Help in removing the TieRods - TCCoA Forums
post #1 of 12 (permalink) Old 04-01-2009, 11:14 PM Thread Starter
hello all, can someone do a short write up on how to remove the inner tie rod.
i am replacing both the inner and outer TR.
thank you much
Tbird Rider is offline
post #2 of 12 (permalink) Old 04-02-2009, 12:17 PM Thread Starter
anyone????
post #3 of 12 (permalink) Old 04-02-2009, 11:38 PM
This has previously been pretty well covered. Do a search for "inner tierod" If you seperate "tie rod" you get bogus results.
a black car.
Sophosis is offline
post #4 of 12 (permalink) Old 04-03-2009, 02:35 AM
The Band, not the Disease!
AnthraxBird's Avatar
Here ya go:
http://forums.tccoa.com/showthread.p...t=inner+tierod
It could also be your steering rack... try replacing the inners and outers (both are pretty cheap) an then take it to the shop to get it aligned. It's impossible to align a car with those parts bad.
AnthraxBird is offline
post #5 of 12 (permalink) Old 04-03-2009, 09:44 AM Thread Starter
thank you for the replies....and sorry i did forget to use the search funtion.
i am replacing the outer & inner, the UCA & the LCA and the sway bar link. Once all this is done, definitely needs an alignment.
post #6 of 12 (permalink) Old 04-03-2009, 01:25 PM
Just mark where it's aligned at with a sharpie marker, then get it as close as possible, then have it aligned. =)
post #7 of 12 (permalink) Old 04-03-2009, 04:25 PM Thread Starter
btw....is the boot full of PS fluid that will shower me once i pull the boot? =)
post #8 of 12 (permalink) Old 04-03-2009, 05:21 PM
Nope
post #9 of 12 (permalink) Old 04-03-2009, 09:16 PM Thread Starter
oh no!!!! there is a rivet insert in there.
i was able to remove the boot and saw a rivet insert
how do i remove it? and what size wrench do i need for that inner tie rod?
thanks again
post #10 of 12 (permalink) Old 04-03-2009, 09:22 PM
You can generally bust them loose and break the rivet right off, they are very weak.
post #11 of 12 (permalink) Old 04-04-2009, 01:40 AM
+1 Forget you saw the rivet and spin it right off with a big crescent wrench. The rivet is aluminum and won't damage the threads at all.
coolhandzep is offline
post #12 of 12 (permalink) Old 04-04-2009, 04:22 AM
Originally Posted by AnthraxBird View Post
Just click the post...
