Economics of a new LCA, does not pay to replace a ball joint - TCCoA Forums
post #1 of 12 (permalink) Old 04-09-2009, 02:51 PM Thread Starter
Using rockauto prices, a premium moog LCA cost $60. Has 3 components.
A moog ball joint cost $31, strut bushing $18 , Frame bushing $21. = $70
So they pay you $10 to get the arm! If you factor in any labor you are probably ahead by $100. Any labor operation seems to be a minimum of $50 around here.
The by the time a ball joint goes, the frame or shock bushings are usually toast too.
The only downside is the alignment.
95 4.6L Rusty Survivor!
tbirdguy is offline
post #2 of 12 (permalink) Old 04-09-2009, 03:30 PM
thanks for the breakdown.
post #3 of 12 (permalink) Old 04-10-2009, 05:52 AM
Sideoiler's Avatar
I like your math!
Sideoiler is offline
post #4 of 12 (permalink) Old 04-10-2009, 01:47 PM Thread Starter
Originally Posted by white 97 lx View Post
I doubt the strut rod bushing comes with the arm though.
Nope, but the STRUT bushing does. I believe there was an arm for the SC that came with that too! It is discontinued.
tbirdguy is offline
post #5 of 12 (permalink) Old 04-10-2009, 01:51 PM
white 97 lx's Avatar
yeah went and checked that just now, ur pretty quick lol. Maybe I should take the time to actually read what is typed .
white 97 lx is offline
post #6 of 12 (permalink) Old 04-15-2009, 06:09 AM
Kevin's Avatar
Send a message via AIM to Kevin
And, you can save the alignment by using a bit of spray paint PRIOR to removing the frame bushing bolt - you can reinstall in the same position by referring to where the adjuster plate was.
Have done just balljoints before, pain in the arse - will only do a control arm from now on.
1992 Mercury Cougar XR7 5.0 - Rust In Pieces
1995 Mercury Cougar XR7, rust free Florida car - future 5.0 project
Kevin is offline
post #7 of 12 (permalink) Old 04-15-2009, 09:34 AM
sdavis872's Avatar
I just had my ball joints pressed out and new ones in and I had to get an alignment after. I really wish I would have had the whole LCA done, but the mechanic did just the ball joint because it was cheaper to do that. It was about $270 and he said it would have been about $350 for the LCA.
sdavis872 is offline
post #8 of 12 (permalink) Old 04-15-2009, 11:27 AM Thread Starter
Does anyone have issues with the camber frame bolts seizing in the bushings? Or do they usually slide out easily? One car came out easy, but I'm wondering if I'm pushing my luck!
tbirdguy is offline
post #9 of 12 (permalink) Old 04-15-2009, 11:47 AM
One of my Birds gave me no problems.
The other, unfortunately, did have seized bolts on both LCAs. Ended up having to cut them out.
It depends on your local rust factor and on how long the bolts have been in place.
If the bolts on both sides of your car have been in for approximately the same time, you'll probably be all right. Probably.
Those who live by the sword get shot by those who don't.
TeflonJon is offline
post #10 of 12 (permalink) Old 04-15-2009, 12:03 PM Thread Starter
Guess I'll keep that harbor freight angle grinder in mind
tbirdguy is offline
post #11 of 12 (permalink) Old 04-16-2009, 11:02 AM
Kevin's Avatar
Just get a bigger hammer!
My rust bucket 92 fights me with every nut/bolt I try to remove - but they ALWAYS come off/out.
Problem with pressing out/in a new balljoint is that IF you take the LCA out of the car without marking the camber plates - you will need an alignment, may as well buy a new arm. Do it without removing the LCA = PITA, but no alignment needed.
My opinion - just mark where the plate was - no alignment needed.
Kevin is offline
post #12 of 12 (permalink) Old 04-16-2009, 02:12 PM Thread Starter
I'm beating a strut sleeve bolt now. I will probably have to move up to a larger hammer. I don't want to heat it too much because of the rubber stench.
tbirdguy is offline
