Shocks with Eibachs? - TCCoA Forums
post #1 of 28 (permalink) Old 04-04-2009, 11:04 AM Thread Starter
kscull70's Avatar
i have recently got a set of the eibach lowering springs. right now the shocks that are in my price range are the KYB GR-2 and the Tokico blues. Which of those two would be the best match for the eibachs?
All help is appreciated. Thanks
-Kevin
kscull70 is offline
post #2 of 28 (permalink) Old 04-04-2009, 03:36 PM
Clueless Poster
v8_superbirdy's Avatar
Send a message via AIM to v8_superbirdy Send a message via Yahoo to v8_superbirdy
-Kevin
well i have heard good and bad about the kyb i literally just ordered all 4 shocks kyb gr2's today about 30 mins ago. i'm also running eibachs on the rear waiting for struts to come in to replace the springs with eibachs right now. i would also suggest you get a set of short sway bar links off superdcoupeperformance.com supposed to help flatten the sway bar out after being lowered makes sence to me nayways.
my other ride is an ambulance!
1997 V8 sport - first car - sold 6/7/10
2006 silver mustang gt premiumcustom made grill, frpp shorty headers, pypes cat back exhaust, hurst billet pro shifter,
v8_superbirdy is offline
post #3 of 28 (permalink) Old 04-04-2009, 04:46 PM Thread Starter
kscull70's Avatar
where did you order the KYB's from?
and i never thought about the shorter sway bar links
thanks for the help!
kscull70 is offline
post #4 of 28 (permalink) Old 04-04-2009, 07:14 PM
FordFanatic's Avatar
you might want to research that on here. i could have swore that you only needed the shorter links if your using an aftermarket sway bar.
FordFanatic is offline
post #5 of 28 (permalink) Old 04-04-2009, 09:10 PM
The Great Obucina's Avatar
shocks......do it right, go koni.
"Booyah". Stu Scott.
The Great Obucina is offline
post #6 of 28 (permalink) Old 04-05-2009, 01:02 AM
white 97 lx's Avatar
He convinced me to do it
white 97 lx is offline
post #7 of 28 (permalink) Old 04-05-2009, 12:12 PM
Clueless Poster
ordered them through my local pepboys only because with having them shipped it would be way more to order them from a website.
i could be wrong about the sway bar links but if i read correctly the reason you need them is when you lower the car the sway bar links are obviously unchanged and when it's lower the links push the sway bar up causing it to not go down the full length and taking away travel of the sway bar so that it actually "detunes" the sway bar.
post #8 of 28 (permalink) Old 04-05-2009, 02:09 PM Thread Starter
kscull70's Avatar
hmmm i will read into the sway bar links...and i do no have the funds to the koni's at the moment or else i would.
thank you for all the help
kscull70 is offline
post #9 of 28 (permalink) Old 04-05-2009, 03:14 PM
CEO, WT Club
GODSPEED's Avatar
I've had eibachs with kyb on my old car, and eibachs with tokico's on my new car.
Go eibachs with tokicos.
-Joel
Previous MN12s:
GODSPEED is offline
post #10 of 28 (permalink) Old 04-05-2009, 04:13 PM Thread Starter
kscull70's Avatar
While researching the shorter sway bar end links i found that
"When you lower a car it will need to be realigned and you should also consider getting new shorter rear sway bar end links to maintain proper bar orientation."
This came from supercoupeperformance.com under the vogtland lowering springs ad.
i know it says that you should do this but is this mandatory? And have you guys that have the eibach springs done the shorter sway bar links?
Kevin
kscull70 is offline
post #11 of 28 (permalink) Old 04-05-2009, 06:23 PM
Bay_Bird93's Avatar
No, its not mandatory. I have eibach springs and have the stock length sway bar links. And as for shocks, go koni.
'97 Lincoln Mark Viii LSC - Stock
'93 Ford Thunderbird - Splitport & M5r2
'64 Chevrolet Impala SS - Stock
Bay_Bird93 is offline
post #12 of 28 (permalink) Old 04-05-2009, 08:31 PM Thread Starter
kscull70's Avatar
thank you Bay_Bird93 and everyone else for all the help
kscull70 is offline
post #13 of 28 (permalink) Old 04-06-2009, 12:07 AM
Kelsey Smith's Avatar
Send a message via MSN to Kelsey Smith
I've got the same Eibach springs with Tokico blues, I'm very satisfied. If I'd had the funds, I'd have definetely gone with the Koni's (For that matter, if I had the funds, I'd have gone to a fully adjustable coil-over, like a QA-1 or something), but I like my current setup. Rides smooth, and handles really well, even stressing it autocrossing. Way better than cut Sport springs and old Sport shocks
"WHAT CONE?!?!
1997 T-Bird Sport, 'Interceptor' (12 ESP 2008-2012)- CAI, 2.25 duals, Flowmaster 40 series, Clear corners, BBK 70mm Throttle Body, TrickFlow upper intake, PI Intake, BBK adjustable fuel pressure regulator, LE stripes, Bullitt-style gauge faces. 18x9 wheels, Sniper tuned, 3,620 pounds
1991 Ford F250 - Air restrictor delete. Cat delete.
1991 T-Bird 'Interceptor II' (12 CP 2013-) - Race-prep, Full custom "interior", Carb'd 302, Trick Flow twisted wedge heads, stage 1 cam, Custom Koni coil-overs front, Koni yellows rear, Cobra front brakes, fuel cell, 18X9 wheels, 275/30 Hoosier A6, 4.11 T-Lok. 3000 pounds
2004 Toyota Solara SE - V6, Sport package, Muffler delete, 17X7 wheels, 235/50 Conti ExtremeContact DWS
Kelsey Smith is offline
post #14 of 28 (permalink) Old 04-06-2009, 01:51 AM
Traveler's Avatar
I've got KYB's and Eibachs... Have no complaints whatsoever.
As far as the shorter links... I have them from Supercoupeperformance. Haven't noticed a huge change in performance, however I have noticed that because they do not have any pivots in them, when you jack up the car and the suspension hangs all the way down... it bends the bolts. Don't know if this is important or not, they still work obviously, but I hope to find a way to shorten the stock links with the pivots in them.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #15 of 28 (permalink) Old 04-06-2009, 08:18 AM
96sport's Avatar
Eibachs & shocks
I tried the cut spring route on the "new" 96 Sport, but didn't like the ride.
Now putting in Eibach 6 cyl springs. $99 on ebay. Fronts are done and so far I like the height and ride. Will do Koni when the stock shocks wear out.
Straightaways are for fast cars
Turns are for fast drivers
96sport is offline
post #16 of 28 (permalink) Old 04-06-2009, 02:05 PM Thread Starter
kscull70's Avatar
i think i am going to go with the eibachs and tokico's. Thank you for all of the input and help that you guys gave.
kscull70 is offline
post #17 of 28 (permalink) Old 04-06-2009, 02:32 PM
Maic's Avatar
I had Monroe and Tokico's with the Eibachs. Monroe Reflex=BS, Tokico's with the Eibachs where 1% better but still to soft in the Front. Beware of Speed Bumps.
You may wait for someone who has a comparison between Tokico and KYB, if you can.
Note: I know the Konis are out of your price range at the moment, but if you serious about driving and keeping you car those are the way to go with the Eibach Springs.
-Maic
Maic.
Maic is offline
post #18 of 28 (permalink) Old 04-06-2009, 03:07 PM Thread Starter
kscull70's Avatar
-Joel
GODSPEED,
Could you give a comparison of the kyb versus the tokicos for me?
Kevin
kscull70 is offline
post #19 of 28 (permalink) Old 04-06-2009, 07:08 PM
Clueless Poster
i would've got better shocks but almost 800 for shocks is waaaayyy over my minimum wage budget at the moment. hell some day i may get tokicos
post #20 of 28 (permalink) Old 04-06-2009, 07:15 PM
Maic's Avatar
-Joel
Missed out on that one. This Thread is moving fast. lol
Good catch kscull70
-Maic
Maic.
Maic is offline
post #21 of 28 (permalink) Old 04-06-2009, 10:41 PM
KINgGh0sT's Avatar
Send a message via AIM to KINgGh0sT
I don't want to hijack this thread but I am wondering how much do you guys scrape with a 1.5Inch drop?
KINgGh0sT is offline
post #22 of 28 (permalink) Old 04-06-2009, 11:11 PM
mrwiggles2004's Avatar
My front bumper will still clear most sidewalks at like QT for example. But If I dont go really slow over larger speed bumps then I scrape. I dont take train tracks at full speed anymore either
97 Thunderbird LX 4.6L
Current Mods
PI Intake Manifold, Comp XE268's, 180 degree T-stat, Brother's Performance U/D pulleys, K&N filter w custom CAI, 75mm TB and Trick Flow plenum, Borla mufflers w Magnaflow tips, Magnaflow straight cats, Summit 8mm wires, Eibach Pro Kit Springs, Koni Adjustable Front Shocks, Bilstein Cobra Rear Shocks, Cobra R replica rims(17x9)front (17x10.5)rear
mrwiggles2004 is offline
post #23 of 28 (permalink) Old 04-06-2009, 11:28 PM
Bay_Bird93's Avatar
The only time I ever scrape is when driving down certain driveways.
post #24 of 28 (permalink) Old 04-07-2009, 12:37 AM
Clueless Poster
i dont scrape much only my fatty glass packs did but they hung lower then stock. the back end i havent scraped yet. the front end of my car isn't lowered yet.
post #25 of 28 (permalink) Old 04-07-2009, 12:45 AM
KINgGh0sT's Avatar
I scrape with a fully loaded car sometimes and I have no drop so I was worried.
post #26 of 28 (permalink) Old 04-07-2009, 01:04 AM
Clueless Poster
well if fully loaded you scrape and you plan on being fully loaded often i wouldn't lower your car. you might want to look at a stock hieght but stiffer spring then.
post #27 of 28 (permalink) Old 04-07-2009, 01:17 AM
KINgGh0sT's Avatar
I was also thinking I cannot really take what I have now as an opinion. I think with a stiffer spring and shock combo I could get away with the drop
post #28 of 28 (permalink) Old 04-07-2009, 03:39 AM
The Band, not the Disease!
AnthraxBird's Avatar
You can, just be more careful where you used to scrape at.
AnthraxBird is offline
