SC/XR-7 Springs - TCCoA Forums
post #1 of 10 (permalink) Old 02-11-2009, 10:07 AM Thread Starter
mrwiggles2004's Avatar
SC/XR-7 Springs
Are the XR-7 springs the same spec as the Supercoupe? As far as stiffness goes. I'm looking for a set to upgrade the stockers on my 97. I considered buying Eibach's or Vogtland, but from what I hear the SC springs are a good bit stiffer. If the XR-7 Springs are the same that would be perfect as there are quite a bit more cougars than thunderbirds at the local yard. Thanks!
97 Thunderbird LX 4.6L
Current Mods
PI Intake Manifold, Comp XE268's, 180 degree T-stat, Brother's Performance U/D pulleys, K&N filter w custom CAI, 75mm TB and Trick Flow plenum, Borla mufflers w Magnaflow tips, Magnaflow straight cats, Summit 8mm wires, Eibach Pro Kit Springs, Koni Adjustable Front Shocks, Bilstein Cobra Rear Shocks, Cobra R replica rims(17x9)front (17x10.5)rear
mrwiggles2004 is offline
post #2 of 10 (permalink) Old 02-11-2009, 10:31 AM
JR Tigerstar is offline
post #3 of 10 (permalink) Old 02-11-2009, 10:38 AM Thread Starter
That's kind of what I need to know. The only XR-7's I can find at the yard are V8's.
Current Mods
post #4 of 10 (permalink) Old 02-11-2009, 10:40 AM
89-91 XR7s got SC springs. 96/97 tbirds and cougars with the sport option also got the same springs.
post #5 of 10 (permalink) Old 02-11-2009, 10:45 AM Thread Starter
Thanks for that, now I know what to look for.
Current Mods
post #6 of 10 (permalink) Old 02-11-2009, 08:17 PM
Did the 91 XR-7 V8 not have the SC suspension?? I know they had the adjustable shocks and Im sure the springs were the same as the SC. I bet you won't find one of these, but you never know.
post #7 of 10 (permalink) Old 02-11-2009, 09:26 PM
The 91 XR7 did have the exact same suspension as the SC. They aren't that uncommon, its just that most of the ones you find have been beat to snot.
post #8 of 10 (permalink) Old 02-11-2009, 09:51 PM
Everyone ignores the 92 XR7's, those had the SC suspension as well. Those only lost the SC interior goodies before the 93's got the one price fits all crap.
post #9 of 10 (permalink) Old 02-11-2009, 10:30 PM
I didn't know whether the 92s got the SC suspension or not. Then again, I've only ever seen one 92XR7, so they are probably pretty hard to come by.
post #10 of 10 (permalink) Old 02-12-2009, 08:30 PM
The SC cars had sport springs; they are pretty stiff, and need konis to work well.
Spring Code JJJJ on the drivers' side doorjamb label indicates the sport springs.
Here is the info on them...
http://forums.tccoa.com/showpost.php...6&postcount=22
Here is a company that will make springs for you:
http://forums.tccoa.com/showpost.php...0&postcount=16
