Replacing UCAs and LCAs - thoughts/suggestions? - TCCoA Forums
post #1 of 4 (permalink) Old 04-30-2009, 07:05 PM Thread Starter
Well I finally did it today. I purchased all new LCAs, UCAs, strut mounts, and strut rod bushings.
I'm converting my Mark 8 over to a tokico setup.
I've never done a control arm before. Are there any suggestions you all may have on getting this done easily?
I sprayed all the bolts down a month ago with PB Blaster and will do that again a week before diving in.
I finally fixed my belt drive air compressor too :-)
I know I need a ball joint separator - of which i can probably rent.
Any other tips/tricks?
TIA!
wood_e is offline
post #2 of 4 (permalink) Old 04-30-2009, 08:02 PM
SignofTheCat94's Avatar
Send a message via MSN to SignofTheCat94 Send a message via Yahoo to SignofTheCat94
I'm doing the same thing this weekend or next. A quick search will get you a lot of advice from the guys who have done this before. My personal advice is make sure you have a manual (an actual service manual would be best, but I've made due with a Chiltons or Haynes on some pretty complicated stuff in the past), heat source for stuck bolts, good working air tools and a torque wrench. I also read that an 18mm ratcheting wrench becomes your best friend for the UCA. I'm going to do a much bigger search and print out what I need before I turn a single bolt.
Mods? Do the ones in the garage waiting to go on the car count?
Many thanks to my fellow Veterans; I am honored to be a part of your ranks.
SignofTheCat94 is offline
post #3 of 4 (permalink) Old 04-30-2009, 08:26 PM
Maic's Avatar
way to go. It's all here!
-Maic
Maic.
Maic is offline
post #4 of 4 (permalink) Old 04-30-2009, 09:32 PM Thread Starter
got it - search is king! Planning will be a must for this job.
wood_e is offline
