Rear bushings bad?? - TCCoA Forums
post #1 of 2 (permalink) Old 04-02-2009, 09:40 PM Thread Starter
Rear bushings bad??
First off I must say that I did read the sticky about suspension noise.
Recently I replaced all four shocks on the car, which included both front struts. When I did that work I also replaced the right upper control arm because the ball joint was shot. Anyway, to the point. I suspect some bushings (or something else) may need replacing for the rear suspension setup; when I go over bumps I can hear a faint noise that reminds me of the sound bad ball joints make coming from the left rear tire area. When I flushed the brake lines I checked the bushings back there and from what I could tell they generally seemed intact... Would that noise be coming from anything else? If not, what's the best way to determine if the bushings need replacing?
post #2 of 2 (permalink) Old 04-02-2009, 10:10 PM
The Band, not the Disease!
AnthraxBird's Avatar
Axles, rear diff. bushings, trans mount?
AnthraxBird is offline
