ABS senser? - TCCoA Forums
post #1 of 10 (permalink) Old 04-01-2009, 09:35 PM Thread Starter
TwoHaggard's Avatar
ABS senser?
im taking my front knuckle off my car. the senser going into that is it a Abs senser? or wheel speed? cuz i cant get mine out an i turned it with channel locks an i think it may have snaped. can someone give me some info or pics please.
Project still in progress
Explorer engine, vortech v2,intercooled,bullit intake,derale power steering cooler, b&m trans cooler, oil filter relocation, cobra aluminum radiator, Walbro 255 Pump, Intrax 2in lowering springs, KYB front/back,,mark8 Driveshaft, 1.25Rear sway bar, 3:73 aluminum diff, TrackLok, Rear Diff Cover Brace, Sc Wheels 235/60s, Jmodd, Air Bags in Springs,Rear strut Bar,17in Mirror Blk CobraRs, Sc L Brackets, rear torsional load brace, kmember-frame brace, weightloss program, pbr dual pistons drilled/slotted, stainless lines , recaro seats, sct x4 DonL tuned
TwoHaggard is offline
post #2 of 10 (permalink) Old 04-01-2009, 09:41 PM
Mister_T's Avatar
It's an ABS sensor, and I'm wondering the same basic thing... how do you remove one? I turned mine with a set of vice grips assuming they twist and then pop out but it didn't help. I got the bolt out that hold it in place but it won't pull out.
Be careful is the only advice I do have though. Autozone sells these for $120. Since mine is broke, it's junkyard time for me.
I'm Mister_T and I approve this message.
Mister_T is offline
post #3 of 10 (permalink) Old 04-01-2009, 09:48 PM
byrd_of_thunder's Avatar
Send a message via AIM to byrd_of_thunder Send a message via MSN to byrd_of_thunder Send a message via Yahoo to byrd_of_thunder
there are no speed sensors on the wheels. it's an ABS sensor. if you broke it your ABS light will come on until you get it fixed and it's a good bet the rest of your system won't work right until you get it fixed.
Nick
Byrd_of_Thunder
2012 Ford Focus SE Hatchback
**1997 Ford Thunderbird LX - RIP**
byrd_of_thunder is offline
post #4 of 10 (permalink) Old 04-01-2009, 10:58 PM Thread Starter
TwoHaggard's Avatar
ya, so is the hole rod come out too? is it all one peice? if so. mines pretty froze.
post #5 of 10 (permalink) Old 04-02-2009, 10:08 AM
R8D-XXX's Avatar
IMO, I don't think there is a way to get them out w/o destroying them. Over time, they get siezed in there.
pics of my car
Updated 10/14/11
13.0 @ 106.5 1.79 60ft
R8D-XXX is offline
post #6 of 10 (permalink) Old 04-02-2009, 12:03 PM
i don't have a picture of the knuckle in my head right now so i can't say if there is a way to get them out without breaking them like R8D-XXX said, but my advice, if they are able to be taken out use LOTS of PB Blaster and brake cleaner. if that doesn't work maybe it just isn't meant to be.
Nick
Byrd_of_Thunder
post #7 of 10 (permalink) Old 04-02-2009, 12:12 PM Thread Starter
TwoHaggard's Avatar
ya its alrdy broke so it doesnt matter how i get it out.
post #8 of 10 (permalink) Old 03-20-2012, 08:43 PM Thread Starter
TwoHaggard's Avatar
bringing this back from the dead since i did never get around to fixing this, any way it could be pressed out? or anyone have input. thanks
post #9 of 10 (permalink) Old 04-10-2013, 05:31 PM Thread Starter
TwoHaggard's Avatar
Anyone ? Should I just go get a knuckle from the junkyard?
post #10 of 10 (permalink) Old 04-10-2013, 10:41 PM
Lots of pb blaster, a flat blade screw driver and a hammer worked for me. You just need to gradually chisel around the base of the sensor and spindle until it's loose.
