So the suspension seems to be shot - TCCoA Forums
post #1 of 5 (permalink) Old 03-03-2009, 08:35 PM Thread Starter
johnnyx's Avatar
Question So the suspension seems to be shot
Hey guys,
I've been driving my '95 Bird for a while now with some major squaking and rattling coming from the front passanger side tire area. My guess is that the whole front suspension seems to be shot. The wheel also seems to shake a lot as I drive every once in a while. I saw someone mentioned on the forum that replacing the lower ball joints should fix the problem.
If I wanted to replace the whole front suspension and give it a more sporty ride / stiff ride, what would you guys recommend performance part wise?
I was quoted about $500 bucks for parts and service from one of local shops with standard Ford parts.
Thank you in advance for any advice.
Best regards,
JX
johnnyx is offline
post #2 of 5 (permalink) Old 03-03-2009, 10:17 PM
Check out this thread; it will refer you to another thread, which points out the original thread, which should be a sticky.
post #3 of 5 (permalink) Old 03-04-2009, 05:36 PM
white 97 lx's Avatar
Where's the link?
white 97 lx is offline
post #4 of 5 (permalink) Old 03-05-2009, 07:02 PM Thread Starter
johnnyx's Avatar
Which link mate?
johnnyx is offline
post #5 of 5 (permalink) Old 03-05-2009, 10:15 PM
That was a subtle hint to Use Too subtle, I guess.
Here's the link; It's on the next page of this forum...
http://forums.tccoa.com/showthread.php?t=118050
