power steering hose replacement - TCCoA Forums
post #1 of 23 (permalink) Old 05-01-2009, 01:41 PM Thread Starter
Faster than Porkchop
cjchevez's Avatar
97 4.6 tbird leaking power steering fluid .
I need to replace my power steering pressure hose and would like to have a walk through if possible . Any tips ?
1997 Ford Thunderbird 4.6 Sport .
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
PI heads *PI intake*Mark VIII torque converter*Cobra T-loc w\4.10's * Jmod*tranny fluid cooler*P&P stock T/B & plenum*UD pulleys* Dynotech 4in ds*80mm Lightning maf*Xcal2*02 GT intake tube.
cjchevez is offline
post #2 of 23 (permalink) Old 05-01-2009, 03:58 PM
Best advice I can give is remove the oil filter and power steering pump for easy access to the high pressure line at the rack. Stubby wrenches will also be useful.
post #3 of 23 (permalink) Old 05-02-2009, 05:34 PM Thread Starter
cjchevez's Avatar
I got the power steering pump off but I cant disconnect the hose from either the pump or the rack ! I started to strip the nut on the pump so I called it quits foe today .
Does the thread go backwards on the hose or do I need a special wrench ?
What size wrench ?
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
cjchevez is offline
post #4 of 23 (permalink) Old 05-02-2009, 05:51 PM
twin turbo 281's Avatar
When you get it off you can take it to a hydraulic hose and equiptment store/shop and have them repair it or make you a new line.
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #5 of 23 (permalink) Old 05-02-2009, 06:11 PM Thread Starter
cjchevez's Avatar
I have the replacement hose here but I don't have the correct wrench to take the hose off . I need to know the size wrench that i need for the hose .
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
cjchevez is offline
post #6 of 23 (permalink) Old 05-03-2009, 02:10 AM
Not sure about the size but it's not reverse-threaded, it's normal.
post #7 of 23 (permalink) Old 05-03-2009, 02:21 AM
KorpseofDeath's Avatar
Send a message via AIM to KorpseofDeath
Did you use a flare-nut wrench? It's leaking, so the nut is soaked, and a normal wrench won't hold strong and may slip, Possibly that's why it started to strip.
sorry I can't comment on what size, but I need to do the same because mine is leaking too.
~1997 TBIRD 4.6L LX SPORT ~ Xenon Kit ~ 149K Miles ~ K&N ~ JMOD ~ Daily Driver
~1991 TBIRD 5.0L HO ~ Completely Stock ~
KorpseofDeath is offline
post #8 of 23 (permalink) Old 05-03-2009, 10:52 AM Thread Starter
cjchevez's Avatar
I borrowed a flare nut wrench and that helped with the pump side now I only need to remove the rack side and this bithc is not moving I'm afraid of ruining the rack side fitting .
I cant use the flare nut wrench because it wont go over the nut since its attached to the other rack end .
Its a 18 size wrench but not a flare nut wrench that I need for the rack side .
I called my uncle so I hope he can save my project .
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
cjchevez is offline
post #9 of 23 (permalink) Old 05-03-2009, 11:02 AM
I don't know for sure if there is room for this but...
if there is, cut the metal line above the nut. You can now slide a 6 point socket or wrench over it that won't slip.
Good luck!
coolhandzep is offline
post #10 of 23 (permalink) Old 05-03-2009, 07:11 PM Thread Starter
cjchevez's Avatar
The job is done !!
You need to remove the powers steering pump& hose's , the bracket ,oils filter undo the lower water hose unbolt the rack move it around till you see the nut .
Then you need to get a wrench on the rack side of the hose nut then wrench the nut on the power steering pump side and undo .
This is a pain in the ass job I now have a new leak from the rack side !!
I called it quits for now and I might start saving for a newer car since I have this new leak now .
Is 33 to young to start hating working on cars ?
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
cjchevez is offline
post #11 of 23 (permalink) Old 05-03-2009, 08:19 PM
1995 cougar xr7's Avatar
i can't remeber the sizes all i remember is i never want to do it again
1995 cougar xr7 is offline
post #12 of 23 (permalink) Old 05-04-2009, 12:06 AM
Buckcreekbilly's Avatar
I agree, when i did mine, all i could do for the day was curse the damn engineers that designed this setup. It's gotta be the worse damn power steering hose i've ever replaced.
95 Thunderbird LX 4.6
K&N cold air intake. True 2 1/4" duals, Xenon GFX. 3:55 Trac loc. Beefier trans, 2800 stall convertor, MkV111 aluminum driveshaft.
Buckcreekbilly is offline
post #13 of 23 (permalink) Old 05-06-2009, 12:29 PM Thread Starter
cjchevez's Avatar
I have to re -do the whole job now but I'm going to take my time maybe work on it over a few weekends .
Looks like the rack might have to come down but not sure yet , I'm hoping its just an o ring that needs to be replaced .
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
cjchevez is offline
post #14 of 23 (permalink) Old 06-01-2009, 06:35 AM
Rob
Rob's Avatar
Send a message via AIM to Rob
Awww man, that sucks. Last time I did a rack install in a 93 cougar I wound up bending the tubes that come out of the rack and meet the hoses The tubes no longer were sealing inside the nuts. I had to replace the nuts and push in a new tube (relatively cheap parts from ford). That's what I get for thinking I found an easy way to change it and not just doing it the sucky way like i do on my 94. On 3.8, you can just reach down by the power dist box to unhook the lines from the tubes, but on 4.6 i just do it all from the bottom and dont remove anything.
-Rob
-Rob
Rob is offline
post #15 of 23 (permalink) Old 06-01-2009, 11:19 AM Thread Starter
cjchevez's Avatar
-Rob
Yes , that's what happened to me too lol , it was much easier this time around though . I left the pump on and just moved the rack till I got a good view after undoing the steering column .
Not too bad though , I guess after the first time you learn .
Ohh I got away without replacing the o rings , the two bigest Ford dealers didnt have them in stock .
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
cjchevez is offline
post #16 of 23 (permalink) Old 06-01-2009, 12:31 PM
Rob
Rob's Avatar
You lucky *****!
-Rob
Rob is offline
post #17 of 23 (permalink) Old 06-01-2009, 05:43 PM Thread Starter
cjchevez's Avatar
You lucky *****!
So far so good (knocks on wood)
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
cjchevez is offline
post #18 of 23 (permalink) Old 10-08-2012, 05:39 AM
loudpipessavelives's Avatar
Send a message via AIM to loudpipessavelives
anyone replace this on a 5.0 car by chance??
93 Bird/ Trick Flow 5.0-- awaiting some fresh paint
99 Marquis on 20's (daily)
01 Mustang Cobra with bolt on's-- 22k miles, might be for sale soon
http://www.cardomain.com/id/CDogg93
loudpipessavelives is offline
post #19 of 23 (permalink) Old 10-08-2012, 07:52 AM
Sure.
See my pics in the "Replace your pressure hose" sticky.
Three hints: Do your motor mounts. They're a LOT easier to do with the rack out.
Plan on new LCAs - it's a lot easier to reach the rack nuts while the LCA's out.
Learn how to cuss in a few more languages - I found Ferrengi and Klingon helped
And count yourself lucky - I don't see HOW the 4.6'ers do it.
RalphP is offline
post #20 of 23 (permalink) Old 10-08-2012, 02:32 PM
dDUBb's Avatar
Its just as easy .. and messy.
dDUBb is offline
post #21 of 23 (permalink) Old 10-08-2012, 03:31 PM
This sucks!!!!!!! I wanna be taking my car in for paint in about two weeks too! been working diligently on this too. Any idea how much time you had into the repair?
post #22 of 23 (permalink) Old 10-08-2012, 03:45 PM
http://forums.tccoa.com/showthread.php?t=136327&page=2 this is the correct link i believe?
post #23 of 23 (permalink) Old 10-08-2012, 08:19 PM
Roadrunnner's Avatar
I found my 94 was more diffcult
Will
Roadrunnner is offline
