Clunking sounds from front end..... - TCCoA Forums
post #1 of 9 (permalink) Old 03-20-2009, 02:16 AM Thread Starter
Slowride's Avatar
Send a message via Yahoo to Slowride
On my '89 T-Bird SC, when I'm going foward and turning sharply either direction, I'm getting a "clunk" noise from the front end. I've replaced the radious arm bushings at the lower control arm, upper and lower ball joints on both sides and also put a set of Vogtland springs ( 3/4" drop) on as well.....all was done back in October of '08 and it's been doing it ever since. At first I thought it was the springs and front end settling but everything should be "good" by now.
Had the front jacked up last week trying to figure it out and inspect other parts like the tie rod ends and what have ya. Even turned the wheel all the way both directions and all I got was a slight clunk when the wheels were turned all the way over in both directions, but it was nothing like the clunk I get when she's on the ground and moving foward and turned almost all the way----in either direction.
Oh, and when she is turned almost all the way, she feels like she's pushing.
So I'm not sure what it could be......bushing bind up, something in the rack and pinion, something with the springs or new bushings, or what. Any ideas guys??
Thanks.
Slowride
The early bird may get the worm, but the second mouse gets the cheese!!!
Slowride is offline
post #2 of 9 (permalink) Old 03-22-2009, 06:46 PM
frankjc's Avatar
Send a message via Yahoo to frankjc
Could be a number of things. I would recommend reading the sticky at the top of the suspension forum, if you haven't already.
Drive it like you stole it!
frankjc is offline
post #3 of 9 (permalink) Old 03-25-2009, 06:33 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
Originally Posted by Rayo View Post
Had the same problem on mine.check and make sure all the nuts and bolts are tight on the parts that attach your suspension to your body..Good luck..
X2 buddy, this has happened to me on my own car(my 92 cougar too) and some customers' cars
-Rob
-Rob
Rob is offline
post #4 of 9 (permalink) Old 03-25-2009, 08:36 PM
Thanks.
Slowride
hey check the stabilizer bar links. If the rubber is torn replace them.
tbirdguy is offline
post #5 of 9 (permalink) Old 03-26-2009, 01:48 AM
Read the stickies. They're there for a reason.
post #6 of 9 (permalink) Old 03-29-2009, 04:00 PM
clunk
I had a pritty bad clunking/clatter and i grabed the upper control arm and made the noise!Just tightened up and went away!Not saying thats your problem but worth a try!
scoot93t-bird is offline
post #7 of 9 (permalink) Old 03-30-2009, 01:23 AM
SuperNewbie
supergordo's Avatar
Check the anti sway bar endlinks..
1995 Cougar XR7 4.6
1997 Thunderbird LX 4.6
1977 Country Squire 460
1985 Capri RS 5.0, 5spd
1997 Thunderbird 4.6
1984 Capri RS 5.0,5spd
supergordo is offline
post #8 of 9 (permalink) Old 04-04-2009, 03:42 AM
d00mbuggy's Avatar
supergordo, you hit it right on the money. I know that sound. When I went in for an oil change, I had the mechanics move my front end from side to side, making that clunking sound, while one was underneath the car trying to find the source of it. Turns out, it was the sway bar connecting links. They replaced them for about $200 total for both sides, clunking gone, and the car handles WAY bettter. Well worth the $200.
d00mbuggy is offline
post #9 of 9 (permalink) Old 04-08-2009, 12:39 AM Thread Starter
Slowride's Avatar
I'll recheck everything and go from there. It does kinda sound like the pivot bolts may be loose....I'll check.
Thanks !
Slowride is offline
