Steering wheel shake - TCCoA Forums
post #1 of 10 (permalink) Old 04-20-2009, 04:42 PM Thread Starter
Has anyone had this problem? Between the speeds of 20 and 50 my steering wheel rocks back and forth. No vibration over 60 mph. I had the tires balanced and rotated. Looking for ideas. The guy at the tire shop said my rims were out of round.
milo042005 is offline
post #2 of 10 (permalink) Old 04-20-2009, 04:45 PM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
wow.
tierods sound like the culprit. any clunking?
2014 GT
1990 300ZX TT
big mike is offline
post #3 of 10 (permalink) Old 04-20-2009, 04:57 PM Thread Starter
No clunking. Car rides smooth except for the annoying steering wheel shake
post #4 of 10 (permalink) Old 04-20-2009, 05:00 PM
Bad rims = bad vibration.
How old are the tires? Sometimes the tires themselves go bad, and no amount of balancing will fix them.
Do you have factory or aftermarket rims?
The front suspension could cause some of what you describe, if it were bad enough, but generally this seems like a tire issue.
Since there is no vibration over 60... I wonder if it could be something outside the box. Power steering, perhaps... maybe the rack itself.
91TwighlightGT is offline
post #5 of 10 (permalink) Old 04-20-2009, 05:15 PM Thread Starter
Factory rims. Tires are futura's. I dont know how old they are. Tread looks pretty good.
post #6 of 10 (permalink) Old 04-20-2009, 06:38 PM
To determine the age of a tire there is a stamped four digit or three digit code (if it was made before 2000). '1406' would mean the tire was manufactured the 14th week of 2006. '265' would correspond to the 26th week of 1995, or 1985 but if it was that old you'd be able to tell. This is only stamped on one side. This is a useful bit of information everyone should know (especially if you like to buy used tires).
coolhandzep is offline
post #7 of 10 (permalink) Old 04-20-2009, 08:02 PM
Well, you could try jacking the car up and spinning the tire, visually checking it for any signs of uneven treadwear or a slipped belt (which is usually a bulging area of tire). Last option is to also have a different shop inspect and balance the tires. Perhaps the first shop's equipment isn't up to snuff.
post #8 of 10 (permalink) Old 04-21-2009, 10:09 AM
Kevin's Avatar
Send a message via AIM to Kevin
Also consider your rotors - they will be the culprit IF your rims are true, tires don't have shifted belts, and suspension components are fine.
Just changed my rotors+pads on the front after 11 years of ownership - shimmy went away.
Reason I knew it was rotors - tie rods were good, shimmy was present with summer AND winter wheels.
1992 Mercury Cougar XR7 5.0 - Rust In Pieces
1995 Mercury Cougar XR7, rust free Florida car - future 5.0 project
Kevin is offline
post #9 of 10 (permalink) Old 05-11-2009, 11:56 PM
Black_Cat's Avatar
Rotors for sure, when you hit the brakes, your engaging the calipers, if the rotors are warped, your steering wheel bounces side to side This bouncing increases with increased pressure on the brake pedal, it's a no-brainer
2011 BMW X5 35i Premium Package
2009 BMW 535i ///M Sport Package
Black_Cat is offline
post #10 of 10 (permalink) Old 05-12-2009, 04:07 AM
CrystalPistol's Avatar
But every time I've ever had a bad rotor, it only showed when applying some pressure to the brakes.
You said tires were rotated. Did moving the rears to the front not change it? If not, not likely wheels or tires unless all are bad.
Also, some people don't like weights on the outside in view. With wide tires if balanced statically putting all the weight on the inside only, you can induce shake which is why best to get them balanced dynamically.
Factory wheels? Offset is OK then.
Alloys? Not likely bent, the factory alloy wheels are very tough. Seen them break suspension in hits and not fase the wheel.
A combination of not enough caster and loose steering gear like a sloppy rack & pinion or bad wrag joint can do it, or a combination that includes the balance issue can cause it too.
My first guess is the balance technique used though.
CrystalPistol is offline
