Rear hub removal - TCCoA Forums
post #1 of 14 (permalink) Old 04-02-2009, 11:16 PM Thread Starter
my tb truck's Avatar
Rear hub removal
After you remove the nut holding the rear hub can you pull the hub off with a puller without taking anything else loose? The manual does't give a good detailed breakdown for hub removal, only shows farther disassembly to remove shaft. I only need the hub off. I am not replacing anything, only want to drill it to a 4.50 instead of 4.25. Any help might save me some extra work. This is a 1995 T-bird LX ,Thanks. Larry.
my tb truck is offline
post #2 of 14 (permalink) Old 04-03-2009, 02:15 AM
The nut retains the axle to the hub. The rear hub itself is pressed into the bearing; the bearing pressed into the knuckle.
From this thread I found this SCCOA page: Ford Thunderbird Rear Wheel Bearing Installation. These instructions may be of help.
Astaeroth is offline
post #3 of 14 (permalink) Old 04-03-2009, 07:15 AM
R8D-XXX's Avatar
This is the way I just did mine:
1) remove shaft nut
2) remove the 3 bolts holding the hub/knuckle on
3) half shaft will probably pop out of rear end because it is stuck into knuckle. Knock the half shaft out of knuckle with a dead blow.
4) you will then have to have access to a press to get the hub and bearing out of the knuckle.
And then put it all back together in the opposite order.
pics of my car
Updated 10/14/11
13.0 @ 106.5 1.79 60ft
R8D-XXX is offline
post #4 of 14 (permalink) Old 04-03-2009, 11:26 AM
rbrown's Avatar
rbrown is offline
post #5 of 14 (permalink) Old 04-03-2009, 12:30 PM
VicRattlehead's Avatar
just buy cobra hubs and wow its all done for you.
CMP Drag Racing
VicRattlehead is offline
post #6 of 14 (permalink) Old 04-03-2009, 06:58 PM Thread Starter
Hey Guys, I do appreciate your help. I was looking fo an easy way which I never find. I took the hubs off just like I thought I was going to with no problem. I have access to a machine shop and a good machinist so it won' be a problem now that they are off the truck. Thanks again. Larry.
post #7 of 14 (permalink) Old 04-14-2009, 08:31 PM Thread Starter
I got the hubs and drums drilled for the 5x4.5 pattern. My machinist made a setup to bolt the knuckle and hub to the table and drilled them out without pressing them out. Tomorrow I am removing front hubs to drill them. Now I can get some original looking wheels for the 48F1 truck.
post #8 of 14 (permalink) Old 04-14-2009, 08:48 PM
rbrown's Avatar
In the front since they don't have to be pressed in, for the price, new mustang hub assemblies might be better.
And those rears look good.
rbrown is offline
post #9 of 14 (permalink) Old 04-14-2009, 09:37 PM
tbirdtess's Avatar
How much??
What did your Machinist charge to redrill the rear hubs?
I need to get mine redrilled. I can press them off no problem.
Does anyone know if rear drum & rear disk hubs are the same?
Paul
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #10 of 14 (permalink) Old 04-17-2009, 08:12 PM Thread Starter
Question Which hubs?
I looked at the front hubs and they will have to be built up where the studs will be at the new location. Which Mustang front hubs would match the front disc brakes on the T-bird? I don't see many Mustangs at U-pull it yards. Rock Auto has some hubs for about $65.00. This is a 1995 LX I am asking about. Thanks for your help. Larry.
post #11 of 14 (permalink) Old 04-17-2009, 08:55 PM
rbrown's Avatar
Sorry, I thought you were getting these redrilled for Mustang pattern.
91 Festiva 1.3L baby 5 speed
10 Flex Brick Twin Turbos
*Rodney*
rbrown is offline
post #12 of 14 (permalink) Old 04-18-2009, 10:41 AM Thread Starter
1) remove shaft nut
What did you do about the front hubs? It looks like they cannot be just drilled out and the studs relocated. Are there any Mustang hubs that would fit the 1995 T-bird ? I am changing the patter as you know from 5x4.25 to 5x4.50 so I can order me some original looking steel wheels for the 48 Ford F1. I have the back ones finished. Thanks, Larry.
post #13 of 14 (permalink) Old 04-18-2009, 01:37 PM
Listed from the main page tech articles...
4.25 to 4.5 Bolt Battern Change
http://members.tccoa.com/dlf/Article.html
a black car.
Sophosis is offline
post #14 of 14 (permalink) Old 04-24-2009, 09:08 PM Thread Starter
We are through with the front hubs also. Ready to put them back on and figure the backspacing I need and order me some original looking wheels. Putting 8 inch on the bacvk and 6 inch on the front. BFG T/A radials and trim rings with original FORD hubcaps for a 48 F1.
