Height Spec. Question - TCCoA Forums
post #1 of 6 (permalink) Old 02-07-2009, 08:21 PM Thread Starter
All of my birds were acquired at high mileage, I'm fairly certain my 97 is sagging but I need some good stock measurements to be sure and to properly guage what springs and shocks to replace them with to get my new desired height.
The measurements I need must be off of a stock ride height thunderbird/cougar with a 4.6L with good shocks and springs, lowered vehicles need not apply, the measurements I need are:
From the center of the rear fender down to the center of the hub.
From the center of the front fender down to the center of the hub.
From the front pinch weld jack point to the ground.
From the rear pinch weld jack point to the ground.
Thank you.
Chris
post #2 of 6 (permalink) Old 02-07-2009, 11:32 PM
The_Ghost's Avatar
I'll let you know once I replace my front struts next week. I'm on SPORT springs though. Alternately I can measure my dad's stock 95 (40k or so) for you.
Would that work?
96 Laser Red 4.6L - Custom
Custom Nascar-Inspired Bodykit - 55* Rear Spoiler - J-modded Trans - 80mm MAF - One-Off Diablosport Chipmaster Revolution Chip/Tune W/Toggle - ScanGaugeII Diagnostics & Data Readout - PBR Brakes - Drilled/Slotted Rotors - SC Wheels & Springs - Falken Tires - KYB GR-1 Shocks/Struts - FSTB - RSTB - RTLB - LECB - 60/40 Split Rear - SC Seats - SC Vac/Boost Gauge
The_Ghost is offline
post #3 of 6 (permalink) Old 02-08-2009, 10:41 PM Thread Starter
After you install the front struts next week and after the springs settle please take measurements for me. For now measurements off of your 40k vehicle will do.
Thanks again Nick,
Chris
post #4 of 6 (permalink) Old 02-09-2009, 12:02 AM
I can get you these specs tomorrow. Just so I'm clear, where are the last two measurement points located?
post #5 of 6 (permalink) Old 02-09-2009, 10:00 AM Thread Starter
also I need measurements from both sides, front and back so there should be a total of 8 measurements.
post #6 of 6 (permalink) Old 02-09-2009, 06:39 PM
From the center of the rear fender down to the center of the hub. 16-9/16"
From the center of the front fender down to the center of the hub. 16"
From the front pinch weld jack point to the ground. 6-1/2"
From the rear pinch weld jack point to the ground. 7-1/2"
