Spring Rust Clean Up? - TCCoA Forums
post #1 of 5 (permalink) Old 02-10-2009, 12:47 AM Thread Starter
winkeytoofly's Avatar
Bought some used lowering Eibach Springs from a NY member, they have a little bit of surface rust here and there not bad really but im wondering what is the best way to clean these up.
winkeytoofly is offline
post #2 of 5 (permalink) Old 02-10-2009, 08:39 AM
wire wheel on a die grinder...then some flat black paint..or pink if you prefer..
post #3 of 5 (permalink) Old 02-10-2009, 10:16 AM
rbrown's Avatar
Also Rust Cure. Works wonders.
rbrown is offline
post #4 of 5 (permalink) Old 03-14-2009, 12:50 AM
white 97 lx's Avatar
Acid tank at work, then a fresh coat of powder . Oh wait that's what I did with mine
white 97 lx is offline
post #5 of 5 (permalink) Old 03-15-2009, 02:17 PM
evaporust..I get it at harborfreight, there may be other places too. Also its non toxic.
tbirdguy is offline
