Air Bags - TCCoA Forums
post #1 of 8 (permalink) Old 04-29-2009, 06:40 PM Thread Starter
Sideoiler's Avatar
Air Bags
Trying to keep my 255/60/15 radial TA's from bottoming out and was wondering if these would work for me?
Air Lift; Air Lift 1000 60776 at http://www.streetsideauto.com/index.asp
Sideoiler is offline
post #2 of 8 (permalink) Old 04-29-2009, 07:05 PM
It says it will fit mine, so it should fit yours!
post #3 of 8 (permalink) Old 04-29-2009, 07:22 PM
Maic's Avatar
Thumbs up
YES ! Just put those in 3-4 months ago.
Just be aware,
Quote[Air Lift 1000 Rear; Coil Spring; No Drill; Installation Time - 1 Hour Or Less;]Quote
Drill = Yes, More than 1Hour to install both.
-Maic
Maic.
Maic is offline
post #4 of 8 (permalink) Old 04-29-2009, 07:25 PM Thread Starter
Sideoiler's Avatar
-Maic
Were they hard to install?
post #5 of 8 (permalink) Old 04-29-2009, 07:50 PM
Maic's Avatar
Not so hard in my opinion. Just Time consuming doing it nice and proper.
I installed my'n the same way (i thing Racecougar) has his. Routing the hose to the top, not the bottom.
-Maic
Maic.
Maic is offline
post #6 of 8 (permalink) Old 04-29-2009, 08:56 PM
CrystalPistol's Avatar
I have them on the Merc for when I pull a trailer, when unloaded, I run 3 lbs or so in them so they don't wreck the ride. At anything over 5-7 psi, they really stiffen the rear, and if on seperate air line where air cannot move from side to side, they'll add lots of oversteer like a fat sway bar. Even when sharing a common line, they'll add some.
Rated for up to 35 psi, they'ld have to be like rocks then.
CrystalPistol is offline
post #7 of 8 (permalink) Old 04-30-2009, 09:14 AM Thread Starter
Sideoiler's Avatar
Running the oversized TA's whenevver I have a heavy load in the boot or a couple of heavy (read fat-azzed) adults in the rear seat and hit a bump or a dip in the road the car bottoms out on the tires. Not bad, but enough to make contact and noise. I was hoping to find some Monroe air shocks to fit the car but haven't been able to find them to fit the Bird. That's why I was looking at these and thinking of adding just enough air to prevent the bottoming out.
post #8 of 8 (permalink) Old 05-05-2009, 09:59 AM
The air bags will take care of that. They just require a minimal bit of air all the time to prevent chaffing or pinches as I recall it saying in the instructions.
Here's hoping they don't read this.
