Replacement of rear springs.. - TCCoA Forums
post #1 of 20 (permalink) Old 02-27-2009, 08:50 AM Thread Starter
CometGSR's Avatar
Hey guys, I am replacing my rear springs with Moog Cargo Coils tonight. My buddy was looking over the procedure that is detailled with the Ford HELMS and noticed that we may have to compress the springs to get them out? There isn't a lot of room to do this with typical compressors, at least from what I can see..
Well, I was looking at the rear spring replacement procedure on the Ford
CD's last night, and it looks like they managed to make it about as
difficult as conceivable for a RWD! Apparently, we still need to
"compress" the springs to get them in and out, and there's even a
possibility you'll need a REAR wheel alignment afterward...We'll have to
see just what we're up against. I packed my spring compressors, but
they're much different than what is shown in the procedure, so I'm not
sure if they'll fit where they need to. We'll have to play that by ear.
If necessary, I could always fabricate something later on at my place or
we could check if the Murray can loan out the right tools.
Any advice? Will typical compressors work?
Thanks!
-=James
1995 Ford Thunderbird V8
SCT Tuned by Amercian Motorsport, Mustang PBR, FRPP 3.73 gears, Modified Trak-Lok, Steeda UDP, K&N Panel, 1990 SC Seats, 2.5" Single Exhaust/Magnaflow Hi-Flow Cats, Michelin Pilot Sport A/S +, Windstar wheels, RichardM Intake, Kenwood KDC-HD552U HD Radio, 2800 stall DirtyDog Marauder TC, J-MOD, 2002 Grand Marquis transmission, DynoTech Driveshaft, AeroForce Interceptor Scan Gauge, Griffin Super High Capacity Radiator, 180* Thermostat, Cobra steering wheel, 6000K HID, Clear Corners Getting a makeover Spring 2015
http://www.fordthunderbird.net - For Pics and more!
CometGSR is offline
post #2 of 20 (permalink) Old 02-27-2009, 09:54 AM
I don't remeber using any compressor on the rear....they practiallcy fall out once everything is unbolted.
post #3 of 20 (permalink) Old 02-27-2009, 10:00 AM
I 2nd that, are the new ones lowering springs?The problems I faced when I did my springs back in 1997 I replaced them with stock springs. I had to work to get them in. But lowering springs should be a breeze
2011 Kia Sorrento
1996 T-bird
*SOLD* 2007 Suzuki M50
Looking for a new ride!
funderbird is offline
post #4 of 20 (permalink) Old 02-27-2009, 10:35 AM
IIRC the tech article has you kick the lower control arm, and sure enough, after a few attempts at doing that my springs just fell out!
Bangster is offline
post #5 of 20 (permalink) Old 02-27-2009, 10:49 AM Thread Starter
CometGSR's Avatar
If anything, the Cargo Coils might be a little bit taller or they may be the same as stock.
Do you find it difficult to get the new ones in?
-=James
CometGSR is offline
post #6 of 20 (permalink) Old 02-27-2009, 12:06 PM
cmill95's Avatar
well, you could always just put your spring compressers on after removing the wheel and pumping the jack a few times. then when you lower the a-arm down the 1 or 2"s to disassemble the stuff thats in the way it should come right out. no muss, no fuss.
cmill95 is offline
post #7 of 20 (permalink) Old 02-27-2009, 12:26 PM
dDUBb's Avatar
Taking the springs out is a little easier than putting them back in.
dDUBb is offline
post #8 of 20 (permalink) Old 02-27-2009, 01:01 PM Thread Starter
CometGSR's Avatar
Thanks guys! Hopefully things will go well tonight. I am replacing the chassis bracket too, I found some NOS ones. Mine are completely rusted out!
-=James
CometGSR is offline
post #9 of 20 (permalink) Old 03-10-2009, 09:59 AM
No it wasn't too bad, I had a buddy and a shop guy hepling me get them in and it wnet easy.
2011 Kia Sorrento
1996 T-bird
post #10 of 20 (permalink) Old 03-10-2009, 02:31 PM
twin turbo 281's Avatar
i used a ton of coat hanger wire to mildly compress the rears to ge the springs out to make life simpler. Just make sure to use long cutters when releasing the spring tension
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #11 of 20 (permalink) Old 03-10-2009, 02:45 PM
TT281,
you first wrap the springs under load then when you take load off the spring they are semi compressed? That would make life easier...
2011 Kia Sorrento
1996 T-bird
post #12 of 20 (permalink) Old 03-10-2009, 02:49 PM
thats what I did and then you let the arm fall out and easily pull the spring out. just like using a standard compressor however its a poor mans way of compressing the springs not to mention aropund here its hard to find the correct band type of compressors needed for the rear springs
post #13 of 20 (permalink) Old 03-10-2009, 02:55 PM
Makes sense, that the way I am going to do it next time, would bailing wire be better?
2011 Kia Sorrento
1996 T-bird
post #14 of 20 (permalink) Old 03-10-2009, 02:59 PM
it can be dangerous to do it like that...just be careful.
post #15 of 20 (permalink) Old 03-10-2009, 03:07 PM
Roger that be careful!
Funny story, I was swaping rear springs on a mustang I think. We couldn't get them out (cuz rust and all) the shop guy at the hobby shop got a 6 ft pry bar and started to press out ward on the spring. While the otherr shop guy pried down ward. I was just standing back, when that spring came out it flew the lenght of the hobby shop and imprinted on the steel wall. From then on I decided that I wouldn't do it, that way! I have had to "rent" (buy then return) spring compressors in the past for my other vehicals and the ones they have are never the right ones. So TT281's idea sounded doable.
2011 Kia Sorrento
1996 T-bird
post #16 of 20 (permalink) Old 03-10-2009, 03:10 PM
yes we took extreme care i rapped many links of wire aroudn the springs and carefully removed them then threw them in the grass and cut the wire with long handled cutters. This is how i do the springs but I dont recomend it for saftey reasons.
post #17 of 20 (permalink) Old 03-10-2009, 03:33 PM
I wrap a big blanket around mine when doing it like that.....
post #18 of 20 (permalink) Old 03-10-2009, 04:17 PM
nice
2011 Kia Sorrento
1996 T-bird
post #19 of 20 (permalink) Old 03-10-2009, 09:15 PM
You guys Are Not Invited to my place for suspension work.
Baling wire on a spring qualifies for a Darwin award, if you fail.
Maybe it's just me, but I ain't going out like that.
YMMV, but you've been warned, lol.
I'm not afraid of risk; I used a pair of spring compressors to put on a set of sport springs; that's fairly dangerous, in my book... But no baling wire.
post #20 of 20 (permalink) Old 03-11-2009, 04:12 PM
I used 1 macpherson strut compressor and romex wire to get my rear springs out.
