Over Torqued UCA ??? - TCCoA Forums
post #1 of 4 (permalink) Old 03-27-2009, 11:47 PM Thread Starter
winkeytoofly's Avatar
Ok a while back i replaced my UCA with Moog and my struts and springs. Well get a nice loud POP everyone now and then either while taking a corner or turning left. I had tightened them down pretty good, is it possible that I tightened them down a little to much and now the bushings pop or what?
94 3.8 T-Bird Cardomain Sold to the junkman
1997 4.6L T-bird Laser Red HALO Headlight Conversion, Silencer Removed, Lowered Eibach 1 1/2inches, Bilstein Shocks, ART Catless Downtubes, Mandrel bent 2.5 Exhaust, Borla Mufflers, Mrk8 8.8 TL 3.73, 18x9 Black Saleens, BFGoodrich GForce Sport Comp-2 245/45/R18
2004 F-150 Single Cab 4.6
winkeytoofly is offline
post #2 of 4 (permalink) Old 03-28-2009, 12:29 AM
tbirdbrain's Avatar
A problem can occur while tightening suspension components during the time the suspension is in a fully extended position. This causes a preload condition which can cause unnecessary wear and diminished bushing life (and other issues including popping). All suspension adjustments and tightening sequences have to occur while the components are at established ride height. (normally done by using a jack)
tbirdbrain is offline
post #3 of 4 (permalink) Old 03-28-2009, 08:46 AM Thread Starter
I didnt use the jack i dropped her to the floor and tightened the bolts down.
post #4 of 4 (permalink) Old 03-30-2009, 03:41 PM
CrystalPistol's Avatar
Then you did it exactly right, so likely that's not your popping. You can still loosen and retighten the 4 bolts easy enough as suggested above.
Look at lower control arm bushing ... lower ball joints ... strut rods bushings ... front subframe to body bolts ... steering rack mounts.
CrystalPistol is offline
