Mark 8 LCA's on a Bird - TCCoA Forums
 2Likes
  • 1 Post By Traveler
  • 1 Post By coggonobrien
post #1 of 29 (permalink) Old 03-13-2009, 11:47 PM Thread Starter
R8D-XXX's Avatar
So I've read that people on the board are doing this but I havn't really been able to get a good idea of why. I've only seen bits and pieces of what people have written.
Can someone explain in better detail of why you would put Mark 8 LCA's on a bird? I've got a junk 93' Mark 8 out on my dads property with the rear LCA's just hanging there by a couple of bolts and was wondering if I should do anything with them. Especially since my car is coming apart for a gear change this weekend.
pics of my car
Updated 10/14/11
13.0 @ 106.5 1.79 60ft
R8D-XXX is offline
post #2 of 29 (permalink) Old 03-13-2009, 11:54 PM
ClintD's Avatar
they are aluminum and lighter
ClintD is offline
post #3 of 29 (permalink) Old 03-13-2009, 11:54 PM
Traveler's Avatar
Well, if its a 93 the first thing you should do is yank that 93 driveshaft if its still there... (one-piece aluminum)
Now, the LCA's.. the Marks all had aluminum lower control arms instead of steel. Much lighter. and since they are unsprung, they have a greater effect on handling. To use them you will need to get a set of adapters (available here on the forums from... damn.. forgot the name, do a search). The Marks had airbag suspension and your bird has good ol' fashioned springs. The perches allow you to use springs with the mark LCA's. I'd LOVE to have a free set of Mark LCA's just sitting there! snag em!
Oh yea... the Mark's have aluminum cases for the diff center sections to... keep that.
CDsDontBurn likes this.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #4 of 29 (permalink) Old 03-14-2009, 12:05 AM Thread Starter
R8D-XXX's Avatar
I have already robbed the DS and the rear end....thanks for looking out though.
but back to the LCA's......so I need some sort of adaptors? This is the first I've heard of this. I thought they were a direct bolt on.
pics of my car
Updated 10/14/11
R8D-XXX is offline
post #5 of 29 (permalink) Old 03-14-2009, 12:12 AM
Traveler's Avatar
Yes, they fit in the circles where the airbags normally go. they provide a perch for the springs. I'll do a search if you do.. one of us should find them.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #6 of 29 (permalink) Old 03-14-2009, 12:30 AM Thread Starter
R8D-XXX's Avatar
Well I didn't see any pics of these perches but I have a good idea now of what you need from searching and reading a couple of threads.
I'll probably just end up shining this little idea on. Since I am running the air bag kit in my springs now, I definitly need the perches on my birds stock LCA's.
pics of my car
Updated 10/14/11
R8D-XXX is offline
post #7 of 29 (permalink) Old 03-14-2009, 12:31 AM
post #8 of 29 (permalink) Old 03-14-2009, 12:37 AM Thread Starter
R8D-XXX's Avatar
Now I see, thanks Racecougar!!
pics of my car
Updated 10/14/11
R8D-XXX is offline
post #9 of 29 (permalink) Old 03-14-2009, 12:38 AM
Traveler's Avatar
Thats them!!
You shouldn't need the perches for the airbag kit on your stock LCA's... I'd think the kit would be made to work with the stock LCA's.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #10 of 29 (permalink) Old 03-14-2009, 12:47 AM Thread Starter
R8D-XXX's Avatar
Thats them!!
Yes they do. I didn't mean that I need the aftermarket perches.
Meant that I need to keep the stock LCA's for my airbags. I was just calling what my air bags are sitting on now "perches" Sorry I was fuzzy on that.
pics of my car
Updated 10/14/11
R8D-XXX is offline
post #11 of 29 (permalink) Old 04-09-2009, 12:34 AM
DLF
DLF's Avatar
Or you could switch to the Mark VIII LCA's, and get sping perches that would allow your AirLift airbags to work like they do now. And save about 6 lbs. of unsprung weight per side.
http://www.sccoa.com/forums/showthread.php?t=105981
My Web Site
DLF is offline
post #12 of 29 (permalink) Old 04-09-2009, 06:28 AM
The Airlift airbags work just fine with the perches if you're lowered 1" or more.
That's the best picture that I have at the moment, but the airbag is in contact with both the upper and lower perches.
post #13 of 29 (permalink) Old 04-09-2009, 04:09 PM
What about the hubs... they are ally too....
kustomizingkid is offline
post #14 of 29 (permalink) Old 04-22-2009, 11:31 PM
96tbirdboi's Avatar
im buying some mark 8 lcas where can i get these perches and what bushings do i go with mark 8 control bushings r mn12 bushings?????? should i get the mark 8 driveshaft or should i go elsewhere on my driveshaft,planning to get 3 73 gears
1996 ford Thunderbird LX 4.6L 2V [email protected]
PI Swap(heads/intake)
Comp 262 cams
Sport springs
True dual exhaust(Magnaflow cats/Mufflers
Steeda UDPs
Trick flow tb/plenum
96tbirdboi is offline
post #15 of 29 (permalink) Old 04-22-2009, 11:36 PM
MikeyB's Avatar
Go with a mark 8 shaft
95 Cougar XR-7
Sold it...
96 Thunderbird LX
Sold it...
MikeyB is offline
post #16 of 29 (permalink) Old 04-22-2009, 11:38 PM
96tbirdboi's Avatar
yeah and what do i need to get the lcas installed
Comp 262 cams
Sport springs
Steeda UDPs
post #17 of 29 (permalink) Old 12-05-2016, 07:59 AM
coggonobrien's Avatar
bringing back an old thread but does anybody have dimensions on the perches? I'd like to make my own.
coggonobrien is offline
post #18 of 29 (permalink) Old 12-05-2016, 11:10 AM
Thunderstruck95's Avatar
While the perches are the preferred way to put coils in the Mark VIII LCAs, they are not required. Many of the after market coil spring conversions sold for Mark VIIIs do not include the centering perches for the LCAs.
I did a coil conversion on one of my Marks and did not use the perches, and I did not experience any noise/ shifting issues.
1995 T-Bird.
PI 4.6. Bullitt intake. Stage 2 MHS cams. Kooks Headers. 4,200 ATF Speed converter. BCA Transmission. 4:10s. Tune by Supercoupes Unlimited. 245 RWHP.
3,700 lbs at half tank. Goal- 3,400 lbs
Best of 13.85 at 96 mph. Goal- 11's NA
1997 Lincoln Mark VIII FX2 Sand Dune Machine- R.I.P.
Thunderstruck95 is offline
post #19 of 29 (permalink) Old 12-05-2016, 11:12 AM
I'm going to throw the control arms in my tbird eventually.
post #20 of 29 (permalink) Old 12-05-2016, 05:25 PM
I went poly at the same time:
This is the thread about the poly bushings:
http://forums.tccoa.com/44-suspensio...-bushings.html
If you haven't seen it, this is a good thread for the overall suspension:
http://forums.tccoa.com/44-suspensio...n-rebuild.html
post #21 of 29 (permalink) Old 12-05-2016, 05:34 PM
I don't think they're necessary unless the car isn't sitting level without(usually solved by the somewhat thicker poly isolators) or you plan to use assist airbags.
post #22 of 29 (permalink) Old 12-05-2016, 05:48 PM
My "Perches" don't add any metal under the spring; only the rubber is between the spring and arm.
I did file of the sharp edges of the spring, lol.
They just keep the springs centered; they walked about a bit without them.
post #23 of 29 (permalink) Old 12-06-2016, 06:37 PM
I drew them up in CAD a LONG time ago. If you need the file, I'll have to look for it.
I wouldn't run without some means of locating the spring in the pocket.
post #24 of 29 (permalink) Old 12-07-2016, 07:19 AM
Rod, if you can find it I will take it. I've got plenty of mfg capabilities to make a pair from stainless
post #25 of 29 (permalink) Old 12-07-2016, 09:12 AM
I'm all for trick parts, but why pick stainless over aluminum?
1995 T-Bird.
post #26 of 29 (permalink) Old 12-07-2016, 09:51 AM
we don't work in aluminum here at work but have a laser that will cut 1" thick stainless clean
post #27 of 29 (permalink) Old 12-07-2016, 03:59 PM
Stainless rusts aluminum badly; I was worried about using a steel bolt.
Aluminum bolts won't work, lol.
post #28 of 29 (permalink) Old 12-08-2016, 07:04 AM
gotcha, guess we can make it out of aluminium then.
post #29 of 29 (permalink) Old 12-11-2016, 05:02 PM
Found the file. If you shoot me an email at [email protected], I'll send it over to you.
