Wheel hub/bearing brand? - TCCoA Forums
post #1 of 4 (permalink) Old 05-12-2009, 05:38 PM Thread Starter
So when I rotated the tires today I discovered that my left front wheel bearing is on its way out. RockAuto has two brands to choose from, Timken and BCA/National. Which one should I go with? Both are part number 513092. I'm also getting Dorman part #05113, I just want to make sure that's the right nut.
post #2 of 4 (permalink) Old 05-12-2009, 08:50 PM
The stock bearings are Timken; that's what I used.
You will need to press the rear ones apart; the fronts took ~15 minutes.
You need a 36mm socket, and a new nut.
Rockauto has those as well.
EDIT:
This is where I bought the socket...
http://www.mcmaster.com/#7205a62/=1qz241
post #3 of 4 (permalink) Old 05-12-2009, 09:07 PM Thread Starter
Kind of my impression too. Ordered the hub and nut, hopefully I can find someone with a socket that's big enough and a torque wrench that can handle 200+ ft/lbs!
post #4 of 4 (permalink) Old 05-12-2009, 09:17 PM
tbirdtess's Avatar
socket
Hello
I have the socket. 36MM
Western NY -- Tonawanda
Paul
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
