Rear end links broke...is there a problem? - TCCoA Forums
post #1 of 15 (permalink) Old 04-09-2009, 04:28 PM Thread Starter
Slowride's Avatar
Send a message via Yahoo to Slowride
Put Vogtland springs on my '89 SC and had a new set of rear sway bar endlinks (shorted ones) put in and not even 6 months later....both of them broke!!! Found a couple of pieces in the driveway. Has there been any issues with materials that anyone has heard of ??? If not, then what would cause this to happen??
Thanks!
Slowride
The early bird may get the worm, but the second mouse gets the cheese!!!
Slowride is offline
post #2 of 15 (permalink) Old 04-13-2009, 04:33 PM
Interceptor's Avatar
Send a message via Yahoo to Interceptor
The rear endlinks on these cars aren't very robust. I've seen a setup made with spherical bearings but I don't recall where. It was a lot stronger than the stock type setup. You didn't mention if you had a larger rear bar. This would add to the stress placed on the endlinks too.
Interceptor is offline
post #3 of 15 (permalink) Old 04-14-2009, 09:40 AM
If it broke both endlinks, something isn't right; the stress should have gone away when the first link broke.
Can you post a pic of the endlinks and the position of the swaybar?
post #4 of 15 (permalink) Old 04-14-2009, 09:51 AM
Eleventeenth Gear Poster
Aaron K.'s Avatar
I replaced a broken set of Energy Suspension rear endlinks a month or so ago that were about 5 years old. I was jacking up the rear to patch a tire, and as I was jacking it up, the head of the drivers side endlink snapped off. I checked the passenger side and the head on it had already broken off, and looked like it had been broken for a couple months.
Sold = 96 Thunderbird
Aaron K. is offline
post #5 of 15 (permalink) Old 04-14-2009, 11:43 AM
Traveler's Avatar
I've noticed this with my shortened endlinks:
The factory stock endlinks have a pivot on the end to allow the angle to change between the endlinks sway bar. The newer "shortened" links are simple bolts that run through the swaybar, no pivot. This works fine (on my car) till I jack the car up and the angle between the swaybar and the link gets extreme. Then the bolt that is the endlink bends. it hasn't broken yet, but I have replaced them twice now. I'm trying to think of a way to make shortened links that have pivots.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #6 of 15 (permalink) Old 04-14-2009, 05:36 PM
Maic's Avatar
x2
-Maic
Maic.
Maic is offline
post #7 of 15 (permalink) Old 04-14-2009, 06:12 PM
Clueless Poster
v8_superbirdy's Avatar
Send a message via AIM to v8_superbirdy Send a message via Yahoo to v8_superbirdy
i haven't looked at it but an idea popped into my head. couldn't you take the swivel part off. IIRC the swivel is held on with one bolt and you could simple move and bolt it onto the shorter sway bar links.
my other ride is an ambulance!
1997 V8 sport - first car - sold 6/7/10
2006 silver mustang gt premiumcustom made grill, frpp shorty headers, pypes cat back exhaust, hurst billet pro shifter,
v8_superbirdy is offline
post #8 of 15 (permalink) Old 04-14-2009, 07:01 PM
Maic's Avatar
May some like this, with the Factory EndLink Bracket on top to allow for movement.
I found a link to a company that makes a similar top part in various sizes and strength. I'm just don't know yet witch strength/size to go with.
-Maic
Maic.
Maic is offline
post #9 of 15 (permalink) Old 04-14-2009, 08:30 PM
Clueless Poster
-Maic
i like those as they are fully adjustable one size fits all. only thing i dont like is that they look some what cheap.
post #10 of 15 (permalink) Old 04-14-2009, 08:40 PM
Maic's Avatar
..here is a Thump for you with the heavy duty version
http://img14.imageshack.us/img14/6404/thumbsdown50.jpg
-Maic
Maic.
Maic is offline
post #11 of 15 (permalink) Old 04-14-2009, 09:01 PM
Clueless Poster
-Maic
...well i've already ordered the ones of scp.com so ill see what i can jerry rig together
post #12 of 15 (permalink) Old 04-15-2009, 02:24 AM
speaking of which what is the correct part number for the energy suspension shorter sway bar endlinks?
post #13 of 15 (permalink) Old 04-15-2009, 04:43 PM Thread Starter
Slowride's Avatar
INTERCEPTOR: Still using the stock sway bars.
GROG6: No pics to post, I only found 1/2 of one end link, 1 poly bushing, 1 spacer and 1 washer.
Like I said, I have no idea why this happened...maybe the shop that intalled them tightened them too tight. The next set I'll put on myself. I wouldn't think the stress on the endlinks would have increased with it being lowered, maybe if I used the stock ones...but the shorter ones should keep everything about the same, right? I know the stock style one's I put on the CAT two years ago are still in one piece. Thanks for the input guys. The pics of the end links with the swivel at the top look pretty descent...just not sure how strong the main bar/shaft would be with it being completely threaded like that.
Slowride is offline
post #14 of 15 (permalink) Old 04-15-2009, 05:56 PM
Sideoiler's Avatar
This may sound like a stupid question, but if one of the end links are broken would this cause the passenger side rear end to bottom out on over-sized tires? Like 255/60/15's
Sideoiler is offline
post #15 of 15 (permalink) Old 04-26-2009, 04:24 PM
Lil Mikey's Avatar
The only thing the end link being broken should affect is corners. Is the rubbing only happen during left hand turns?
Normally for rubbing on the back, make sure you have the correct tire size and back spacing. If you want to fit a little more tire, roll the lip inside the fender up so it doesn't hit the tire.
Mike
1995 Thunderbird SC Terminator 6spd http://forums.tccoa.com/showthread.php?t=89775
2006 F250 QuadCab Shortbox 4x4 6.0L- the I'm going to have to tow the T-Bird home when I break it vehicle.
1980 Dodge Mirada - Collecting tree sap at grandma's house - My first engine swap(s) - Slant 6 to 318 to 400
1973 Firebird Formula - Totaled - next in line after the T-Bird gets done. - Pontiac 350, 4spd, Ford 9", etc
Lil Mikey is offline
