Dropping/removing rear suspension from a '90 SC? - TCCoA Forums
post #1 of 3 (permalink) Old 03-07-2009, 06:58 PM Thread Starter
Hi there!
Dad's got a 1990 SC with a flaked motor (rod knock or something) that he's been parting out, and it's about time to take it to the wrecking yard.
He's got a wild hair about pulling the rear end out of the thing to use in a street rod project, and we're looking for the easiest way to go about this.
Is there any write-up or how-to on this, or can anyone give us some easy instructions?
kythri is offline
post #2 of 3 (permalink) Old 03-07-2009, 10:06 PM
tbirdtess's Avatar
tech
Hello
Check out the tech articles.
You will need to unbolt:
drive shaft
brake lines. including parking & ABS wires.
upper shock mounts
4 corner bolts.
Rest is a single unit. this is what makes it a good unit to swap.
Paul
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #3 of 3 (permalink) Old 03-08-2009, 09:01 AM Thread Starter
Thanks!!
kythri is offline
