Inner Tie Rods - TCCoA Forums
post #1 of 5 (permalink) Old 02-15-2009, 01:37 PM Thread Starter
Inner Tie Rods
I'm having the hardest time trying to remove my inner tie rods from rack and pinion on my 93 Thunderbird SC
How do they come off?
MikeyMike56 is offline
post #2 of 5 (permalink) Old 02-15-2009, 02:01 PM
tbirdtess's Avatar
rivet?
Hello
Did you drill out the rivet? It holds it from turning.
Paul
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #3 of 5 (permalink) Old 02-15-2009, 02:46 PM Thread Starter
I read about the rivet, but I didn't see it. I have a screw instead of a rivet, so I guess their aftermarket tie rods!? I removed the screw and now I'm trying to thread the inner tie rod off... and its not coming off? its not reverse thread!? or is it?!
post #4 of 5 (permalink) Old 02-15-2009, 04:19 PM
The threads are not lefties. Use a big crescent wrench, dont be a pansy and break them loose. The rivet is just aluminum and won't damage anything if you turn the inners off with them in. You could practically crush one of those rivets between your teeth if you tried. Depending upon their position monkeying around with removing them transforms a 15 minute job into a headache. Good luck!
coolhandzep is offline
post #5 of 5 (permalink) Old 02-15-2009, 10:40 PM Thread Starter
I figured it out! It's turns out the screw that I took out broke inside the tie rod still keeping it locked in! So I drilled it out, and finished the job!
tbirdtess and coolhandzep for your help
