clunking... - TCCoA Forums
post #1 of 9 (permalink) Old 05-04-2009, 10:12 PM Thread Starter
danalba's Avatar
clunking...
so the clunking on the passenger side continues. it only clunks when i go over a bump decently hard. not when just driving. iv replaced calipers rotors breaks LCA UCA tie rods and just about everything else looks new... im at a loss of what it could be.... anyone out there had same issue and it turn out to be weird?
MAC CAI/02 STANG MAF/SCT CHIP TUNED BY LONNIE
EIBACH 1.5 LOWERING SPRINGS- BILSTEIN GAS SHOCKS
90 SUPERCOUPE SIDE SKIRTS/REAR
18x9-FRONT: 245 REAR: 275
PI intake/PI cams
355 trac lok
new tune for swapped parts (93 oct)
no longer the owner.... but its still my child its just released into the world....
danalba is offline
post #2 of 9 (permalink) Old 05-04-2009, 10:47 PM
chsplayer's Avatar
i have a solution for you, my 93 did it and its fixed
check your sway bar links. i thought i just had one, but it sounds like im going to replace all. the part is 21 bucks and some change for the piece.
chsplayer is offline
post #3 of 9 (permalink) Old 05-04-2009, 11:45 PM
Stryker's Avatar
steering rack maybe? is it lowered?
Mods: The usual stuff... 3.73 Gears, J-mod, catless mandrel 2.5" true duals, Marauder Converter, Eibachs, Xcal2 and Phoenix Gold Audio, chrome 18's, etc. etc..
I joined the dark side...
2002 Mustang GT, FRPP Aluminator with Tork Tech MP112 intercooled S/C at 17PSI, with all the supporting mods.
Stryker is offline
post #4 of 9 (permalink) Old 05-05-2009, 02:07 AM
strut rod bushings...
wood_e is offline
post #5 of 9 (permalink) Old 05-05-2009, 07:54 AM Thread Starter
danalba's Avatar
its not lowered, and the other thing is i dont know how to check if any on them are bad. is there even a way to do this? next thing im checking out i think is going to be the sway bar links he said. and i dont know where the strut rod bushings are...
PI intake/PI cams
355 trac lok
danalba is offline
post #6 of 9 (permalink) Old 05-07-2009, 12:48 PM Thread Starter
danalba's Avatar
ok so i figured this one out, going in reverse there is no squeeking or creeking from my suspension. going in drive though it does squeek and when the weight transfers to the front end it makes a creeking like noise. what are some symtoms of bad struts. im thinking more and more this is it. and also where are the strut bushings located? top, bottom or both of the strut?
PI intake/PI cams
355 trac lok
danalba is offline
post #7 of 9 (permalink) Old 05-18-2009, 03:55 PM
The rod going from your LCA to your subframe is your strut rod. The bushings that go bad first would be the ones that connect it to the LCA. They are about $16 each at autozone. You will also need a 24mm deep well socket and vice grip to get the nut off of the strut rod.
autoxbird is offline
post #8 of 9 (permalink) Old 05-18-2009, 07:21 PM Thread Starter
danalba's Avatar
will i be able to visibly see if the bushings are bad? i know what your talking about and they appear fine...
PI intake/PI cams
355 trac lok
danalba is offline
post #9 of 9 (permalink) Old 05-18-2009, 07:31 PM
TANKSHAW's Avatar
I just replaced all my suspension in front (i mean all). First test drive ... heard clunking... hmm torqued everything to spec what gives? So i decided to check her out underneath. Dude it turned out my sway bar link nut was'nt tightened enough! The link would move a little I mean like an eighth to a quarter of an inch!. If those are new check them nuts out! Make sure they are tight. If not check the play in the joint if the ball joint on the link moves in and out swap em.
96 4.6 sport---- fresh suspension, other than that stock as a rock!
TANKSHAW is offline
