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
im pretty sure its a 24mm nut at the ball joint. camber nut i believe is 21mm. shock bolt, not sure. i want to say its an odd number size. if there's a harbor freight near you, then get a set of these:
http://www.harborfreight.com/cpi/cta...temnumber=7383
i used a 30mm axle socket and a breaker bar for the front strut rod nuts. the flat spot on the strut rod takes a 19mm wrench.
2014 GT
1990 300ZX TT
big mike is offline
