Suspension Bracing question - TCCoA Forums
post #1 of 34 (permalink) Old 02-21-2009, 03:18 PM Thread Starter
TwoHaggard's Avatar
i was wondering if any has Rear Torsional Load Brace Photobucket
and the Front Suspension Support Brace from SCP. Photobucket
did u feel a differnce, cornering, launching, wheel hop..?
thx.
Project still in progress
Explorer engine, vortech v2,intercooled,bullit intake,derale power steering cooler, b&m trans cooler, oil filter relocation, cobra aluminum radiator, Walbro 255 Pump, Intrax 2in lowering springs, KYB front/back,,mark8 Driveshaft, 1.25Rear sway bar, 3:73 aluminum diff, TrackLok, Rear Diff Cover Brace, Sc Wheels 235/60s, Jmodd, Air Bags in Springs,Rear strut Bar,17in Mirror Blk CobraRs, Sc L Brackets, rear torsional load brace, kmember-frame brace, weightloss program, pbr dual pistons drilled/slotted, stainless lines , recaro seats, sct x4 DonL tuned
TwoHaggard is offline
post #2 of 34 (permalink) Old 02-23-2009, 01:32 PM Thread Starter
TwoHaggard's Avatar
noone have these?
post #3 of 34 (permalink) Old 02-23-2009, 03:34 PM
SuperNewbie
supergordo's Avatar
One of my fellow Nevada club members has the rear brace and he says he can tell. Another friend of mine has both sets of braces. I haven't spent enough time in the car to really have an opinion on them. I'd think that they are a nice upgrade to our cars. But at this point thats just my speculation.
1995 Cougar XR7 4.6
1997 Thunderbird LX 4.6
1977 Country Squire 460
1985 Capri RS 5.0, 5spd
1997 Thunderbird 4.6
1984 Capri RS 5.0,5spd
supergordo is offline
post #4 of 34 (permalink) Old 02-23-2009, 05:22 PM
I have a torsional load brace on mine, Its a pretty noticable difference through hard acceleration and cornering.
As for the K-member bracing I'd get them from Johnny Langton if he's still making them. His design not only connects the frame rails to the K-member, but they also add strength to the K-member itself.
post #5 of 34 (permalink) Old 02-23-2009, 06:21 PM
Dusty's Avatar
I have them from JL, but they look similar. I also got the rest of his package at the same time, so it is hard to tell which part helped most.
I also got new springs at the same time and it was a different car after all that.
1995 PI Tbird
1998 TA Vert
2004 Buick Regal GS
2000 Honda ST1100
1990 Mazda RX-7 2+2
Dusty is offline
post #6 of 34 (permalink) Old 02-23-2009, 08:37 PM
driller's Avatar
If you start adding parts like that, you'll soon realize how flexible the unibody really was.
driller is offline
post #7 of 34 (permalink) Old 02-23-2009, 08:54 PM
FordFanatic's Avatar
just adding jl's sub frame connectors was a huge, noticeable difference. you can really tell that the suspension and not the body is taking the beating from the road.
FordFanatic is offline
post #8 of 34 (permalink) Old 02-23-2009, 09:05 PM
white 97 lx's Avatar
I have both of them, the FSSB really hepled the front end soak up the bumps, now I just need to weld the bracket on for my LECB. The torsional load brace? Well it's hard to say how much of a difference it made, I already had the rear shock tower brace but I didn't really notice any big improvements when I put the torsional load brace on. Maybe I just didn't run the car hard enough in the twisties! That's gonna change though since I'm redoing my suspension here very shortly.
white 97 lx is offline
post #9 of 34 (permalink) Old 02-24-2009, 01:25 PM Thread Starter
TwoHaggard's Avatar
ok cool. so they seem like a pretty good upgrade. there bolt on so not hard to install eather so when i find an extra dollar i think im going to get them both. anyone know about how much they weight?
post #10 of 34 (permalink) Old 02-24-2009, 01:33 PM
95_SilverBird's Avatar
I noticed a huge difference with both, but the RTLB comes in 2 styles. one hangs down way to low and i managed to bottom out and crack it.
Eibach 1.5" Lower Springs, Koni Adjustable Shocks, SCP IRS Brace, SCP Lower Engine Cradle Brace, Mark VIII LCAs
Chuck's Poly Motor Mounts, 13" PBR Front and Cobra rear brakes, 245-45-18 ADR Kasai Wheels, RichardM Intake Tube
Super Coupe leather seats and console, Pioneer Head, Audison Amps, Boston SL Components, 10" Boston G5 subs, Reverse Glow EL Gauges, Super Coupe Ground Effects, '96 Hood and Headlights, Custom paint: Tungsten Silver, PI Intake, 4000 stall
95_SilverBird is offline
post #11 of 34 (permalink) Old 02-24-2009, 02:47 PM
I have 4 braces in my car currently and installed each of them at different times, I have a rear torsional load brace, rear shock tower brace, sc L braces, and a custom V-brace, the rear torsional load brace was noticeable most durring dips, and twistys, I definatly noticed a difference, the rear shock tower brace I installed helped mainly in twistys, and sc L braces and custom V-brace seemed to help most in unibody flex, I've gone from oversteer to understeer, my next investment will be lecb, fssb, and a fstb.
post #12 of 34 (permalink) Old 02-25-2009, 12:52 AM Thread Starter
TwoHaggard's Avatar
sounds all good. iv never hurd of the sc L braces? where they at on the scs? got pictures?
post #13 of 34 (permalink) Old 02-25-2009, 01:19 AM
They can be found on fold down seat SC's. They bolt to where the seat back does and 2 studs in the middle.
post #14 of 34 (permalink) Old 02-25-2009, 07:35 AM Thread Starter
TwoHaggard's Avatar
do u have to modify your vbrace to make them work?
post #15 of 34 (permalink) Old 02-25-2009, 01:50 PM
I didnt have to modify mine at all. I just used longer bolts and was able to bolt it on.
post #16 of 34 (permalink) Old 02-25-2009, 09:31 PM
I originally used the stock v-brace with the L-braces, the only modification that needs to be made is if you are using fold down seats and that is at the point of the V, it needs to have a hole drilled to bolt the center of it between the two lower bolts to mount the seat frame to the body otherwise the stock bolts are long enough it just takes a lot of patience to get them to thread into both threaded bosses.
post #17 of 34 (permalink) Old 02-26-2009, 07:31 AM Thread Starter
TwoHaggard's Avatar
oh i understand. im not planing on fold down seats. so im going to have to look into gettin some sc L-Braces now!!
post #18 of 34 (permalink) Old 05-07-2010, 02:14 PM
tbirdtess's Avatar
Drop?
Hello
So why is there a drop to the lower rear brace?
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #19 of 34 (permalink) Old 05-07-2010, 02:26 PM
To clear the exhaust and the rear punkin it appears
post #20 of 34 (permalink) Old 05-08-2010, 12:30 PM
tbirdtess's Avatar
Hi
was just under my car. I see the drop is to clear the rear pumpkin mount.
What if the brace was mounted 90* to the picture? I think it would do more.
(flat to the rear)
note: I have no exhaust pipes to the rear of my car.
351W 2bbl.
C-4 Auto
3.90 open rear
post #21 of 34 (permalink) Old 05-16-2010, 07:33 AM
High-Mileage 4.6L Thrasher
Johnny Langton's Avatar
Originally Posted by tbirdtess View Post
Hi
(flat to the rear)
You mean like this?
Works well, clears most everything(except stock exhaust), and get max ground clearance.
JL
Fuelly
Johnny Langton is offline
post #22 of 34 (permalink) Old 05-16-2010, 09:02 AM
95xbird's Avatar
JL. Thats what I need, My exhaust is alittle to low for the SCP ones. You make that? And if you did are you making more?
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #23 of 34 (permalink) Old 05-16-2010, 12:09 PM
I'd be interested in a set of braces when you make some more, JL.
Grog6 is online now
post #24 of 34 (permalink) Old 05-16-2010, 03:28 PM
GRNDPNDR's Avatar
I've been welding up a set of these for my car as well. Custom exhaust needs to be taken into account, but stock exhaust will fit the SCP looking brace no problem.
I have an extra RTLB if anyone wants it. It will clear stock exhaust.
I'll make a set for anyone interested, but I'm not going to bother if it's just a passing interest.
I'm making my own beause I don't like SCP's prices, but I'm also trying to engineer a better design for some of them.
Rest In Peace Mom.
GRNDPNDR is offline
post #25 of 34 (permalink) Old 05-17-2010, 12:58 PM
Yes, we did make that one. We're not making any more as of this moment,but that doesn't mean we're not gonna make some int he near future. There's a house that needs completed,and some remodel work on mine that needs done before I commit to any other projects..
JL
Fuelly
post #26 of 34 (permalink) Old 05-17-2010, 04:50 PM
95xbird's Avatar
No problem. Seeing how I wont be able to find any to fit anytime soon I'll wait you out. Besides im in no real rush to hunt for one. When ever you do make them again just let me know.
Its slow, Really.
LS1 KILLER
95xbird is offline
post #27 of 34 (permalink) Old 05-17-2010, 07:37 PM
Same here JL will take one as well, Be nice to have a SS one
post #28 of 34 (permalink) Old 05-20-2010, 10:23 PM
tbirdtess's Avatar
Originally Posted by Johnny Langton View Post
You mean like this?
JL
Did you notice a big difference?
Not exactly as shown in the pictures.
Flat side to the rear.
(Note I have No exhaust past the rear seat area.)
351W 2bbl.
C-4 Auto
3.90 open rear
post #29 of 34 (permalink) Old 05-21-2010, 06:55 AM
No exactly as shown in the pictures.
It does make a big difference. I was surprised at how much flex that area has-even on a stock car.
JL
Fuelly
post #30 of 34 (permalink) Old 05-21-2010, 08:35 AM
I'm wondering if this piece would even have an effect on my car...
